Old 04-11-2021, 04:00 PM   #22975
coastwardpig
coastwardpig's Avatar
Drives: '19 86
Originally Posted by RToyo86 View Post
Spring maintenance day.
Changed the oil, touched up some stone chips, and Applied some DEI heat tape to the oil pan.
https://i.imgur.com/FHY1mUv.jpg
Spring cleaning day for me. Spent nearly 5 hours doing a thorough cleaning on the inside
coastwardpig is offline   Reply With Quote
The Following 2 Users Say Thank You to coastwardpig For This Useful Post:
ddevl_86 (04-12-2021), RToyo86 (04-11-2021)
Old 04-12-2021, 01:51 AM   #22976
jflogerzi
jflogerzi's Avatar
Oil Change plus swapped my track pads out and put street pads back in. Also managed to break my oil fill cap.... off to the stealship to get a replacement part.
2013 Series 10 FRS #553
Old 04-12-2021, 02:24 AM   #22977
Kittykate
Drives: 2015 FR-S
Gave her a nice wash.
Someone scraped up her bumper today just after that while I was working. The alarm goes off when I slam the gas cap too hard but if some asshole scrapes up my bumper? Nothing apparently.
I was debating wrapping the car this summer and now I think my decision is made.
Kittykate is offline   Reply With Quote
The Following User Says Thank You to Kittykate For This Useful Post:
Old 04-12-2021, 08:13 AM   #22978
FLIPDADY
FLIPDADY's Avatar
Drives: 2015 Subaru BRZ Sport Tech
Test fitted the Greddy front lip. Nice and tight fitment. Now onto the paint shop.
Sent from my LM-G900 using Tapatalk
FLIPDADY is offline   Reply With Quote
The Following 2 Users Say Thank You to FLIPDADY For This Useful Post:
ddevl_86 (04-12-2021), Lonewolf (04-12-2021)
Old 04-12-2021, 11:15 AM   #22979
lucky_666
lucky_666's Avatar
7 year suspension refresh
lucky_666 is offline   Reply With Quote
The Following 4 Users Say Thank You to lucky_666 For This Useful Post:
Lonewolf (04-12-2021), MJones_RB (04-12-2021), RToyo86 (04-12-2021), The Red One (04-12-2021)
Old 04-12-2021, 11:26 AM   #22980
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
A clean interior makes the car feel fresh again.
As much as I love detailing the exterior.. interior cleaning is a choir for me
Fortunately I have a friend who does offers detailing services and will do my interior and hit all the fabrics with a extractor. Those things work amazingly well.
RToyo86 is online now   Reply With Quote
The Following User Says Thank You to RToyo86 For This Useful Post:
Old 04-12-2021, 11:40 AM   #22981
coastwardpig
Drives: '19 86
Yep, it's definitely a choir. I use a carpet cleaner to clean all the fabrics.
I used to clean the interior of my car way more often but with age it's getting harder to find the motivation. But hey, at least I got a decent workout out of it; my back thigh muscles were sore the next day
Old 04-12-2021, 02:07 PM   #22982
DarkSunrise
DarkSunrise's Avatar
Changed the oil, touched up some stone chips, did a bolt check on the headers/OP and Applied some DEI heat tape to the oil pan.
Are you logging oil temps? Has it made a difference?
2022 BRZ Build
2013 FR-S Build
Old 04-12-2021, 02:33 PM   #22983
RToyo86
RToyo86's Avatar
I monitored it on my 30 minute drive yesterday with torque app and honestly could not tell the difference.
Temps peaked at 212F after a 2nd-3rd pull which falls into normal range.
Might make a difference under heavier load conditions with extended high rpm. Once I confirm my alignment isn't out of whack I'll be going on a nice mountain drive and see how it fares.
DarkSunrise (04-12-2021)
Old 04-12-2021, 03:56 PM   #22984
Grady
Grady's Avatar
Battery relocate
Sent from my ONEPLUS A5010 using Tapatalk
I hope you have some type of current protection close to the battery. Can not tell from the picture?
Old 04-12-2021, 06:07 PM   #22985
ddevl_86
theddevilinme
ddevl_86's Avatar
Drives: 2013 Scion FRS [H8R]
A checklist of items happened yesterday that Ive been wanting to do for months!
+ Brake calipers painted! (Finally the right temps out and a willingness to do it)
+ Coolant drained/replaced.
+ Sound Generator delete/Perrin inlet hose installed.
+ Drop-in high flow washable filter installed.
Amidst my troubles, I didnt get to install the drive belt [serpentine] or the new front cover spacer panel due to time restrictions and effort.
The Drive belt mostly cuz I was on 4 jackstands and didnt wanna break nothin while pulling on the tensioner. Unless Im totally stupid and wasnt really needing to "pull", since im not trying to remove the pulley like I originally thought I was doing...
But also, apparently the breaker bar I have has a 1/2" head and all my sockets use 1/4" ratchets. So I'll need to find a bigger 14mm to crank it.
Other than that, I "think' I noticed the cabin noise was gone from the sound generator delete. It definitely seemed quieter when revving the engine in Park to bleed the air from the coolant system.
However, I also noticed that the torque dip was incrementally worse with the new drop-in filter and Perrin inlet tube. I'll have to give it a test tomorrow or the next day on the road, but being in Park idling having the engine drop RPMS like that was scary. Definitely felt like it was gonna crap out a few times when barely giving the gas and letting off (~1500-2000rpm). I know for certain it wasnt THAT bad before... maybe once or so in a 6 rev process, but not EVERY time like now
Any thoughts/cures to idling drops?
Also, great story for anyone interested in painting their brake calipers. I used the G2 Paint kit, and it was perfect for the application of the stock brakes. HOWEVER....
Dont ever listen to your wife when telliing you not to use a plastic container that you know would work great, and instead opting to use a red solo cup for the work.
Not only do you lose an hour or two for cleaning up, and also need to have correct solvents for cleaning, but you lose all the paint as it drips helplessly onto everything and anything around you. Then you yell and bitch about it all happening when it shouldnt have. So the lesson learned here is DONT USE SHITTY CONTAINERS FOR CHEMICALS as they tend to melt and cause further issues lmao
We're all just living to die - might as well enjoy the ride!
ddevl_86 is offline   Reply With Quote
The Following 3 Users Say Thank You to ddevl_86 For This Useful Post:
FLIPDADY (04-23-2021), jflogerzi (04-13-2021), MJones_RB (04-13-2021)
Old 04-13-2021, 12:58 PM   #22986
jflogerzi
jflogerzi's Avatar
How the hell did you get so much paint on your hands..... Gloves?
The Following User Says Thank You to jflogerzi For This Useful Post:
RToyo86 (04-13-2021)
Old 04-13-2021, 02:24 PM   #22987
ddevl_86
theddevilinme
ddevl_86's Avatar
Great question gets great answers.
...use a red solo cup for the work.
I blame my wife. But ultimately it was my mistake for even wanting to split the paint for reserving some incase I needed touchups in the next year or two...
I didnt wear gloves cuz it wasnt supposed to be anywhere other than the calipers lol
The Following User Says Thank You to ddevl_86 For This Useful Post:
Old 04-13-2021, 06:25 PM   #22988
Ashikabi
Ashikabi's Avatar
Marine breaker in the top left corner
