Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
View Poll Results: How would you rate the design of the 2nd gen? 1 lowest & 5 highest
1 19 7.20%
2 25 9.47%
3 62 23.48%
4 104 39.39%
5 54 20.45%
Voters: 264. You may not vote on this poll
Old 03-28-2021, 01:18 PM   #1499
anticubus
Drives: 2017 Toyota 86
To me this feels like another Corolla XRS 9th gen -> Corolla XRS 10th gen jump in the making. The 2ZZ-GE was exciting and the smaller, nimbler platform was fun. The next gen wasn't bad, but it was somehow even more boring to look at and exist around. The 2.4L offered was uninspiring to say the least, that trim was literally a downsized Camry with a stiff suspension.
anticubus is offline   Reply With Quote
Old 03-28-2021, 05:19 PM   #1500
Transport3r
Drives: -
Didn’t it gain almost 500lbs between those 2 chassis?
Transport3r is offline   Reply With Quote
Old 03-28-2021, 10:26 PM   #1501
Blighty
Drives: WR Blue Pearl 2022 Subaru BRZ
In my eyes it couldn't be more different.
I owned a 2zz, there was no follow-up to that sports spec of the corolla 9th gen.
That is not the case with this new 86/BRZ, all its performance metrics are up and its a dedicated sports car platform.
Blighty is offline   Reply With Quote
Old 03-29-2021, 10:31 PM   #1502
anticubus
That's what I'm saying with the 2ZZ comparison. It was as much a clean sheet engine compared to the 3S series as the FA is to the old EJ blocks. Toyota is still using D4-S in their newer engines, things were much more NA performance aligned for the first gen. The newer FA24 is going to move the car faster like the 10th Gen XRS (That did exist, powered by the camry's 2.4L engine. https://www.motorweek.org/reviews/ro...ta_corolla_xrs) in that it's getting more power from displacement and I don't suspect much else. It also isn't as likely to enjoy revving out just because it's a bigger engine.
This is 100% speculation though. When they're out I'll test one and we can all laugh at my terrible predictions if it's way more fun and I end up trading mine in or something like that. I don't think that's happening though, the styling also isn't very appealing to me vs the current gen.
Yes, yes it did. It also gained proper traction control and a lot of commuter-focused features. The 10th gen isn't bad, just uninspiring and a product of the recession and safety regulations coming into effect.
Old 03-29-2021, 10:54 PM   #1503
jflogerzi
jflogerzi's Avatar
They increased redline and the tq comes on sooner. As long as power holds to redline should be just as fun. Hopefully the 2.4L will sound better
2013 Series 10 FRS #553
Old 03-30-2021, 07:27 AM   #1504
Blighty
The 10th Gen XRS was using a completely different engine tuned for a regular passenger car, and made way less power than the 2ZZ - it was not faster.
It had more torque of course, but torque like an agricultural vehicle, not a sports car.
Old 03-30-2021, 08:32 AM   #1505
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
From quickly looking up the 2 on reviews, the 10th gen was about a second slower to 60 than the 9th gen. No wonder it feels slower. The 2.4 has more torque down low but when you're wringing it out that doesn't matter if you still make the same power up top, and weigh 300lbs more. I'm sure it feels quicker around town accelerating in the lower rev range, but that's probably it.
Old 03-30-2021, 09:40 AM   #1506
Sasquachulator
Pavement Grey
The camry motor is just a lazy non-performance oriented motor.
It made power, it made sounds...it was...an engine.
The 2ZZ on the otherhand....sounded like a motorbike at high revs and wailed like a banshee when it engaged lift...and Lift gave it a turbo-like kick in the butt. VETAK KICKED IN YO!!!!
The Following 2 Users Say Thank You to Sasquachulator For This Useful Post:
PulsarBeeerz (03-30-2021), Yoshoobaroo (03-30-2021)
Old 03-30-2021, 05:13 PM   #1507
anticubus
This is exactly what I'm referencing. It doesn't look like the FA24 is going to enjoy being up towards the 7K range, but it definitely resolved the torque issues. I like revving it out so the torque dip wasn't a huge issue in daily driving but after focusing on my cornering there are lots of times where it becomes a choice between landing in the the dip or a shift mid-corner.
I wasn't making a direct comparison to the 2.4L out of the 10G XRS, just noting that the two BRZ generations have followed a similar engine pattern. The FA20 and the FA20DIT landing in the BRZ and then quickly the WRX means they saw more performance oriented design aspects like the high redline and in Toyota's case the focus on extracting all the NA performance regulations and engineering margin would allow them. Then the next generation we get an NA version of a turbo SUV engine with a more hands-off approach from Toyota. I'm worried it's going to drive like one. With the announcement their model is getting pushed back I'm definitely not buying first year.
Old 03-30-2021, 07:55 PM   #1508
ZDan
ZDan's Avatar
Drives: '23 BRZ
It makes peak power at 7000rpm. That is where it wants to be. And it makes 23hp more than the current gen at that rpm. We get another 100rpm before the rev limiter, so it will stay (slightly) further up in the powerband after upshifting. I don't see any downsides. Here's what relative rear wheel hp and torque should look like:
Old 03-30-2021, 08:22 PM   #1509
Yoshoobaroo
TRACKBREAD
This shows perfectly that the motor should be similarly rev-happy as the FA20
Another good indicator is that the stroke (86mm) was unchanged, and only the bore enlarged (86mm>92mm). Typically engines with larger bore/stroke ratios like revving more than ones with lower bore/stroke ratios.
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
ermax (03-30-2021)
Old 03-30-2021, 09:41 PM   #1510
ermax
ermax's Avatar
Especially when that extra space is used for larger valves. Most of the time when getting a displacement bump OEMs go with a longer stroke which negatively impacts high revs. Fortunately they didn’t go that route. There’s no reason this new engine should be less rev happy.
The Following 2 Users Say Thank You to ermax For This Useful Post:
nikitopo (03-31-2021), Transport3r (03-30-2021)
Old 03-31-2021, 12:53 AM   #1511
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
The only issue I can see with this engine is the higher compression ratio (13.5 vs. 12.5), which it could affect performance more with lower quality fuel. Such compression ratios were used in the past mainly in racing applications, where someone had access to racing quality fuel. It looks they went into that direction to extract the best possible performance figures under this displacement level and latest emission regulations. E85 and Flex fuel kits could be a solution for those having access to such type of fuel. And of course the worst option would be to supercharge such a high compression engine ...
The Following User Says Thank You to nikitopo For This Useful Post:
Tcoat (03-31-2021)
Old 03-31-2021, 06:36 AM   #1512
Yoshoobaroo
TRACKBREAD
I bet it's still fine running on 87AKI. It may be optimized for 91/93 but I kinda doubt that being that the US public has such an aversion to using higher octane fuel for some reason. We'll see I guess. I'm excited about the C/R bump, I always run 93 in my cars anyway since they all have at least a 93 Octane tune on them anyway.
2022 Subaru WRX Spy Shots via Car and Driver R_E_L Other Vehicles & General Automotive Discussions 230 01-03-2023 01:23 PM
2017 BRZ Hig Res - Courtesy Subaru Global Media Trap63 BRZ First-Gen (2012+) — General Topics 10 07-11-2016 09:53 AM
Subaru global brz web page Gaen BRZ First-Gen (2012+) — General Topics 4 06-15-2012 01:32 AM
Subaru FT-86/216a news: Subaru Confirms Rear-Drive Coupe Debut for Geneva Motor Show C-Bone BRZ First-Gen (2012+) — General Topics 39 03-24-2011 09:22 AM
FT-86 makes UK debut at Goodwood Moving Motor Show Hachiroku FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 28 07-09-2010 02:57 PM
