Old 04-12-2021, 01:13 PM   #715
Can you swing it around?
The pieces fit very tightly together (better than Legos IMO), so probably as long as you don't hit anything you could. The tip pieces would most likely fly off on contact.
I think it also needs some internal lighting, but I'm not that ambitious.
They provide a handy-dandy prying tool to get them apart and to set them which is nice.
Spuds (04-12-2021)
Old 04-12-2021, 01:17 PM   #716
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Ok, that tool is really cool. Would have been great to have back in the day...
The Following User Says Thank You to Spuds For This Useful Post:
Dadhawk (04-12-2021)
Old 04-12-2021, 01:51 PM   #717
Thinking this is my next project.
Pretty amazing you have a photo of the actual plane that appears on the box.
Old 04-12-2021, 02:01 PM   #718
It was a very famous aircraft flown by an ace.
He crashed it landing in front of the press that were there since he (and the aircraft) was set to rotate back to the US for a bond tour. He wasn't hurt but it means there are a pile of pictures of the crashed plane.
Between the preflight press pictures and the crashed pictures it is probably one of the best documented aircraft in WW2. There are dozens.
Dadhawk (04-12-2021), JD001 (04-12-2021), NoHaveMSG (04-12-2021), soundman98 (04-12-2021), Spuds (04-12-2021), Ultramaroon (04-12-2021)
Old 04-12-2021, 02:32 PM   #719
Oops.
Also... I apologize if this is a repost but man, what a priceless gift!
Old 04-12-2021, 02:38 PM   #720
Oops.
Wait until you see my simulated spinning prop!
Dadhawk (04-12-2021), Spuds (04-12-2021), Ultramaroon (04-12-2021)
Old 04-12-2021, 03:06 PM   #721
JD001
JD001's Avatar
Drives: Subaru BRZ
How do you allow for colour correction? I note the nosecone is doing a "Hakone"...
Old 04-12-2021, 05:59 PM   #722
Mostly I go by a "that looks close enough" approach. Sometimes there are clues that can be used to figure things out even in black and white picture.
I presume you mostly noticed the reds in the two pictures are radically different. In that case I would say that neither is accurate. These aircraft flew out of Briton and mostly used the RAF paints to customize since they didn't have much beyond their standard US basic camo paints. That means the nose cone, checkerboard and wheels were probably done in RAF insignia red from the roundels.
So this is the red I would go with:
The purists insist on using only military issued specific numbered colours for aircraft but I do not like that idea. Colours varied (there are at least 60 different shades of "olive drab") and unless you are doing a brand new piece of equipment from a know manufacturer in a given moment of time the numbered colours mean little. Add into that the fact that when you shrink something down the full size colour may look way off in scale. Dirt, wear and lightig also come into play and will change the official colour.
The aircraft that Ultra served in is a great example. The colour in the picture he sent me (yes there is a young Ultramaroon there) doesn't look anything like what I thought would be ore accurate in small scale. The aircraft was also obviously scrubbed really clean for the photoshoot and it need some darkening up and grunge since that is how it would be day to day.
He says I called it but may just have been being polite.
So all in all unless there is somebody that actually flew, drove or serviced equipment to tell me I am wrong I just paint it my best guess.
JD001 (04-13-2021), Spuds (04-13-2021)
Old 04-12-2021, 06:13 PM   #723
Your tax dollars hard at work. Anyone care to guess how many cans of this stuff we used in the absence of fresh water? It makes for a great instant detail spray.
soundman98 (04-13-2021), Spuds (04-13-2021), Tcoat (04-12-2021)
Old 04-13-2021, 02:30 PM   #724
That is probably around .001% of the list!
Also birdcage but won't need to quite as perfect as some.
It is costing me a fortune to keep you guys entertained!
Dadhawk (04-13-2021), JD001 (04-13-2021), Kaotic Lazagna (04-13-2021), soundman98 (04-13-2021), Spuds (04-13-2021)
Old 04-13-2021, 02:39 PM   #725
Kaotic Lazagna
Drives: GR Corolla
The Following 2 Users Say Thank You to Kaotic Lazagna For This Useful Post:
soundman98 (04-13-2021), Tcoat (04-13-2021)
Old 04-13-2021, 02:44 PM   #726
JD001
JD001's Avatar
Drives: Subaru BRZ
What are you saying? We are worth it and you know it.
The Following 3 Users Say Thank You to JD001 For This Useful Post:
Dadhawk (04-13-2021), Kaotic Lazagna (04-13-2021), Tcoat (04-13-2021)
Old 04-13-2021, 03:09 PM   #727
Well better than those snobs over on Britmodeler!
Really they aren't snobs at all and I quite enjoy it over there even if most are in the UK.
JD001 (04-13-2021), Ultramaroon (04-14-2021)
Old 04-13-2021, 06:15 PM   #728
Yeah, but with the exchange rate, it's a bargain.
TRD ABS Plastic Kit? Shims Cosmetic Modification (Interior/Exterior/Lighting) 5 07-19-2015 07:31 PM
Front lip - abs plastic _frs Want-To-Buy Requests 0 09-21-2014 11:11 AM
Trade my black dash plastic for your silver dash plastic thread. F3dzo Southeast 0 07-17-2012 10:06 PM
plastic interior lancie Scion FR-S / Toyota 86 GT86 General Forum 34 10-16-2011 01:02 PM
