Old 04-19-2021, 06:43 PM   #71
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Sounds like a DIY for one of you CANBUS gurus.
Originally Posted by timurrrr View Post
FWIW, I've already started thinking that I can just read the speed from the CAN bus (like I already do for another DIY device)
and show it on a large 3-digit 7-segment LED display above the gauge cluster.
This will also provide a better viewing angle!
Heck, it might even be bright enough to reflect in the windshield and then I can put it pretty high in my field of view, like the HUD in Corvettes.
Let's see if I find time to try this
It is probably broadcasting all the time, the speedo just only listens for it so often.
Yes, and even on multiple PIDs
The Following User Says Thank You to timurrrr For This Useful Post:
NoHaveMSG (04-19-2021)
Old 04-19-2021, 06:50 PM   #72
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
These car manufacturers clearly don't know how to make digital speedometers.
You should never buy cars from them!
Old 04-19-2021, 06:51 PM   #73
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I didn't think about that but would make sense. Must be broadcasting on different PIDs for speedo, TCS, and power steering control module.
Old 04-19-2021, 06:53 PM   #74
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
That is what I personally don't care for. It is scrolling so quick you can't really read it practically. It is enjoyable visually on an acceleration run, but that would be about it to me.
Dadhawk (04-19-2021)
Old 04-19-2021, 08:22 PM   #75
Actually, at least on the Ferrari, it is skipping numbers or its changing so fast there are numbers missed by frames of the video (which actually would be possible depending on the frame rate). I didn't take the time to look at the others. Pause the video and use the comma and period to go through it one frame at a time. It is skipping numbers quite a bit and you can see one fade into the next. There are also frames with no change.
If the 86 accelerated at the same speed as these cars it would look like that as well I suspect.
NoHaveMSG (04-20-2021)
Old 04-19-2021, 09:57 PM   #76
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Yes, I noticed that too, but still it was a lot more responsive.
Again, I never specifically said it should show every single number; I complained that the current refresh rate is too low.
Now that you mentioned it, I decided to do some "scientific" counting!
(30 fps)
Between the first frame that shows 0:03 to the first frame that shows 0:04, the number on the display changes 10 times.
So ~10 Hz, as I was suggesting as a good compromise for a while
For comparison, here's a GT86 video:
(it's 60 fps, so double the button pressing to view one second)
Between 0:41 and 0:43 (two seconds), the number changes 7 times. So ~3.5 Hz.
Ok, my "~2 Hz" estimation was a little wrong.
Looks like instead of ~5x'ing the refresh rate we only need to ~3x the refresh rate.
Old 04-19-2021, 11:32 PM   #77
soundman98
ProCrastinationConsultant
soundman98's Avatar
don't forget, they could also be doing some software smoothing, where the dash really only gets an update every 2hz, but displays incremental numbers between updates...
Old 04-20-2021, 07:30 AM   #78
But, aren't you assuming the two cars are accelerating at the same pace? In any given second the Ferrari is going to go through more MPH changes then the FRS during hard acceleration.
Old 04-20-2021, 12:44 PM   #79
surfwaxsmitty
Drives: '14 BRZ 6MT
Honestly, only used the digital speedo on my gen 1 and it was completely fine. The examples shown with each digit displayed are not preferable for me - too fast and not helpful.
surfwaxsmitty is offline   Reply With Quote
Old 04-20-2021, 02:58 PM   #80
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
The number on the GT86 speedo in the 0:41–0:43 part of the video increases by in +3 km/h increments (on average; there's one example of a +2, and one of +4), so clearly the rate of acceleration is not the limiting factor here.
At the same refresh rate the Ferrari would just be accelerating +5...+6 km/h per update.
Dadhawk (04-20-2021)
Old 04-20-2021, 06:19 PM   #81
p1l0t
p1l0t's Avatar
Yeah but are you accounting for the acceleration's effect on the electrons? It's the same effect as gravity...
The Following 4 Users Say Thank You to p1l0t For This Useful Post:
Dadhawk (04-20-2021), NoHaveMSG (04-20-2021), soundman98 (04-20-2021), timurrrr (04-20-2021)
Old 04-20-2021, 06:33 PM   #82
nextcar
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
I can't wait until we can actually see this car in person and test drive it so we can stop talking about the speedometer and move on to important subjects like whether or not you can see the brake pads, or possibly whether or not we should buy the automatic or manual transmission.
How I long for the carefree early days, giving advise on the senior prom...
Originally Posted by drewbot
Pull out
nextcar is offline   Reply With Quote
The Following 6 Users Say Thank You to nextcar For This Useful Post:
Dake (04-21-2021), NoHaveMSG (04-20-2021), p1l0t (04-20-2021), soundman98 (04-20-2021), Tcoat (04-29-2021), Transport3r (04-20-2021)
Old 04-20-2021, 06:57 PM   #83
JesseG
JesseG's Avatar
Drives: 2016 Scion FR-S
Originally Posted by chipmunk View Post
Can't remember if it was the LFA or Ferrari 458 (a few years ago), I remember hearing claims that they had to use a digital tach because the analog couldn't keep up with the RPM.
If you're not free-revving the engine with clutch pressed in, you should be fine.
It was the LFA, that V10 My favorite engine ever
JesseG is offline   Reply With Quote
Old 04-20-2021, 08:34 PM   #84
mazeroni
Drives: 2013 Scion FR-S Series 10
In a fast car, you want to see the numbers going fast because it highlights how quickly the car is building speed. If you were to do it both ways and market research it, I assume the fast numbers would be better received.
Additionally, on a track, you would want numbers to updated quickly so you can glance down at any time to know your precise speed. For normal drivers, they probably want less numbers flashing at them, especially after a work day.
For me, on the street, I feel like with 16 years of driving experience, I can accurately guess within ~5 mph of how fast I am going on a given street. So I only need to glance down to confirm the speed. I'm not watching the speedo or really even the tach; I rely on noise to tell me when to shift.
Also also also... The speedos we are watching have been recorded on camera running at a FPS @ 24/ 30/ 60 with who knows what shutter speeds and so>edited and rendered out that can affect how it looks>uploaded and converted to YouTube media file that further changes thing>then displayed on computer monitor.
mazeroni is offline   Reply With Quote
The Following 2 Users Say Thank You to mazeroni For This Useful Post:
Dadhawk (04-21-2021), timurrrr (04-20-2021)
In-dash digital speedometer vaer Electronics | Audio | NAV | Infotainment 4 04-14-2020 10:19 AM
Does the BRZ get same refresh? snezze21 BRZ First-Gen (2012+) — General Topics 74 03-24-2016 01:51 PM
Convert the digital speedometer from Kmh to MPH? Jastation Electronics | Audio | NAV | Infotainment 10 09-28-2015 05:46 AM
Digital speedometer in base GT86? rhysmcinerney Electronics | Audio | NAV | Infotainment 25 01-22-2014 06:18 PM
Fast car Fast driver vinyl decal I need help francosolracer Cosmetic Modification (Interior/Exterior/Lighting) 18 10-20-2012 03:43 AM
