Old 03-25-2021, 05:42 PM   #1
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
2017+ Urethane Rear S/B Bushings?
HELP!
Has anyone found an aftermarket supplier for Urethane replacement bushing for the 2017+ 16mm rear sway bar?
Updating my 2016 and would like to improve the bushings while I’m at it.
Muskoka800 is offline   Reply With Quote
Old 03-26-2021, 07:29 PM   #2
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Originally Posted by Muskoka800 View Post
HELP!
Took less than 30 seconds.
https://www.suspension.com/universal...r-bushings.asp
https://www.amazon.com/s?k=16mm+poly...ref=nb_sb_noss
Old 03-26-2021, 07:40 PM   #3
Racecomp Engineering
Rear OEM sway on 17+ is 15mm.
Grady (03-29-2021)
Old 04-02-2021, 10:09 AM   #4
Muskoka800
It’s appears that 15mm bushing for the Impreza will factory fit and are available in the aftermarket. Found on eBay and on there way from Russia, of all places.
Thanks all for your input.
*SOLD* Whiteline Sway Bars Front & Rear FRS BRZ 86 Urethane Bushing Shipping Included hirollaz Brakes, Suspension, Chassis 0 08-08-2018 01:50 PM
FS: (OK) Superpro Rear Toe Arm Bushings kingsalami Brakes, Suspension, Chassis 1 11-19-2016 02:22 AM
rear subframe bushings? Roadcone Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 09-09-2014 09:25 PM
FS: SPC Rear LCA's (with toe bushings) wparsons Canada Classifieds 4 08-18-2014 10:28 AM
Urethane Sway Bar Bushings? phm14 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 01-16-2013 10:32 PM
