Old 04-15-2021, 01:56 PM   #57
Lelandjt
Drives: '04 STi, '12 Mazda 3 Hatch
Originally Posted by sato View Post
As stE92ve mentioned, the Toyota release in Japan (and not referring to US specs) might be the reason. Most likely, additional US regulation added weight due to safety and/or emissions equipment on top of the BRZ Japan spec weight.
Sent from my Pixel 3 using Tapatalk
Good call. Probably lighter bumper beams at both ends.
Lelandjt is offline   Reply With Quote
Old 04-15-2021, 09:22 PM   #58
norcalpb
norcalpb's Avatar
Originally Posted by Blighty View Post
It was rated 197hp in all markets though right?
I believe they advertised as 200hp and 100hp/liter because it was 200 metric (ps) horsepower.
IMO the tiny difference is probably fuel related, and if you happened to add in some 100Ron fuel in the US model it might very well make 232hp
It was 197hp in all markets yes, but I think we all just subconsciously rounded up because 200hp was low enough.
Old 04-15-2021, 09:29 PM   #59
ZDan
ZDan's Avatar
Drives: '23 BRZ
Pre-release it was 197, but when it came to market in the U.S. it was definitely rated at 200hp here.
The Following 2 Users Say Thank You to ZDan For This Useful Post:
DarkSunrise (04-15-2021), timurrrr (04-15-2021)
Old 04-16-2021, 07:51 AM   #60
chipmunk
Drives: _
I'd be very interested in learning if this powertrain would be an easy swap into gen 1. I'm pretty sure, a couple of years down the line, someone will do it!
chipmunk is offline   Reply With Quote
Old 04-16-2021, 11:30 AM   #61
Jordanwolf
Rice King
Jordanwolf's Avatar
Many of these things are going to go to the junk yard because of accidents, so I'm sure someone will try eventually.
Glorious Honda.
Jordanwolf is offline   Reply With Quote
Old 04-16-2021, 01:46 PM   #62
Blighty
Drives: WR Blue Pearl 2022 Subaru BRZ
So weird.
Blighty is offline   Reply With Quote
Old 04-16-2021, 04:36 PM   #63
sato
sato's Avatar
Drives: Dodge Patitas
I'd do it. Might be a good refresh if one of our engines decide to pull a fast one. Then again, I'm not wishing that future 2022+ owners get rear ended or drift into a pole, u know, stuff like that.
sato is offline   Reply With Quote
Old 04-16-2021, 04:45 PM   #64
Jordanwolf
Rice King
Jordanwolf's Avatar
We know it's going to happen though. I'm suspecting this might actually be an expensive swap.
Glorious Honda.
Old 04-16-2021, 05:40 PM   #65
Transport3r
Drives: -
Second gen 86 to have 4 hp more than BRZ
Swapping a 17 engine in a 13 is already not trivial, the 2.4 swap will probably be more involved still. I’m thinking ECU mostly, not many modern cars tolerate having a foreign Ecu very well, it needs to play well with the other computers. Might be easier to swap the bottom end if the heads swap over.
Transport3r is offline   Reply With Quote
Old 04-16-2021, 08:32 PM   #66
Ohio Enthusiast
Drives: 2018 BRZ
Considering that the FA24D has a larger bore (86mm to 94mm) for the same stroke (86 mm), I don't see how the heads can be swapped. Had they increased the stroke while maintaining the bore, might have been possible.
Old 04-16-2021, 08:48 PM   #67
Transport3r
Drives: -
Wow. Yea. My brain was off apparently.
Old 04-19-2021, 09:04 AM   #68
chipmunk
Drives: _
I was thinking the whole powertrain & drivetrain, including electricals. If all the mounts are same, of can be easily modified using adapters, I don't see why not
Old 04-29-2021, 09:52 AM   #69
sato
sato's Avatar
Yeah, I also had that wishful thinking line but Subaru's design will not allow us to go K24 block/K20 head route like Honda fans can.
