Old 04-02-2021, 09:54 PM   #76693
soundman98
ProCrastinationConsultant
soundman98's Avatar
just added some undercabinet lights to a customers kitchen where i had to drill a hole on each side of that space and fish the wire through using a small camera.
that would've ended with a call to the coroners and a new kitchen...
soundman98 is offline
Spuds (04-02-2021)
Old 04-02-2021, 10:32 PM   #76694
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
My dad's truck just bit me again. Rear end went, 3k. I sure wish I had kept my Honda for my son instead.
Sapphireho is offline
Old 04-02-2021, 11:25 PM   #76695
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
I heard there is a place in TX that will convert any new automatic toaster to a manual, but you have to supply a doner manual toaster and 75 bucks.
Why am I not surprised. Somewhere around here is a guy who is working on a conversion to put a PowerGlide automatic into a C8 Vette.
Slow is smooth, and smooth is fast
Capt Spaulding is offline
The Following User Says Thank You to Capt Spaulding For This Useful Post:
soundman98 (04-03-2021)
Old 04-02-2021, 11:31 PM   #76696
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
That is not too surprising, Powerglides are popular for the drag racing crowd.
These guys do manual conversions on exotics and the Zupra.
https://www.gatedsix.com/forsale
I watched some videos on some of the conversions they did a while back. Insanely expensive. I think it was something like 75-80k+ for the 430 Scud.
NoHaveMSG is offline
Capt Spaulding (04-02-2021)
Old 04-02-2021, 11:34 PM   #76697
Sapphireho
Famous Potatoes
Sapphireho's Avatar
I couldn't imagine putting that much into a toaster.
NoHaveMSG (04-03-2021), soundman98 (04-03-2021)
Old 04-03-2021, 02:21 AM   #76698
On all the motor controllers in my industry there is a fail safe on the throttle input that will open the connection to the contactor to cut power. I haven't had a fail closed incident in the field that caused one to go run-away yet. I am sure it is not 100%. Hell we had an issue years back where plugging in the charger with the unit on and then pressing the brake and throttle would put it in reverse. So I am sure it is not outside of the realm of possibility with our setup.
Here is one of the linear actuators that we use from Sevcon that I opened up for that one project I did . The controller needs to see a closed input from this microswitch before it receives a throttle signal.
Ah, I see. Makes it considerably less scary.
Ultramaroon is offline
Old 04-03-2021, 10:07 AM   #76699
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
AFAIK it has only been there shop Zupra which has had 3-4 different looks. It is around 10k in labor.
Kiske is offline
The Following User Says Thank You to Kiske For This Useful Post:
Old 04-03-2021, 02:40 PM   #76700
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
I am far less motivated to wash, detail, and do maintenance on my car this spring... I think it has something to do with the gen2 question. Or maybe it is because I drive it less? Or perhaps I am getting bored of it? This is troubling.
Spuds is offline
humfrz (04-04-2021), spike021 (04-03-2021)
Old 04-03-2021, 05:12 PM   #76701
soundman98
soundman98's Avatar
i'm less motivated because my couch is more comfortable.
The Following 4 Users Say Thank You to soundman98 For This Useful Post:
NoHaveMSG (04-04-2021), spike021 (04-03-2021), Spuds (04-03-2021), Ultramaroon (04-03-2021)
Old 04-03-2021, 05:43 PM   #76702
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Captain Snooze is offline
The Following 7 Users Say Thank You to Captain Snooze For This Useful Post:
MICHAEL450f (04-03-2021), NoHaveMSG (04-03-2021), Sapphireho (04-03-2021), soundman98 (04-03-2021), spike021 (04-03-2021), Spuds (04-03-2021), Ultramaroon (04-03-2021)
Old 04-04-2021, 02:06 AM   #76703
soundman98
soundman98's Avatar
so my dad found one of these altec lansing bluetooth speakers in the garbage a while back. something went wrong with the all-in-one charging/amplifier circuit board.
so i'm gutting the altec electronics and installing my own.
had to fire up my adjustable power supply that i haven't touched in close to 10 years to fine tune the battery level display i'm installing.
10 seconds after powering it up, even before i can dial in the settings i need, it goes POP, and all the magic smoke comes out. i think, hmm, sounded like a capacitor...
i loled when i opened the case and found this. a capacitor attempted to enter orbit, but was blocked by the central chassis support. probably would've dented the thin case if it was anywhere else..
so now i'm out a power supply...
MICHAEL450f (04-04-2021), NoHaveMSG (04-04-2021), spike021 (04-04-2021), Ultramaroon (04-04-2021)
Old 04-04-2021, 02:11 AM   #76704
Doh! I bet if you just replace that shorted cap, you'll be good to go. Check the rectifier diodes but usually they go up in smoke when they short.
Old 04-04-2021, 02:54 AM   #76705
soundman98
soundman98's Avatar
yeah, i've got some replacement caps on the way. i have 3 big drawers of random capacitors for exactly this reason, but none in this size/rating of course--almost tried a 25v where this was a 35v, but not worth the risk. problem is there was a TON of smoke that came out--like a blown copper winding smoke. caps don't usually smoke when they pop in my past experience. i'm thinking something else went in the process--when it popped, the display cut off like i popped a fuse, but the normal serviceable fuse is still intact.
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
Old 04-04-2021, 02:59 AM   #76706
How about because you are getting older and lazier -
humfrz is offline
The Following 4 Users Say Thank You to humfrz For This Useful Post:
MICHAEL450f (04-04-2021), spike021 (04-04-2021), Spuds (04-04-2021), Tcoat (04-04-2021)
