Old 03-22-2021, 10:36 PM   #1
Nfsundrgrnd
Nfsundrgrnd's Avatar
Drives: 2013 WR blue sport tech BRZ
Question Highest mileage BRZ/GT86/FRS with valve spring recall
I'm curious about the amount of people who got the recall done and did not get a catastrophic failure resulting in a blown engine. I'm also curious about who has the highest mileage done after the recall. I got my brz in february and brought it to my local Subaru dealer to get a few things fixed and they mentioned the free valve spring recall so I figured why not and had it done.
This was before I read up on all the catastrophic failures that had happened. Since then, I've put nearly 6000kms on my car with normal driving and hard driving from time to time with not much issues.
I just want to know if I have a ticking time bomb or if a bunch of people have driven with the recall with no issues.
Thanks!
Nfsundrgrnd is offline   Reply With Quote
Old 03-22-2021, 10:38 PM   #2
henry.haden
Drives: 2013 Subaru BRZ
I have almost 70,000 miles with a supercharger and no issues
henry.haden is offline   Reply With Quote
The Following User Says Thank You to henry.haden For This Useful Post:
FRSapex (03-28-2021)
Old 03-22-2021, 10:52 PM   #3
Ashikabi
Ashikabi's Avatar
Thanks!
Honestly 6k isn't much. You're not out of the woods yet. BUT the vast majority of failures seem to be from Toyota dealers so you should be fine
Sent from my ONEPLUS A5010 using Tapatalk
The Following User Says Thank You to Ashikabi For This Useful Post:
Nfsundrgrnd (03-23-2021)
Old 03-23-2021, 12:11 AM   #4
Nfsundrgrnd
You've done 70k miles after the recall with a supercharger? That's reassuring if so!
Old 03-23-2021, 09:01 AM   #5
TommyW
TommyW's Avatar
Drives: '13 Whiteout
It’s really hit and miss. Either they put the timing cover on right and scrape the old silicone off correctly or they don’t. It’s Russian Roulette.
I made it 3,000 miles. I think for those that drive conservatively have a better chance of not having issues. Mine went exiting T5 at Laguna Seca
TommyW is offline   Reply With Quote
The Following 2 Users Say Thank You to TommyW For This Useful Post:
Tcoat (03-23-2021), x808drifter (03-24-2021)
Old 03-23-2021, 09:07 AM   #6
Mine was completed on 1/15/2019 with 136,305 miles/219,362km on the odometer.
I now have 181,718 miles/292,447km with no issues.
As @TommyW says, it was either done correctly (as most were) or it wasn't.
Tcoat (03-23-2021)
Old 03-23-2021, 10:41 AM   #7
Petah78
Drives: 2022 BRZ sport-tech
Impressive mileage! How was it driven and maintained? Track use? OCI?
Thanks.
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ
Current: 22 BRZ, 00 S2K - #0220
Petah78 is offline   Reply With Quote
Old 03-23-2021, 10:42 AM   #8
That's because the vast majority of the '13 model year were Toyotas. In the US, there were 11,417 2013s sold vs 4,144 Subarus.
Ohio Enthusiast (03-23-2021), Tcoat (03-23-2021)
Old 03-23-2021, 10:46 AM   #9
Thanks.
It's my daily driver, so primarily a commuter car, no track time. That doesn't mean it is babied, just hasn't been on a track.
Standard maintenance based more or less on the schedule, except spark plugs which were done at the time of the recall. More details in my owner's journal.
Petah78 (03-23-2021)
Old 03-23-2021, 10:55 AM   #10
If you are really concerned either you or your favorite mechanic could drop the the oil pan and check the screen for "debris". There are photos on here of a bad one, but basically your mechanic will go "oh, what the hell" as soon as she sees it if it's bad.
finch1750 (03-23-2021)
Old 03-23-2021, 11:28 AM   #11
Nfsundrgrnd
Yeah I was thinking of taking a look when I change the oil. Would give me peace of mind lol
The Following User Says Thank You to Nfsundrgrnd For This Useful Post:
Dadhawk (03-23-2021)
Old 03-23-2021, 11:36 AM   #12
Nfsundrgrnd
Do you think I'd see metal debris if I'd cut open the oil filter? If it was indeed failing that is.
Old 03-23-2021, 11:46 AM   #13
If you see metal debris it is already too late.
The majority of the ones that failed do so within a thousand miles. If there is enough material blocking oil flow you are not going to get far before things go bad. It isn't a gradual wear situation but a rapid and catastrophic one.
I would not worry much after about that thousand mile mark. Not to say it couldn't happen but the probability is strong that it will not.
The only true way to check is (which has been mentioned) to pull the pan and check for silicone pieces. Checking the filter won't substitute for that since they are so big they don't even make it that far.
Dadhawk (03-23-2021), ermax (03-24-2021), Hamza (05-14-2021), Nfsundrgrnd (03-23-2021)
Old 03-23-2021, 01:44 PM   #14
Nfsundrgrnd
Ok thanks for the input! I love the car and would hate to see it die, which is why I want to learn more about other people's experience with the recall. The car has been running pretty good so I might just hold off on digging into it. If it ain't broke, don't fix it, right?
Tcoat (03-23-2021)
engine failure, high mileage, recall, valve spring recall
Possible recall on the 86 regarding valve spring tanner CANADA 84 11-28-2019 09:32 PM
Valve float after valve spring recall mswbrz Issues | Warranty | Recalls / TSB 5 11-22-2019 07:03 PM
Not doing the Valve Spring Recall? arnie0000 Issues | Warranty | Recalls / TSB 30 08-06-2019 05:24 PM
BRZ Valve Spring Recall mrhemi Issues | Warranty | Recalls / TSB 6 03-01-2019 03:35 PM
Valve Spring Recall venturaII New England 13 02-25-2019 07:41 PM
