Old 03-17-2021, 11:54 PM   #15
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
The Forester oil cooler/regulator is an easy add that is relatively cheap depending on kit/where you order.
It uses warmer coolant to heat oil up to temp faster and then flips and uses colder coolant temps to regulate oil when it's hotter.
Old 03-18-2021, 07:20 PM   #16
czellers
czellers's Avatar
Drives: 2K19 GT86
Originally Posted by jkamelo View Post
Thanks for all the great responses.
I think I’ll roll with the header + DEI tape and call it a day. This car is my DD and I don’t plan to take it to the track enough to justify the “added failure points” of an oil cooler.
FWIW, I covered the whole oil pan except for right around the plug with one 12"x12" sheet from amazon.. it was like $12 and the wrap was 50' that came with the header. So if you buy wrap, get 50' with at least 10 steel zip ties. I used all 10 ties and about 48 feet of wrap. PS, it will smoke after driving for about 5 miles but will be brief.
Also, take your time wrapping.. I used a temp plastic zip tie to start a piece of wrap, make sure it was super tight, tight enough to basically hold itself, then go back with a steel zip tie and cut the plastic on off after I got the metal one on good. The best way I found to get the metal ties tech was grabbing the loose end if the tie once it was through the female part of the tie and twisting the needle nose pliers basically rolling it, then cutting the excess and folding the remaining half inch into a tab back on itself.. whole thing took me like 6 hours to just take my time and do it right.
This is what it ended up looking like..
czellers is offline   Reply With Quote
The Following 3 Users Say Thank You to czellers For This Useful Post:
jkamelo (03-18-2021), theneptune86 (03-22-2021), Z06ZN6 (03-19-2021)
Old 03-18-2021, 08:02 PM   #17
I suggest that, in terms of minimizing radiated heat transfer, polish up nicely and call it good. If I had it my way I'd ceramic coat the inside and keep the outside polished.
Old 03-19-2021, 12:36 AM   #18
Z06ZN6
Drives: 2017 Toyota 86
If you consider wrapping the header, I recommend fit checking it to the engine first to see how much clearance you actually have to the underside of the oil pan before going through the trouble. My ft86 header tube is so close to the pan that literally I doubt two or more layers of wrapping tape created by overlapping layers would even fit without contacting the pan, and I'd rather not create a direct conductive heat path to the oil this way. The air gap will be a better insulator.
Z06ZN6 is offline   Reply With Quote
Old 03-19-2021, 10:02 AM   #19
czellers
czellers's Avatar
Drives: 2K19 GT86
100% on this.. The Tomei UEL has lots of space but I replaced a cheap knock off EL header that was actually touching the oil pan.. which might have been why the old one wasnt wrapped.
Old 04-08-2021, 12:57 PM   #20
KMA KiCKz
Certified Wumbologist
KMA KiCKz's Avatar
Drives: 2015 Scion FR-S
Dumb question, but I plan on swapping my stock header with the ceramic-coated FT86SF catted header and was wondering: Has anyone noticed an overall increase in engine temps while running this?
I’m worried that if I add this, it will create a cascading effect of needing to buy an oil cooler, etc. to keep temps down. Or maybe I’m overthinking things. Let me know!
Based on my experience, been running the FT86SF header 6+ years with no issues. Also used as my daily with spirited driving every other weekend or so.
Got mine before they offered it with any coating at all and haven't seen any significant temp changes.
So far so good I suppose
- My 2015 Scion FR-S OEM+ Build Thread -
TRD | Brembo | RAYS
KMA KiCKz is offline   Reply With Quote
The Following 2 Users Say Thank You to KMA KiCKz For This Useful Post:
86geek (05-07-2021), jkamelo (04-09-2021)
FT86SF Catted Black UEL header + OFT V2 XdjlX Engine, Exhaust, Bolt-Ons 2 02-02-2020 11:25 PM
FT86SF UEL Catted Header with CEL Infamous_Key Engine, Exhaust, Transmission 11 01-18-2019 06:00 PM
FS: FT86SF Catted UEL Header $300 Zut Engine, Exhaust, Bolt-Ons 5 08-27-2017 05:31 PM
LF: Gruppe-S Header or FT86SF Catted UEL Header b11lee Canada Classifieds 6 12-14-2016 04:03 PM
