Old 03-27-2021, 12:30 PM   #379
JD001
JD001's Avatar
Drives: Subaru BRZ
Today I learned that "watching paint dry" may be fun..
Old 03-27-2021, 03:57 PM   #380
Lantanafrs2
Drives: 2013 frs red
Compared to speculating on release dates it may be
Lantanafrs2 is offline   Reply With Quote
Old 03-27-2021, 05:13 PM   #381
I'd be OK watching paint dry....
The Following 4 Users Say Thank You to Dadhawk For This Useful Post:
JD001 (03-27-2021), Kaotic Lazagna (03-28-2021), Lantanafrs2 (03-27-2021), NoHaveMSG (03-27-2021)
Old 03-27-2021, 10:30 PM   #382
soundman98
ProCrastinationConsultant
soundman98's Avatar
TIL to never, ever use pepboys for vehicle maintenance. my trucks previous owner used them exclusively. every single thing he had them 'repair' has failed in less than 3 years. today, finally worked through the last two items i haven't had time to work on before...
The Following 5 Users Say Thank You to soundman98 For This Useful Post:
Dadhawk (03-29-2021), DarkPira7e (03-27-2021), NoHaveMSG (03-28-2021), ScoobsMcGee (03-29-2021), Spuds (03-27-2021)
Old 03-29-2021, 02:58 PM   #383
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
TIL why programmers use "libraries", so much easier even though you don't learn anything.
The Following 5 Users Say Thank You to NoHaveMSG For This Useful Post:
Dadhawk (03-29-2021), ScoobsMcGee (03-29-2021), soundman98 (03-29-2021), Spuds (03-29-2021), Ultramaroon (03-29-2021)
Old 03-29-2021, 04:19 PM   #384
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
It's easier until you run into integration issues...
The Following 4 Users Say Thank You to Spuds For This Useful Post:
NoHaveMSG (03-29-2021), ScoobsMcGee (03-29-2021), soundman98 (03-29-2021), Ultramaroon (03-29-2021)
Old 03-29-2021, 05:58 PM   #385
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I don’t know what that means but it sounds like it sucks.
Old 03-29-2021, 06:12 PM   #386
Well integration leads to better schools so that you can learn more.
NoHaveMSG (03-29-2021), soundman98 (03-29-2021)
Old 03-29-2021, 06:44 PM   #387
soundman98
soundman98's Avatar
it's the software equivalent of making a square peg fit in a round hole. except you've got no idea it won't fit just by looking at it, and to trim things to size, you must go through 500+ lines of text in a code editor, line-by-line sometimes to find the spot that doesn't fit.
i like my physical hammers and chisels better.
The Following 3 Users Say Thank You to soundman98 For This Useful Post:
NoHaveMSG (03-29-2021), ScoobsMcGee (03-29-2021), Spuds (03-29-2021)
Old 03-29-2021, 08:14 PM   #388
Spuds
The Dictater
Spuds's Avatar
...then try to run it on hardware it was never really meant to run on using janky-AF OS and firmware/bios configurations, and then basically disable 1/4 of said library functions because certain mofos said you have to because it makes their job easy. Then you have to explain to the coder that "Works on my machine" doesn't field a system, which is significantly easier than telling the customer that the shit application they gave you to put in 2 weeks before they wanted the final product delivered not only doesn't work the way they said it would, but also breaks their own damn rules.
NoHaveMSG (03-29-2021), ScoobsMcGee (03-29-2021), soundman98 (03-30-2021), Ultramaroon (03-29-2021)
Old 03-29-2021, 09:58 PM   #389
ScoobsMcGee
Junior Senior with Cheese
ScoobsMcGee's Avatar
All this just to have some security schmuck say you have a buffer overflow which results in RCE. Then he expects you to be grateful for pointing it out, and asks for a bounty.
The Following 4 Users Say Thank You to ScoobsMcGee For This Useful Post:
NoHaveMSG (03-31-2021), soundman98 (03-30-2021), Spuds (03-30-2021), Ultramaroon (03-29-2021)
Old 04-08-2021, 09:35 AM   #390
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Today I learned that just because you can, doesn't mean you should.
First sunny and 50 degree day. Thought I'd wash my car since it hasn't seen sunlight since last spring.
Pushed the car outside thinking it felt really tough to push.
Brakes are so rusted, I can't get it back in the garage alone. RIP
I never brought the hose in for winter, I got completely soaked from the spigot connection at the hose end when I turned on water pressure. It's still completely frozen...RIP
The Following 2 Users Say Thank You to DarkPira7e For This Useful Post:
soundman98 (04-08-2021), Spuds (04-08-2021)
Old 04-08-2021, 09:58 AM   #391
Spuds
The Dictater
Spuds's Avatar
Sounds like at least one very bad day that was 6+ months in the making... I am assuming your car doesn't run at the moment.
soundman98 (04-08-2021), Tcoat (04-08-2021)
Old 04-08-2021, 10:03 AM   #392
DarkPira7e
DarkPira7e's Avatar
Yeah car doesn't run. The only enjoyment it brings right now is me getting to clean it while I wait for parts
The Following 4 Users Say Thank You to DarkPira7e For This Useful Post:
MICHAEL450f (04-09-2021), soundman98 (04-08-2021), Spuds (04-08-2021), Tcoat (04-08-2021)
OFT KC learned Nah Software Tuning 3 03-17-2016 12:52 AM
Learned some interesting things about my car today... SisterBlue22 Scion FR-S / Toyota 86 GT86 General Forum 12 08-09-2015 02:23 PM
Everything I know, I learned from the internet. Chillswitch Cosmetic Modification (Interior/Exterior/Lighting) 17 01-09-2015 02:31 PM
KC learned, what does it mean? wparsons Software Tuning 4 08-15-2014 11:37 PM
Today I learned (TIL) IloveBaldEagles Off-Topic Lounge [WARNING: NO POLITICS] 5 03-16-2013 08:15 PM
