Old 04-06-2021, 02:44 PM   #76735
BrettRS
BrettRS's Avatar
Drives: 2016 Ford Focus RS
EPS issues like this are not common and typically require techstream to help diagnose effectively and efficiently since the steering is run by the steering ecu and TC ecu. Even out of the guys that work on their own cars, not many have techstream. That is also why you are seeing no codes on an OBD2 reader.
Do you know if I'll need a new/matching column ECU (like this listing shows: https://www.ebay.com/itm/2013-SUBARU...0AAOSwgn5fQB7p ) or if just replacing the EPS motor alone will not cause any further issues?
2016 Ford Focus RS (Nitrous Blue) Hatchback
2013 Subaru BRZ Coupe
2003 Ford E250 Cargo Van
1996 Mazda B4000 Pick-Up Truck
1987 Bertone X1/9 Convertible
BrettRS is offline
Old 04-06-2021, 03:25 PM   #76736
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I am not sure. I do know that you have to do some calibrations in techstream, it is not a straight forward replacement. At minimum you will have to do a clockspring calibration if you are swapping the whole column. Without reading through the procedure not a whole lot more I can say about it. Sorry man, kind of a shitty deal.
NoHaveMSG is offline
BrettRS (04-06-2021)
Old 04-06-2021, 04:32 PM   #76737
BrettRS
BrettRS's Avatar
Thanks, I spoke with the dealer, they didn't think I would need the column ecu and the sensor they mentioned needs replaced as well is within the EPS motor, so I really just need the motor.
I mentioned getting it calibrated with their techstream after I installed it and he said that would need to be done for sure, but he's hopeful that with a replacement EPS motor by me and a recalibration at their place afterwards, we might be able to get it resolved without the entire steering column replacement.
Sent from my SM-G998U using Tapatalk
BrettRS is offline
The Following User Says Thank You to BrettRS For This Useful Post:
NoHaveMSG (04-06-2021)
Old 04-06-2021, 04:56 PM   #76738
A quick look at the repair manual shows reams and reams of possible failure modes! I think there may be more than the whole engine. You are sure it is the motor? The failsafe lists 29 codes alone and not one of them are for an actual assist motor failure.
https://demos.starbase7.net/t3Portal..._rm_index.html
Tcoat is offline
BrettRS (04-06-2021), Spuds (04-06-2021)
Old 04-06-2021, 06:15 PM   #76739
BrettRS
BrettRS's Avatar
I am sure of nothing, unfortunately. Dealer said EPS motor and integrated sensor, they could only order EPS motor with new steering column so they couldn't replace motor only. Cost would be $1500+.
Motor is $80 and 2 hours for me to replace at home, so my thought is try that first and take it back for them to recalibrate with techstream. If that doesn't work, back to the drawing board.
I posted a screenshot of their diagnostics on my troubleshooting thread if there might be more info in there that I'm missing.
BrettRS is offline
Spuds (04-06-2021)
Old 04-06-2021, 06:18 PM   #76740
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Customer:
calls, does not leave message
Calls again, does not leave message
CALLS AGAIN, DOES NOT LEAVE MESSAGE
CALLS AGAIN, LEAVES 1 SEC VOICEMAIL
The Following 4 Users Say Thank You to NoHaveMSG For This Useful Post:
p1l0t (04-07-2021), soundman98 (04-07-2021), spike021 (04-06-2021), Ultramaroon (04-06-2021)
Old 04-06-2021, 06:37 PM   #76741
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Any one of you remember which 3M double sided tape was the permanent or hella strong tape? My side skirts are coming off and need to tape em back up w better 3M tape
ichitaka05 is offline
Old 04-06-2021, 06:44 PM   #76742
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
3M Hella Strong Tape is the brand you're looking for
MS, CSCS, TSAC-F, CPT
weederr33 is offline
The Following 3 Users Say Thank You to weederr33 For This Useful Post:
ichitaka05 (04-06-2021), NoHaveMSG (04-06-2021), spike021 (04-06-2021)
Old 04-06-2021, 06:53 PM   #76743
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
3m VHB. Also use adhesion promotor for best application.
https://www.amazon.com/3M-Adhesion-P...7749615&sr=8-3
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
ichitaka05 (04-06-2021), soundman98 (04-07-2021)
Old 04-06-2021, 07:03 PM   #76744
Maybe not many people here work on their own cars or maybe the ones that do don't actively monitor the forums. I'm just hoping to get some help from someone that has a bit more knowledge than me, so I can make an informed decision on whether to get the car back from the dealer and attempt the EPS motor replacement alone, or if I need to pony up the $1500 and get a new steering column. If my faux pas ends up saving me a grand, sorry for clogging up your thread, but I'll be happy that someone saw it and helped me who might not have otherwise, because I am struggling to get any responses or suggestions in my troubleshooting thread.
FWIW, I think posting in this thread was a pro move. We're the daily crowd and many of us work on our own stuff. Some of us do so exclusively.
That being said, I am at work now. I did see your thread and planned on digging a bit but it looks like @Tcoat beat me to delivering the bitter reality. Your dealer probably just fired up techstream against it and pulled those specific indicators. A compound failure is rare. If I was to believe the dealer's diagnosis, personally, I would dig further into the servo system looking for an intermittent open. Closed-loop servo systems can be notoriously difficult to troubleshoot but one might get lucky finding an intermittent loose connector.
Your choice is to either have the dealer do the work, or snag a copy of techstream and try swapping/calibrating a known good drive unit. This is one of those "if you have to ask..." situations.
edit: I don't think it's the motor. That's usually a hard failure.
Ultramaroon is offline
BrettRS (04-06-2021), NoHaveMSG (04-06-2021), Spuds (04-06-2021)
Old 04-06-2021, 07:09 PM   #76745
spike021
spike021's Avatar
Anyone here ever buy a chair like this: https://www.amazon.com/dp/B07G95568C
Thinking of grabbing one for the balcony at my new apartment. I wouldn't be using it for camping.
Instagram: @spike.grc
spike021 is offline
Old 04-06-2021, 07:36 PM   #76746
ichitaka05
Site Moderator
ichitaka05's Avatar
Didn't find HELLA strong tape, but did find Super Strength Molding tape & Heavy Duty tape
Old 04-06-2021, 07:39 PM   #76747
I highly doubt it is the motor as well. As you said they usually work or they don't there is rarely an in between. I knew it was well above my pay grade when I looked up the codes and the page just kept scrolling and scrolling with different sensor, relay and things I don't even know what they are failures!
The last time I "calibrated" a steering rack it involved a torch and a large ballpeen hammer.
I knew the steering was electric assist but damn I had no idea how much data it's control unit was dealing with.
Tcoat is offline
Old 04-06-2021, 07:53 PM   #76748
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
This is on my short list to purchase. All the ones on ebay look like they are going to also have a bootleg copy of the new godzilla v. kong movie on them too.
Spuds (04-06-2021)
