Old 01-13-2021, 07:06 PM   #99
Joveen
Joveen's Avatar
Drives: Bone stock
Originally Posted by Evil Rocky View Post
Awesome build!! What made you use that turbo??
T51R mod bro!! Also the fact that boostlab is good company. I'm going that same route as my boy.
Sent from my SM-N960U using Tapatalk
Joveen is offline   Reply With Quote
The Following User Says Thank You to Joveen For This Useful Post:
DarkPira7e (01-14-2021)
Old 01-14-2021, 12:18 AM   #100
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Thank you! I actually changed my mind; I stayed with Boostlab but picked up the BL58X and got the T51R compressor housing option. The shop I help out at has been installing some Boostlab turbos and I want to show my support for a company that my shop trusts and get their name out there just that little bit more. That, and I decided I'm not just doing this half ass- this is full send
Originally Posted by Drifter X View Post
Been lurking on this thread. Really cool build man.
I appreciate that! With the FRS as its base, it can only be excellent
Old 01-14-2021, 05:30 PM   #101
DarkPira7e
DarkPira7e's Avatar
Little update-
Lots of parts in!
Engine gasket set
ARP head studs
KillerB oil pickup
Fluidampr pulley
Boostlab BL58x (.82 hotside, T51R compressor housing mod)
PTP turbo blanket
4 direct injectors fresh from seal replacement and cleaning by FIC
I changed turbos because honestly I want this build to be everything I've got. I've gone through too much to just have it be OK. This turbo should be good for 500+ on pump gas at around 25psi. I plan to sit low to mid 400s
I won't be upgrading the transmission right now. Replacements are cheap and power can be backed off if transmissions and axles gets wasted too quickly.
Still needed-
Timing chain kit
I think that's it. We'll see
The Following 3 Users Say Thank You to DarkPira7e For This Useful Post:
Drifter X (01-14-2021), NoHaveMSG (01-14-2021), Tomm (01-14-2021)
Old 01-14-2021, 06:24 PM   #102
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Before you put sealant in the oil pan and assemble it, install the pickup and set the oil pan on dry to make sure it fits. Mine was made way too long and I made a mess of the sealant and had to redo it.
Old 01-14-2021, 07:13 PM   #103
DarkPira7e
DarkPira7e's Avatar
Thanks for this, I'll be sure to check!!
Old 02-03-2021, 12:46 PM   #104
Limitless_BRZ
Limitless_BRZ's Avatar
Drives: Crystal White BRZ
just started lurking, keep it up! can't wait to see the finished build
Limitless_BRZ is offline   Reply With Quote
The Following User Says Thank You to Limitless_BRZ For This Useful Post:
DarkPira7e (02-03-2021)
Old 03-18-2021, 12:28 PM   #105
DarkPira7e
DarkPira7e's Avatar
Bought new timing components for the heads! Just need to see what we need for shims.
The Following 2 Users Say Thank You to DarkPira7e For This Useful Post:
Drifter X (03-19-2021), Lonewolf (03-19-2021)
Old 03-18-2021, 02:07 PM   #106
Joveen
Joveen's Avatar
Drives: Bone stock
Bout time you updated us. We hitting the meets this year or nah?
Sent from my SM-G998U using Tapatalk
Old 03-18-2021, 02:26 PM   #107
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Still running 13" spec head?
Old 03-18-2021, 05:41 PM   #108
DarkPira7e
DarkPira7e's Avatar
Hopefully!
Yep. Using my original heads that were good, not re-using the ones on the used replacement engine.
Old 03-25-2021, 09:18 AM   #109
screamer_chaotix
screamer_chaotix's Avatar
Drives: Mitsubishi Evo IX MR SE
New here, but also in Vermont and interested in getting an 86...looks sick. I'll keep an eye out for ya!
screamer_chaotix is offline   Reply With Quote
The Following User Says Thank You to screamer_chaotix For This Useful Post:
DarkPira7e (03-25-2021)
Old 03-25-2021, 10:54 AM   #110
DarkPira7e
DarkPira7e's Avatar
Awesome! I'd be more than happy to give you a ride sometime when it runs. I have a friend with a 2017 performance pack BRZ that would probably be willing to give you a ride, too (if you want to feel what a bolt-on car drives like)
Old 04-15-2021, 05:32 AM   #111
jrhudson
Drives: 2016 scion frs
Awesome build! Cant wait for the finished car
Also you got your heads decked and resurfaced?
jrhudson is offline   Reply With Quote
Old 04-15-2021, 09:03 AM   #112
DarkPira7e
DarkPira7e's Avatar
Yes! Picking them up in about... 45 minutes or so actually
Edit- nvm, machine shop can't do the FA20 heads yet, we're making a bracket for his machine the will bolt to the exhaust side. He uses the intake sides on EJ heads but the casting protrudes out further than the bolt holes
jrhudson (04-19-2021)
brz, frs, iag, jdl, turbo
Joel's BRZ - Low Budget Time Attack Build DIY Member's Car Journals 403 11-19-2024 07:39 PM
Cxracing turbo problem Kalebhall Forced Induction 10 11-16-2017 07:57 AM
Tony's Budget Turbo Build glorydays Member's Car Journals 22 01-25-2015 11:02 PM
My boosted build...on a budget PineappleFriedRice Member's Car Journals 95 08-17-2014 09:29 PM
Aznsky's budget STX build Aznsky Tracking / Autocross / HPDE / Drifting 13 05-12-2014 08:44 AM
