Old 04-21-2021, 03:18 PM   #77141
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Why specifically airspeed? I would think you would want to see static pressure on various surfaces more than anything else.
I would like to do pressure in the future but airspeed is the easiest to calibrate. Suction cup to front of car, note speed, note A/D reading. I figure it is a start with my limited ability.
NoHaveMSG is offline
Spuds (04-21-2021)
Old 04-21-2021, 03:29 PM   #77142
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
If you are saying that you calibrate it in front of the car, then put it under the car, it is still going to be inaccurate. Calibration only accounts for that specific location of the pitot tube. It will still show precise data you can compare against multiple runs, but it won't be accurate to actual airspeed.
Spuds is offline
The Following User Says Thank You to Spuds For This Useful Post:
p1l0t (04-21-2021)
Old 04-21-2021, 03:35 PM   #77143
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Yeah your right, difference in static pressure will skew it quite a bit. Maybe I just need to go back and rethink just using pressure transducers and forget airspeed.
Spuds (04-21-2021)
Old 04-21-2021, 03:47 PM   #77144
Spuds
The Dictater
Spuds's Avatar
Airspeed exiting the back of the car (assuming some sort of diffuser?) would be interesting data. Other than that, I would recommend pressure transducers on surfaces or strain gauges on whatever mounts for a diffuser/splitter if you have them. The biggest problem you are going to have is turbulence under the car. Idk the scale of that vs how take will affect the baseline, but be prepared for smoothing difficulties. That is one benefit of the strain gauge technique, it basically averages and damps for you.
Spuds is offline
NoHaveMSG (04-21-2021), p1l0t (04-21-2021)
Old 04-21-2021, 03:50 PM   #77145
p1l0t
p1l0t's Avatar
Airspeed indicator measures the difference between ram air and static airpressure. The difference in the calibrations based on location might tell you something...
p1l0t is offline
The Following 2 Users Say Thank You to p1l0t For This Useful Post:
Dadhawk (04-21-2021), NoHaveMSG (04-21-2021)
Old 04-21-2021, 03:52 PM   #77146
Spuds
The Dictater
Spuds's Avatar
Airspeed indicator measures the difference between dynamic pressure and static pressure. The difference in the calibrations based on location might tell you something...
FIFY. (Yes I know I am an ass)
Edit, this is wrong...
Spuds is offline
The Following 3 Users Say Thank You to Spuds For This Useful Post:
NoHaveMSG (04-21-2021), p1l0t (04-21-2021), soundman98 (04-22-2021)
Old 04-21-2021, 03:58 PM   #77147
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
That was my initial plan, I knew the data wouldn't be clean but to the point that Spuds brought up, it may be far enough off make it difficult to correlate.
All good info from you and @Spuds
I will likely start a build thread for my car this year even though it is pretty much built, just to document stuff like this. It may be backyard hackery but it's fun to play around with so why not.
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post:
p1l0t (04-21-2021), soundman98 (04-22-2021), Spuds (04-21-2021)
Old 04-21-2021, 04:44 PM   #77148
p1l0t
p1l0t's Avatar
My car is basically stock but I have thread just to keep track of everything, lol. (I have had other cars much more modified so starting a thread for the car is the first thing I do)
p1l0t is offline
Old 04-21-2021, 04:47 PM   #77149
p1l0t
p1l0t's Avatar
You're not an ass, but actually you are wrong. See total (ram) air pressure vs static air pressure is was gives you the dynamic pressure. So when I said it compares ram air vs static I was 100% correct. If I said it measured dynamic pressure I would simply not mention the comparison (ratio).
p1l0t is offline
Old 04-21-2021, 06:00 PM   #77150
Spuds
The Dictater
Spuds's Avatar
Doh. Yes, total pressure is static+dynamic.
Now I'm just a dumbass lol. But really I should have known that since that's kind of my degree...
Spuds is offline
Old 04-21-2021, 06:09 PM   #77151
p1l0t
p1l0t's Avatar
I got a Master's in Aeronautical Science and I forgot probably 90% of it. Then again I chose to fly planes instead of some of the more involved jobs...
p1l0t is offline
Old 04-21-2021, 06:13 PM   #77152
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
I'm in that mood today where I hate everyone and everything. That is all.
MS, CSCS, TSAC-F, CPT
weederr33 is offline
The Following 2 Users Say Thank You to weederr33 For This Useful Post:
Old 04-21-2021, 06:19 PM   #77153
p1l0t
p1l0t's Avatar
Don't get mad, get even.
p1l0t is offline
Old 04-21-2021, 06:20 PM   #77154
nextcar
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
But...
Originally Posted by drewbot
Pull out
nextcar is offline
The Following 4 Users Say Thank You to nextcar For This Useful Post:
p1l0t (04-21-2021), spike021 (04-21-2021), Ultramaroon (04-22-2021), weederr33 (04-21-2021)
