Old 04-12-2021, 06:32 AM   #2031
tomm.brz
Drives: brz 2017 hksv2
try to flash his -2% tune
and reduce adv timing because they are too high
Old 04-12-2021, 06:42 AM   #2032
73TORANA!
Drives: Orange GTS
Thx for that. What are you thoughts on the Eng load @ 3800, as I will still get a rich dip at 3800rpm?
73TORANA! is offline   Reply With Quote
Old 04-12-2021, 07:19 AM   #2033
tomm.brz
first try the -2%, then if in the torque dip is still rich, you can try lowering engine load limits (which will be healthy since the -2% will have a bit lower engine load overall)
You can try fix it also rescaling the maf in open loop a bit better
and to make it leaner through the table "Engine load compensation (MP)" in that range (lower values to make it leaner)
Reduce PI% at high rpm or lower adv timing or will be even more knocky
you could keep this richer tune and just remove timing where it knocks, no big difference.. i had just a quick look at the logs when i first answered,
but the -2% worth a try to me
Old 04-12-2021, 07:32 AM   #2034
73TORANA!
Drives: Orange GTS
Thx for in depth reply. Will try 2% and put a few tanks of gas through it and log again. Then try what you advise before making too many changes at once. Im still learning. Thx for your help. Cheers
Old 04-26-2021, 03:26 PM   #2035
Silver49
Drives: 2013 FRS
I could really use some help. I feel the car is running way too rich. I changed to the stage 2+ 4.03 tune, from the 4.02. I ran a data log on the highway with 3rd gear pulls on the onramps. Could someone take a look? I feel like the front pipe cat is getting really hot, from the smell of it. The car has a an uncatted UEL header and a Perrin intake, both were on there when I bought the car. I want to be on the track next weekend, but I don't think the current fuel mappings are going to work.
https://drive.google.com/file/d/1ukM...ew?usp=sharing
https://datazap.me/u/derekbarker3gma...y?log=0&data=1
Silver49 is offline   Reply With Quote
Old 04-26-2021, 08:40 PM   #2036
tomm.brz
please upload to datazap.me and link here ..
Old 04-26-2021, 10:42 PM   #2037
Silver49
Drives: 2013 FRS
I updated my post to include it now.
Thanks
Old 04-26-2021, 11:43 PM   #2038
tomm.brz
yes quite rich
a maf rescaling would help
Old 04-27-2021, 09:36 AM   #2039
Silver49
Drives: 2013 FRS
yes quite rich
So on that note, I believe my car came with both the 2.75" and 3" Perrin. Or does the size just relate to the silicone part of the intake tube? I added a picture as well. Again any help would be awesome since I didn't buy these parts. Assuming it is both, would I just use the 3" MAF scaling tables or is there a different one since it is both parts.
https://photos.app.goo.gl/dSfCbhmBaUhd1i3f8
Old 04-27-2021, 10:10 AM   #2040
tomm.brz
i don't know of which scaling you re referring to.
I only do custom tune or nothing, if you want help with it i can help you
That intake definitely requires it if you want it to run smooth like with stock intake
If you want to do by yourself with romraider, there is a maf scaling guide complete with a maf rescaling tool in the Tuning section
Old 04-27-2021, 07:21 PM   #2041
Silver49
Drives: 2013 FRS
I updated the MAP scaling with the tables Perrin claims should be used. I believe it is someone better. I think it is still on the rich side from this new data log. I am assuming I need to do the whole MAP scaling process, that the Perrin table amounts are just not good enough. Thank you for any insight.
https://datazap.me/u/derekbarker3gma...p?log=0&data=1
Old 04-28-2021, 05:26 AM   #2042
tomm.brz
MAF
not MAP
and yes, you assume right
Old 04-30-2021, 02:39 PM   #2043
Silver49
Drives: 2013 FRS
I tried scaling the MAF and took this log with a mix of city and highway driving with a 3rd gear pull on the highway. Can someone take a look and let me know if this is good. I believe it is significantly better than the Perrin MAF scaling tables. Any advice would be awesome. My plan is to have the car back on the track next Friday. Thanks
https://datazap.me/u/derekbarker3gma...=1-2-4-8-10-13
Old 04-30-2021, 10:35 PM   #2044
tomm.brz
better, yes
rise a bit the value on the maf around 3.7V
you should take also a log of a third gear pull full throttle from 2000 to redline
RGM Supercharged 86 performance data TheGooseman AFRICA 14 12-13-2014 02:15 AM
Interpreting Ecutek Data Logs? cuddefred Software Tuning 3 09-02-2013 01:55 PM
VIR - Impressions/Pics/Logs/Video (Track Daze) swift996 Tracking / Autocross / HPDE / Drifting 39 08-30-2013 10:21 AM
Noise tube delete air/fuel logs? jm1681 Engine, Exhaust, Transmission 13 10-17-2012 05:57 PM
ECU Data Logger Motordyne Engine, Exhaust, Transmission 5 07-18-2012 10:27 AM
