Old 04-22-2021, 08:01 AM   #19041
Grady
Grady's Avatar
Originally Posted by mrhemi View Post
Replaced the battery for the third time. Two Subaru warranty replacements have failed in a couple of years each and they have been on battery maintainers when not being driven. Purchased a Diehard Platinum group 34 this time. Time will tell how long it lasts.
Check the voltage of your maintainer and the float requirements of you battery. Sounds like it may be keeping the voltage to high and boiling out you battery. What maintainer are you using? I would go with Battery Minder, cost more but engineered well.
Old 04-26-2021, 10:22 PM   #19042
SkyeHack
SkyeHack's Avatar
Drives: 2018 BRZ tS
I did somethings.
SkyeHack is offline   Reply With Quote
The Following 8 Users Say Thank You to SkyeHack For This Useful Post:
BrahmaBull1990 (04-27-2021), Dadhawk (04-27-2021), jcw99 (04-29-2021), The Red One (04-27-2021), therealstoly (04-30-2021), tintumz22 (04-27-2021), weederr33 (04-29-2021), wolffbite (04-27-2021)
Old 04-27-2021, 05:08 PM   #19043
BrahmaBull1990
Howdy
BrahmaBull1990's Avatar
Drives: 2020 BRZ PP
Originally Posted by SkyeHack View Post
I did somethings.
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
BrahmaBull1990 is offline   Reply With Quote
The Following 2 Users Say Thank You to BrahmaBull1990 For This Useful Post:
NoHaveMSG (04-29-2021), SkyeHack (04-30-2021)
Old 04-28-2021, 11:23 PM   #19044
therealstoly
therealstoly's Avatar
Drives: 2020 BRZ Limited
Raceseng lugs. The craftsmanship is absolutely exquisite and pictures don't do these justice.
therealstoly is offline   Reply With Quote
The Following 4 Users Say Thank You to therealstoly For This Useful Post:
BrahmaBull1990 (04-29-2021), jcw99 (04-29-2021), norcalpb (04-29-2021), Wally86 (04-29-2021)
Old 04-29-2021, 12:40 PM   #19045
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
No doubt there's nothing better than these lugs that cost more than the wheels themselves!
Dzmitry is offline   Reply With Quote
Old 04-29-2021, 07:04 PM   #19046
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
I dropped off he heads and stuff at IAG today
The Following 2 Users Say Thank You to Breadman For This Useful Post:
BrahmaBull1990 (04-29-2021), NoHaveMSG (04-29-2021)
Old 04-29-2021, 07:14 PM   #19047
pope
has a funny hat
Drives: 2014 BRZ Limited
Swapped in a basic rear-view mirror and mounted a mirror based “dash” cam to it and mounted the included rear camera on the back window.
Also, drove the car in the rain for the first time. The grip pads on pedals are garbage. Foot slid off the clutch pedal twice.
pope is offline   Reply With Quote
The Following User Says Thank You to pope For This Useful Post:
Old 04-29-2021, 09:45 PM   #19048
BrahmaBull1990
Howdy
Drives: 2020 BRZ PP
Hell yeah. What’s the lead time to machine and get it back?
Old 04-30-2021, 01:08 AM   #19049
vintagemxer
vintagemxer's Avatar
Drives: 2016 BRZ Limited
Did some things
I did somethings.
Thank you for your service Skyehack
vintagemxer is offline   Reply With Quote
The Following User Says Thank You to vintagemxer For This Useful Post:
Old 04-30-2021, 06:31 AM   #19050
DunkThemMuffins
Drives: 2014 BRZ Limited, WRB
I launched my BRZ and my already overdue clutch started slipping on takeoff. So today I put it on jackstands, took the skidplates off, and I'm waiting for my Exedy OEM replacement
DunkThemMuffins is offline   Reply With Quote
Old 04-30-2021, 07:43 AM   #19051
Breadman
Breadman's Avatar
They are building the long block too i believe they said 5-8 weeks from when they started the short block to it being at my door. So end of may/start of june
The Following User Says Thank You to Breadman For This Useful Post:
BrahmaBull1990 (04-30-2021)
Old 04-30-2021, 10:29 AM   #19052
mrhemi
I have been using Battery Tenders. They have not been an issue on the other vehicles they are used on. Recently I have changed to a Schumacher dual output charger / maintainer. This works well as two cars are parked one over top of the other on a stacking lift. Time will tell.
mrhemi is offline   Reply With Quote
Old 04-30-2021, 05:37 PM   #19053
Stonehorsw
Stonehorsw's Avatar
Drives: 18 Brz (Sold) / 22 BRZ / 13 BRZ
GS Dry Filter
Installed today. Main reason was for easier maintenance, but first drive seemed to have reduced torque on low rpm. Let’s see how it goes after a week or so.
Stonehorsw is offline   Reply With Quote
The Following User Says Thank You to Stonehorsw For This Useful Post:
Old 04-30-2021, 05:45 PM   #19054
JD001
JD001's Avatar
Drives: Subaru BRZ
I hope you remembered to remove the plastic bag before installation...the car just don't like the plastic bagged filter..
