Old 02-23-2021, 07:50 AM   #9073
TorontoB
Drives: Brz
What would be the limits on built motor combination 22psi and nitrous? How
TorontoB is offline   Reply With Quote
Old 02-23-2021, 09:19 AM   #9074
86TOYO2k17
Drives: 2017 toyota 86
depends how hard you want to push it and risk breaking the engine or lower the lifespan of your built block.
Built FA20s are somewhat hit or miss as it is.
Personally 340ft lbs would be the max I would even consider pushing on a built FA20 that's about 100-120ft lbs more than stock block can typically handle with decent reliability.
The SPS 335 + FBO + E85 and add in WMI to manage heat, Should be able to get you pretty close to the reliable limits of a built block. 320ft lbs / 400whp should be doable. On this platform that is a handful and you wont be getting much traction beyond that anyways without some serious other modifications.
If you absolutely must run NOS for whatever reason a 20 shot max would be all even then I dont think its worth the risk.
What is your fixation on the 335 + NOS? if the 335 doesn't get you the power you want get a turbo setup, do an engine swap, or get a different car.
Old 03-01-2021, 07:16 PM   #9075
Astro2015
Drives: '16 sprintex frs
Hey FT86club, this is my first time posting to a forum, but happy to be here. I love this chassis, and have been lurking for a while. I dove in with the 335 install, but having some problems.
Could anyone that's installed a 335 unit share how they torqued the main screw in front to hold the supercharger down? It looks like it fits my torque wrench's drive, but the unit itself blocks me from getting it into the hole...
Also, if anyone has info on how to wire the water pump to the injectors I'd appreciate it. I have a harness, but not sure what goes where.
Astro2015 is offline   Reply With Quote
Old 03-01-2021, 09:54 PM   #9076
jflogerzi
jflogerzi's Avatar
Pump just use a relay to the battery. Not many have installed the 335
2013 Series 10 FRS #553
Old 03-02-2021, 10:08 PM   #9077
kev0
Drives: '14
So, so tired of this rubber connector breaking. The hose eventually 'cuts' it because the fit isn't 100%. Annoying because to replace it, I have to buy a box of various sizes, although I only need ONE out of the 10 in there, because Auto Zone does not sell it individually. Each box costs like $6 too!! This is the fourth time I've had to replace it.
kev0 is offline   Reply With Quote
Old 03-02-2021, 11:54 PM   #9078
jflogerzi
jflogerzi's Avatar
Maybe your bypass valve accuator is not quite lined up
The Following User Says Thank You to jflogerzi For This Useful Post:
kev0 (03-03-2021)
Old 03-03-2021, 12:18 AM   #9079
86TOYO2k17
What is that hose directly underneath the small hose?
How close is it to the white hose? looks like it’s almost touching. under load when you’re engine rocks that small hose will hit the big hose pushing up and eventually break the rubber connector.
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
kev0 (03-03-2021)
Old 03-03-2021, 12:42 AM   #9080
kev0
Drives: '14
Now that u mentioned it.. the hose is positioned incorrectly. Compared it to my old photos and I noticed that it is oriented the wrong direction!!
Yes you're right. It is touching. The vibration is definitely causing it to cut. Going to move the hose out the way. The hose is connected from the engine block into the air intake.
Old 03-09-2021, 08:20 AM   #9081
Ads
Drives: 86
Originally Posted by Kodename47 View Post
Just to note that this compressor won't only be used for the BRZ/86 so the dipstick setup won't be simply for the FA20 and that the angle on the engine won't be the same for all uses.
I understand your point, though I was referring specifically to the BRZ/86 and the conflicting instructions between the relevant Sprintex and Innovate manuals.
Originally Posted by Ads View Post
My dipstick was also previously threaded, which seems to be another common occurrence. Now I can't get it anywhere near 10Nm before it threads. I have been getting it as tight as I can with my fingers for now, anything tighter and it threads.
It seems to be ok for now, but I will have to see how it goes with the pressure once the car is up to scratch for the track and it is being pushed.. I am guessing I may just have to sort this out before then though..
Turns out it's not ok... Unless it is in some magical sweet spot of finger tightness, it will spew out oil under load..
Originally Posted by brybot View Post
Semi-related PSA: helicoil kit is a good solution to stripping the Al threads on the oil dipstick. Remember the torque spec on that is 7 ft-lbs / 10N-m and NEVER take it out when it's hot. Anyone has questions, feel free to PM me.
I would be keen for some more info on your experience completing the helicoil repair. How is it holding up? I am about to attempt a temporary fix with some PTFE tape, although I'm not sure how this will go and if it will hold up. Either way, I would want to fix it properly as soon as I can.
Ads is offline   Reply With Quote
Old 03-24-2021, 12:41 AM   #9082
kev0
Drives: '14
For those who have dyno'd this car: What numbers did you make and with what fuel type, type of dyno?
Old 03-24-2021, 12:47 AM   #9083
jflogerzi
jflogerzi's Avatar
I posted my dyno and details in this thread
Old 03-29-2021, 11:38 PM   #9084
stockysnail
Just the tip
stockysnail's Avatar
My dyno is in my build thread on 92 Octane Costco gas with 70mm pulley, intercooler, etc. 250hp/200tq to the wheels. Turns out to be about +75hp/+75tq give or take. Over stock
Old 03-30-2021, 12:31 AM   #9085
jflogerzi
jflogerzi's Avatar
What kind of dyno and more importantly what does a stock car do on this dyno.
Old 03-30-2021, 10:56 AM   #9086
stockysnail
Just the tip
The info was in my long build thread but I understand if you didn't want to look at it. The 2 dyno lines in the attached are on a DynoJet. I didn't get a completely stock dyno run as my car wasn't stock anymore and there are other people that have done a stock dyno run, thus how I got my estimates over stock.
The two lines are 75mm stock pulley, not intercooled, 92oct gas on BRZedit from PRE in Portland. The second is 70mm pulley, intercooled, 92oct gas on EcuTek from MotoMike at the formerly known as MotoEast. Intercooled doesn't get heat soaked and performance is better over longer running periods vs non-intercooled.
The kit can only run on the stock MAP sensor as any other sensor like the 3bar with freak out the ECU at the top end, probably because of the weird/restrictive air flow with the intercooler sandwiched between the manifold and supercharger. There's no post blower temp reading which seems silly.
+30HP/TQ can be achieved by running e85 but in my area of Portland there's only one gas station that dispenses it at the pump (if it is still around), and I don't have space or the desire to get barrels of it.
The Following User Says Thank You to stockysnail For This Useful Post:
kev0 (03-30-2021)
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
