Old 07-27-2012, 02:41 PM   #1
Don@Accelerated
Don@Accelerated's Avatar
Wiseco - Accelerated Performance Turbo Forged Piston Set
Accelerated Performance is proud to announce another new product for the FA20 Engine. I supplied Wiseco with the parts required some while ago to make piston sets for the FA20 Engine. This particular piston drawing will be the turbo variation of an off the shelf Wiseco Piston and something in the 10-10.5:1 Variety.
There will be off the shelf versions and custom AP Spec Versions of the pistons. The AP versions will use advancements we have learned from our on and off road racing programs.
We are looking to create something very similar in strength to our Toyota 2jz pistons sets. I would suspect that each piston will be strong enough to supply 300hp per cylinder. Obviously thats far more than this engine will be able to hold for a long time if ever.
Don
Don@Accelerated is offline   Reply With Quote
Old 07-27-2012, 02:57 PM   #2
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
Any change in compression ratio?
industrial is offline   Reply With Quote
Old 07-27-2012, 03:15 PM   #3
Cessblood
Boost equals pleasure
Drives: MT Raven FRS Lexus ES300 &Turbo tc
x2
Cessblood is offline   Reply With Quote
Old 07-27-2012, 03:16 PM   #4
rusty959
Drives: DGM BRZ limited
Im excited.
rusty959 is offline   Reply With Quote
Old 07-27-2012, 03:17 PM   #5
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
Wow these look amazing!
Silverdub is offline   Reply With Quote
Old 07-27-2012, 03:22 PM   #6
Don@Accelerated
Originally Posted by Cessblood View Post
x2
Edited post. Thought I mentioned that!
Old 07-27-2012, 03:24 PM   #7
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
Don, any word on pricing yet?
kmbkk is offline   Reply With Quote
Old 07-27-2012, 03:25 PM   #8
colHolm
Default User Title
colHolm's Avatar
sweeeet.
colHolm is offline   Reply With Quote
Old 07-27-2012, 03:55 PM   #9
subatoy
subatoy's Avatar
Drives: subatoy
hey Don I've never replaced pistons for turbo charging a car so I have a few questions.
Lets say you are running 4 psi from your kit... the stock compression gives you around 215whp what can you expect out of this new compression ratio if you run the same set up?
would you say that this piston would yield better torque numbers?
subatoy is offline   Reply With Quote
Old 07-27-2012, 04:17 PM   #10
Symbiont
Tall guys fit, too.
Symbiont's Avatar
Drives: BRZ Premium 6MT (SWP)
Even though I am not currently in the market for something like this, it really makes me happy to see development ramping up quickly across the board.
Symbiont is offline   Reply With Quote
Old 07-27-2012, 04:25 PM   #11
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
1200hp! Woot! j/k
Very cool though. Nice to see things moving ahead.
The OP sad these would lower it to somewhere between 10:1 to 10.5:1.
If you keep the same boost but lower the compression, you'll lose power. The point of a lower compression piston is being able to run more boost reliably. I would't be surprised to see 14lbs boost or more with those pistons.
Old 07-27-2012, 04:40 PM   #12
Don@Accelerated
If you ran less compression ratio with the forged pistons. You would lose around 10-15whp would be my guess. However, you'll be able to add lots of boost to compensate
Old 07-27-2012, 04:53 PM   #13
SpeedR
First86 / boat thief
Drives: MKIV Supra
2JZ-GTE has 8.5 and can hit +30PSI with the right turbo. lower compression ratio will alow alow for a lot more power.
SpeedR is offline   Reply With Quote
Old 07-27-2012, 04:57 PM   #14
subatoy
subatoy's Avatar
Drives: subatoy
Originally Posted by Draco-REX View Post
1200hp! Woot! j/k
makes sense. soo if you are not looking for crazy numbers you can stay with the stock pistons just fine?
I would be very happy with 250 WHP
Accelerated Performance FRS/BRZ-300 Turbo Kit Don@Accelerated Forced Induction 104 11-26-2012 03:55 AM
Turbo BRZ from Accelerated performance buzznasa BRZ First-Gen (2012+) — General Topics 3 07-20-2012 11:14 AM
