Old 03-19-2021, 05:01 AM   #1
yooooooo
Drives: Toyota 86 GTS 2019
Toyota 86 Fuel Consumption
Hey guys so I recently bought a 2019 Toyota 86 GTS used from a dealer. I drive pretty well by always shifting below 3k and coasting whenever I can. However the gauge shows that I do 10.5L/100km. I drive half suburban and highway. Also when I unscrew the gas cap it makes a hissing noise? Is this normal?
yooooooo is offline   Reply With Quote
Old 03-19-2021, 05:09 AM   #2
Purist
Purist's Avatar
Drives: Subaru BRZ
Yes.
Sent from my SM-G973F using Tapatalk
Less More
Purist is offline   Reply With Quote
Old 03-19-2021, 05:10 AM   #3
Thefalls
Thefalls's Avatar
Drives: Corolla GT
Its better you calculate by filling up full tank and calculating how many kms you covered.
Hissing noise is normal. Don't stress about that.
And reset the fuel estimation gauge with every fill up. It will be more precise this way.
Thefalls is offline   Reply With Quote
Old 03-19-2021, 05:35 AM   #4
yooooooo
Yea I have been. Thanks.
Old 03-19-2021, 05:43 AM   #5
Purist
Purist's Avatar
Drives: Subaru BRZ
I'm pretty sure the fuel consumption is calculated using data from the fuel map so it should be extremely precise
. I could be wrong...
Less More
The Following User Says Thank You to Purist For This Useful Post:
Tcoat (03-19-2021)
Old 03-19-2021, 07:09 AM   #6
Actually the fuel consumption gauge shows an average. The longer you leave it without resetting the more accurate that average is since it has more varied data points.
It is the total opposite to what you would intuitively think is happening.
Dadhawk (03-19-2021), Thefalls (03-19-2021)
Old 03-19-2021, 08:15 AM   #7
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
For your driving habits 10.5L/100 seems high. That's around 22mpg.
I get 9.5L/100 or 24mpg average in the winter with more idle time and long warm ups.
Old 03-19-2021, 09:13 AM   #8
I'm guessing you fellow drivers must do a good bit of city driving? I think I'd have to punch a hole in my tank to get that low. Over 180,000 miles I've averaged 33.5MPH (7.02L/100km).
It's actually improved over time, even though the majority of the travel is the same roads. I posted about that earlier today (and on a couple of previous occasions in my owner's journal).
Dadhawk is online now   Reply With Quote
Old 03-19-2021, 09:25 AM   #9
yooooooo
Yea that’s what I’ve been hearing. Should I go get it checked with a mechanic ?
Old 03-19-2021, 09:36 AM   #10
Obviously couldn't hurt, but it's so condition specific, it may be your "normal". I can't really say its a requirement if you aren't seeing any other issues.
Old 03-19-2021, 09:41 AM   #11
RToyo86
RToyo86's Avatar
It's a mix, but I also don't baby the car either. I regularly take the car up to 5-7k rpm on the drives home via back roads to my house on 80kmh roads.
My morning commute is mostly highway. I live 1 minute from the highway so I end up idling my car for 5 minutes in the morning so I don't jump on with a stone cold engine when it is -10°c of colder.
That's why I find it odd I still manage better mileage in my worst possible conditions than his regular.
In the summer I average around 28mpg under the same mix of driving.
Old 03-19-2021, 09:41 AM   #12
Itsthebeast
Itsthebeast's Avatar
Drives: 2015 FR-S
I usually get between 29-30 for my average and I live in a stop and go city. 22 seems a bit low to me unless you're sudden stopping and stomping the gas at every stop, could also be the gas you're using. Lower octane gas usually gets lower milage for me from what I've noticed the few times I've used it
Itsthebeast is offline   Reply With Quote
The Following User Says Thank You to Itsthebeast For This Useful Post:
Old 03-19-2021, 09:47 AM   #13
I don't baby mine either, but I also don't ever idle for long (including warming up the car). Even in cold weather, I crank and go. Now, mind you I don't see but a handful of days a year below freezing where I live now, but even when I lived further N in the USA where that is the norm, I never warmed up my car.
Old 03-19-2021, 10:28 AM   #14
RToyo86
RToyo86's Avatar
The 4.3fd doesn't help. The best tank I have managed was cruise locked at 110kmh for most of the tank @ 32mpg. That's measuring mileage and fuel added at fill-up.
When I park the car in the garage and car shuffle I can set off right away without issue. it's when it sits in the driveway in temperatures -10c and below. Once it gets to -15c the clutch pedal is spongy on startup and takes 2-3 minutes idling to feel normal. it doesn't shift smoothy in those conditions until the fluid warms up.
The Following User Says Thank You to RToyo86 For This Useful Post:
Toyota 86 Fuel Consumption yooooooo AUSTRALIA 9 04-03-2021 02:50 PM
Causes of Very High Fuel Consumption? exittoexist Scion FR-S / Toyota 86 GT86 General Forum 33 03-13-2020 02:09 PM
Fuel consumption figures too PuGZoR AUSTRALIA 25 02-16-2014 05:36 PM
Tyre Pressures/Fuel Consumption Vic_RSA AFRICA 11 12-11-2012 01:20 PM
Weight, fuel consumption and 0-100. Loki556 AUSTRALIA 15 07-16-2012 09:06 PM
