Old 03-26-2021, 11:32 AM   #15
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
I took some sandpaper to mine just to roughen up the surface where the markers are. It helped a bit.
The slightest incline or decline will throw the reading off.
The Following User Says Thank You to RToyo86 For This Useful Post:
soundman98 (03-26-2021)
Old 03-26-2021, 11:43 AM   #16
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
You have a dozen people telling you it is fine. Why ask if you are just going to disregard the answers?
You didn't even follow the basic instructions of measuring it when the car has been run and is warm. By letting the car sit for weeks you have let every drop settle into the pan which gives a false high level.
Leave it alone. Slightly high is far better than low.
This. i would worry more on low level than high level
The Following User Says Thank You to zc06_kisstherain For This Useful Post:
Old 03-26-2021, 12:00 PM   #17
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by Sniepster View Post
Maybe some might see this as a laughable non-issue. But for those who track the car (like me) with a non-baffled stock pan, oil levels are worrying if too high.
I'll be syphoning some oil out as i just don't feel confortable with the amount in the pan currently. Thank you everybody for the inputs.
I track my car, and even with the oil on the full mark when hot, I get oil starvation on high G corners. The crank is about 4 inches higher then the OEM windage shield, it is no where near the oil level. Not to mention at high RPM's boxers tend to trap a lot of oil in the heads and have poor drain back. The oil that is pumped into the heads runs down into the timing cover and drains back into the sump from there in a passageway between the timing area and the upper pan assembly.
If you look at what an accusump does, it dumps quarts worth of extra oil into the system during an oil pressure drop. The few ounces you are over is fine.
High G oil starvation, about 4000-4200rpm. Street car on 200TW tires, 5psi.
The Following 4 Users Say Thank You to NoHaveMSG For This Useful Post:
Dzmitry (03-26-2021), SCFD (03-28-2021), soundman98 (03-26-2021), Ultramaroon (03-26-2021)
Old 03-26-2021, 12:54 PM   #18
If you know better, why did you bother asking?
Please explain to us how tracking makes this special?
How would a baffle help in this situation?
The Following 5 Users Say Thank You to Ultramaroon For This Useful Post:
Capt Spaulding (03-26-2021), Jdmjunkie (03-26-2021), NoHaveMSG (03-26-2021), soundman98 (03-26-2021), Tcoat (03-26-2021)
Old 03-27-2021, 10:22 PM   #19
radroach
Drives: car
To add this convo, check the other side of the dipstick. One side always reads higher than the other. Read from the side that reads lowest.
One time a few years ago after doing my own oil change, I thought I had overfilled the oil! I drove over to my local mechanic and showed him and he laughed, and said subarus always read high on one side. Flip the dipstick over and see if it reads lower.
Old 03-28-2021, 01:05 PM   #20
ls1ac
ls1ac's Avatar
"When i ask a question i will only accept answers that agree with what i thought".
I would quote the source but cannot remember who said it.
The Following 7 Users Say Thank You to ls1ac For This Useful Post:
humfrz (03-28-2021), Jdmjunkie (03-28-2021), NoHaveMSG (03-28-2021), Ohio Enthusiast (03-28-2021), soundman98 (03-28-2021), spike021 (03-29-2021), Ultramaroon (03-28-2021)
Old 03-28-2021, 03:57 PM   #21
Uhhhhhhhh ....... @Tcoat?
Old 03-29-2021, 09:52 AM   #22
ls1ac
ls1ac's Avatar
I knew the author was familiar.
And i thought it might be Locke or Hobbes.
The Following 3 Users Say Thank You to ls1ac For This Useful Post:
Capt Spaulding (03-29-2021), NoHaveMSG (03-29-2021), soundman98 (03-29-2021)
Old 03-29-2021, 01:39 PM   #23
I wouldn't say that. If I ask a question it is because I don't know the answer not just to garner support for my preconceived answer.
humfrz (03-29-2021), soundman98 (03-29-2021)
Old 03-29-2021, 06:11 PM   #24
ls1ac
ls1ac's Avatar
I think it was a complement to you an your comment above.
Old 03-29-2021, 08:03 PM   #25
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
You on drugs?
You mean the same car that Toyota on their national car commercial and countless Motorsports shows that glorifies this car as track-ready fun car?
Boy....... stop with the funny smelling vapes.
Old 04-02-2021, 02:51 AM   #26
Sniepster
Drives: 2013 Toyota 86
Thank you, this was very helpful info. The guy that offered help to syphon some oil out also took a look at the dipstick and said the same thing as you guys, that i shouldn't worry and that it's actually gonna play in my favour on the track as it might reduce the risk for oil starvation.
My fear was that with the oil level being so high it might slush around on high g corners and reach the crank.
I ended up leaving it alone. You guys can be real mean sometimes
Sniepster is offline   Reply With Quote
Old 04-02-2021, 02:14 PM   #27
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
We are a little rough sometimes but not so bad once you get used to it.
Old 04-02-2021, 03:25 PM   #28
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
<tannoy announcement> THE BEATINGS WILL CONTINUE ... THAT IS ALL <tannoy announcement>
The Following 4 Users Say Thank You to bcj For This Useful Post:
Jdmjunkie (04-02-2021), NoHaveMSG (04-02-2021), soundman98 (04-02-2021), Ultramaroon (04-02-2021)
Engine Oil Overfilled Causing Leak? congee Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 8 07-24-2020 05:25 PM
Best service in So Cal.. Cobaltbloo Southern California 5 04-23-2018 03:50 PM
Oil slightly overfilled on last oil change any concern? wbradley Issues | Warranty | Recalls / TSB 7 12-22-2013 10:01 AM
Dealership overfilled my engine oil mike the snake Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 50 12-07-2013 10:50 PM
Overfilled Oil samisons Issues | Warranty | Recalls / TSB 10 12-06-2013 07:04 PM
