Old 04-06-2021, 09:14 PM   #1
4n0m41y
Time for exhaust...What all do I need?
Been driving a bone stock 2013 frs for the past 8 years. Think it's finally time for exhaust. From my research to do the full setup I'll need my header of choice, over pipe, mid pipe, and catback. Is that correct or did I miss something? Also, as far as gaskets go, am I safe to assume that they will be included with the various components or will I need to purchase separately?
I'll be taking this to a buddy's house ~150miles away to do on a Saturday and can't afford to not have everything I need to do it in one go on hand. Have to throw it up on jackstands, replace everything, drop it, and drive it back home same day.
4n0m41y is offline   Reply With Quote
Old 04-06-2021, 09:31 PM   #2
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
If this is for power, everything listed and a tune.
Tune is mandatory if going catless.
If you are looking for just noise, just get an axleback.
The Following User Says Thank You to x808drifter For This Useful Post:
Tcoat (04-13-2021)
Old 04-06-2021, 09:31 PM   #3
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
I'd highly recommend starting with replacing one piece and going from there. Sound is very subjective and things like drone can be very unpleasant and unpredictable. if you replace the whole thing all at once, and you don't like it, you won't be able to figure out what to change.
What are you after? sound? just do a catback first.
Power? start with header+tune. or better yet, keep the stock header and get an E85 tune.
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
BrahmaBull1990 (04-07-2021)
Old 04-06-2021, 10:09 PM   #4
jflogerzi
jflogerzi's Avatar
Focus on header and OFT Tune and add an axle back and be done. Don't mess with the FP or OP.
Few good header options are for more Rumble
Tomei UEL Header catless
JDL UEL Header catless
Gruppe-S UEL Catless
FT-86 SPEEDFACTORY BRONZE CERAMIC COATED CATTED UEL HEADER in stock
EL Options:
Ace 350
JDL 4-2-1
Axleback
REMARK MUFFLER DELETE Dual Wall tips with SS or TI burnt tips
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
Old 04-06-2021, 11:56 PM   #5
4n0m41y
Appreciate the replies! This is primarily to remove the torque dip. I purposefully left the car un-modded all these years because I was coming off of a dsm addiction and knew that the moment I started upgrading I wouldn't stop. However I recently grabbed an OFT and flashed the stage 1 tune and after feeling the difference that made...now I want more.
I could care less about the sound, but just figured if I was going through the hassle of doing a header I might as well do the whole thing, but maybe I will just do the header first and go from there. With that being said I've looked at the JDL UEL and ACE 350, however considering the price of the ACE I'll probably go with the JDL.
Is there really much more to be gained by doing the rest of the exhaust, other than just sound?
Old 04-07-2021, 12:45 AM   #6
Purist
Purist's Avatar
Drives: Subaru BRZ
If it's for power, catless headers and overpipe. Cat back does nothing, axleback does nothing. Research further for details.
Sent from my SM-G973F using Tapatalk
Less More
Purist is offline   Reply With Quote
Old 04-07-2021, 05:22 PM   #7
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
As others have stated, headers first and possibly a catback/axleback and a tune. Figure out your budget and allocate for all of that.
Then it comes down to, are you an EL or UEL kind of guy?
Here's my recommendation:
ACE A350
FlexFuel kit
Catback *your choice*
Tune from Zach @ CSG.
That's basically my set up and I love it!
MS, CSCS, TSAC-F, CPT
weederr33 is online now   Reply With Quote
The Following User Says Thank You to weederr33 For This Useful Post:
Plumbus (04-16-2021)
Old 04-07-2021, 06:10 PM   #8
KMA KiCKz
Certified Wumbologist
KMA KiCKz's Avatar
Drives: 2015 Scion FR-S
Like many have stated, would definitely start with a catless header and a tune to get the most "gains"; perhaps even get an axleback/catback to clear the "tone" a bit.
Personally, I've upgraded each exhaust component separately overtime because I was doing research on which parts fit my budget and what appealed to me.
Since you are doing it all in one go, definitely do some research on your ideal setup:
- How much are you willing to spend?
- How loud do you want your racecar to be?
- Will the drone be a problem?
I recommend keeping at least one cat/resonator to lessen drone.
Try looking through the used market to save some money. The cheddar saved could be used on buying new gaskets.
Good luck on your search!
- My 2015 Scion FR-S OEM+ Build Thread -
TRD | Brembo | RAYS
Last edited by KMA KiCKz; 04-07-2021 at 06:11 PM. Reason: Spelling error oopsies ¯\_(ツ)_/¯
KMA KiCKz is offline   Reply With Quote
The Following User Says Thank You to KMA KiCKz For This Useful Post:
Old 04-07-2021, 10:20 PM   #9
BrahmaBull1990
Howdy
BrahmaBull1990's Avatar
Drives: 2020 BRZ PP
I concur
First I did an UEL header and the rest stock, nice rumble and louder. Then did the catback and it’s much louder. If I removed the stock overpipe and the cat with it, it would be unbearable
A stage 2 tune will be required no matter what, IMO
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
BrahmaBull1990 is offline   Reply With Quote
Old 04-08-2021, 12:12 AM   #10
x808drifter
LMGTFY
I guess I need to clarify...
OP if you are trying to make ALL the power.
Catted Header OP/FP and a tune. No catback. Maybe an axleback but that's not for power. (Custom tune for most power, OTS will get you 90&ish there)
OP lives in a state with emissions, and I feel telling people to do illegal shit to their car is a bad idea since removing the cat on a street driving car is illegal in the USA not just their state. The tune might make you fail. But flashing to stock is easy.
But if your goal is just noise, save the money and get an axleback and go from there.
Tcoat (04-13-2021)
Old 04-13-2021, 12:14 PM   #11
cmiovino
cmiovino's Avatar
Drives: 2017 BRZ PP, 2004 WRX
IMO, the overpipe and front pipe are not cost effective for making power. They certainly add some, but not enough to really justify the cost unless you're chasing lap times. Of course, if you have the money and/or want to tweak the sound some, replace these to achieve your goals. They wouldn't be first on my list however.
If it's me, I'm certainly going with a header and tune, plus a catback/axleback of your choice to amplify the sound.
cmiovino is offline   Reply With Quote
The Following User Says Thank You to cmiovino For This Useful Post:
Tcoat (04-13-2021)
Old 04-13-2021, 12:58 PM   #12
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Most OP are overpriced for what they are.
I ended up getting the gruppe-s OP seperately from FT86MS for $200CAD. I believe it's a $100 add on when you buy it with the header. Definitely the best bang for buck combo on the platform. FT86MS also list some off brand OP for $100. I saw it in person and it's POS.
I have the header and OP with everything else stock. Pulls strong. Catback is noise. Pretty limited options if you are picky with not going to loud.
Old 04-13-2021, 02:41 PM   #13
therealstoly
therealstoly's Avatar
Drives: 2020 BRZ Limited
8 years old + Missouri + unknown mileage + 150 mile drive each way = All of it?
Missouri isn't the driest of states, mileage is unknown, and the general rule-of-thumb is 10 years/100K miles for a cat.
+1 on a tune being required sooner rather than later post installation.
If you can, I'd replace everything from stem to stern and be done with it for another eight years. Once you've picked out the exhaust system you like, here are few additional things I'd recommend you have on-hand to increase your odds for a same day turnaround on top of 300 miles of driving -
- New header gaskets
- New header bolts
- Spare exhaust gaskets
- Spare exhaust bolts
- New exhaust hangers (there are 5 of them)
- Penetrating oil
Most of the exhaust components come with hardware but there is nothing worse than having the car up on stands and accidently crease a gasket and not have another one handy. You'll probably end up with some spare bits and pieces but better that than the alternative.
If you've ever thought about motor mounts, this would be the time to do it. With the header out they are a quick and easy swap.
After lots of reading reviews and YouTube videos, the combo I liked most -
- FT86 UEL catted header because SMOG
- Private Label over pipe from Rally Sport Direct + the above new/spare gaskets.
- I was at about 6000 miles when I swapped and didn't replace the front pipe although I would have if it was 8 years old.
- Perrin 2.5" resonated catback
- Even with 6000 miles I had the above spares on hand just in case...
- OFT for tune.
Just passed Nevada SMOG with the tune loaded and without issue.
therealstoly is offline   Reply With Quote
Old 04-13-2021, 02:49 PM   #14
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Fuck PLM and their copying of other small companies parts.
Perrin Catback Exhaust Group Buy!! Limited Time Offer!! Mike@CZP Groupbuys 1852 06-05-2018 05:37 AM
Exhaust bolts working off over time? frosty288 Engine, Exhaust, Transmission 4 09-28-2015 11:55 AM
full exhaust with e85.. Will that damage anything over time? Anthony7515 Engine, Exhaust, Transmission 8 04-23-2014 10:00 AM
Tax return time = WHEEL CLEARANCE TIME from Gram Lights and Yokohama vividracing Wheels and Tires 4 04-04-2014 03:46 PM
