Old 04-09-2021, 12:16 AM   #1
scion fr-s
scion fr-s's Avatar
Drives: 2017 PP BRZ
Belt Walking
Hello. I have belt movement. I replaced the two idler pulleys and the accessory pulley. I also replaced the tensioner pulley and brand new OEM belt. I still have belt movement. My next guess is replacing the alternator pulley. What I mean, is my belt walks side to side. Feel free to chime in. Maybe it is time to find a shop. ARG!!! TIA.
scion fr-s is offline   Reply With Quote
Old 04-09-2021, 12:18 AM   #2
Turdinator
Señor Member
Turdinator's Avatar
Does it jump a groove in the grooved pullies?
1974 TA22 Celica
2013 86 GT
Old 04-09-2021, 01:31 AM   #3
Do you have a supercharger?
Old 04-09-2021, 02:52 AM   #4
scion fr-s
scion fr-s's Avatar
Drives: 2017 PP BRZ
Forgot to mention that I put on a new belt and noticed the edges were starting to tear from the movement of the belt. I am starting to guess that my pulleys are not balanced, causing the belt to walk. No noticeable belt movement on the grooved pulleys. I notice belt movement on the tensioner pulley and idler pulleys since I have to readjust the belt before starting the car. I need to make a video and I am NA with bolt-ons. This is weird because when I had my FRS, I had no belt issues or movement. Freakin BRZ.
Old 04-09-2021, 03:05 AM   #5
Project_1796
Drives: Scion FRS 10 series
Did you check the crankshaft harmonic balancer? is it OEM or aftermarket?
Project_1796 is offline   Reply With Quote
Old 04-09-2021, 03:06 AM   #6
soundman98
ProCrastinationConsultant
soundman98's Avatar
There's 3 idler pully's, though it sounds like something else is not aligned correctly. Have you tried watching it on startup to see where it's jumping?
Bonburner (04-17-2023)
Old 04-09-2021, 03:29 AM   #7
scion fr-s
scion fr-s's Avatar
Drives: 2017 PP BRZ
I have not and an OEM crank pulley.
Old 04-09-2021, 03:29 AM   #8
scion fr-s
scion fr-s's Avatar
Drives: 2017 PP BRZ
I called letter G an accessory pulley LOL.
Old 04-09-2021, 06:53 AM   #9
Ashikabi
Ashikabi's Avatar
Bad bearing somewhere?
Sent from my ONEPLUS A5010 using Tapatalk
Old 04-09-2021, 06:58 AM   #10
When you say you replaced the pulleys were the new ones stock or aftermarket?
Not sure from your wording but did you have movement before changing the pulleys?
Old 04-09-2021, 10:52 AM   #11
Lantanafrs2
Drives: 2013 frs red
Sounds like a pulley isn't seated right
Lantanafrs2 is offline   Reply With Quote
Old 04-09-2021, 01:32 PM   #12
scion fr-s
scion fr-s's Avatar
Drives: 2017 PP BRZ
The new pulleys were OEM Subaru. The old pulleys showed signs of wear which is why I replaced them and yes I had belt movement before changing the pulleys.
The Following User Says Thank You to scion fr-s For This Useful Post:
Tcoat (04-09-2021)
Old 04-09-2021, 09:58 PM   #13
scion fr-s
scion fr-s's Avatar
Drives: 2017 PP BRZ
Thoughts?
Old 04-09-2021, 09:59 PM   #14
soundman98
soundman98's Avatar
so it's not jumping teeth side-to-side, but is moving? should be able to see it attempting to move one place more than another.
The Walking Dead MrAnthonyC Off-Topic Lounge [WARNING: NO POLITICS] 338 04-07-2016 01:45 AM
SOS. Monterey area. Belt tensioner/belt The Racers Line Northern California 11 04-06-2015 02:33 PM
The Walking Dead RAP ThreeZzZ Off-Topic Lounge [WARNING: NO POLITICS] 1 01-12-2015 05:43 PM
The Walking Dead DIM Off-Topic Lounge [WARNING: NO POLITICS] 286 11-02-2014 11:19 PM
No Walking Dead Thread? (Spoiler Warning) Tujin Off-Topic Lounge [WARNING: NO POLITICS] 2 10-16-2012 05:57 AM
