Old 07-27-2012, 01:08 AM   #15
Ad8707
Ad8707's Avatar
Drives: 2013 frs whiteout
Have you guys experienced getting bad batch of gas before..with either your current or previous cars...
Ad8707 is offline   Reply With Quote
Old 07-27-2012, 01:12 AM   #16
Marrk
Drives: Honda Fit
^^If you are convinced that it is the gas, you could syphon out what's left in your tank and refill with gas from a different station. Just a suggestion.
I've experienced instances of poor and/or rough running in my motorcycles that I attributed to bad gas. A tank of new gas seemed to cure it.
Marrk is offline   Reply With Quote
The Following User Says Thank You to Marrk For This Useful Post:
@Art_Mighty (10-16-2012)
Old 07-27-2012, 01:18 AM   #17
Ad8707
Ad8707's Avatar
I am really hoping it just that..I'm just very paranoid...googled a few things and issues such as clog fuel filter bad fuel pump bad injectors maf sensor throttle sensor all mimic the same symptoms..I'm thinking it's a little early to get these problems
Old 07-27-2012, 01:24 AM   #18
Marrk
Drives: Honda Fit
^^Obviously, you are a little exercised over this. It's a new car, after all. We can all relate. But, really, you haven't told us anything that sounds that serious yet. Not likely it's the fuel pump. It could be, but I doubt it. If it were a sensor, you'd get a code, right? So, maybe it's the gas. Or maybe it's nothing. How's the weather where you are? Extreme ambient heat can affect performance. What altitude are you at? It's probably not the altitude or the heat, but I'm curious.
Old 07-27-2012, 01:32 AM   #19
Ad8707
Ad8707's Avatar
Toronto and its been kinda humid lately..iuno if that would really affect things...It just the car has been hesitating and won't climb the rpm....there should be a cel if one of those sensors go bad...It just hasn't been the same..I'll wait it out at least I don't have a cel or anything
Old 07-27-2012, 01:40 AM   #20
Jidonsu
Drives: Scion FR-S | 6MT | Ultramarine
Could be a lot of things. Have you at least checked your air filter? One time I had one of my cars bog like hell after refueling. I thought it was bad gas or bad MAF. When I took apart the stock airbox, I found a giant leaf blocking the air filter, and that was the problem.
Jidonsu is offline   Reply With Quote
Old 07-27-2012, 01:57 AM   #21
Snoopyalien24
Mr. Sarcasm
Snoopyalien24's Avatar
Why don't you try emptying the gas tank 'till its almost completley empty, maybe wait for the gas light to light up the re-fill. Same problem, try different place. Same problem? Throw it in the canal
Snoopyalien24 is offline   Reply With Quote
Old 07-27-2012, 01:59 AM   #22
Lonewolf
Lonewolf's Avatar
Drives: Moped
Heat and humidity can do a number on performance...
Old 07-27-2012, 02:47 AM   #23
rs_two_five
Drives: 2007 Subaru WRX
X2
Or possibly the feeling you're getting is from the added weight of the fuel in the tank. Heck, I notice driving my WRX when the tank is low vs full. It's the reason why I always fuel up before auto-xing.
rs_two_five is offline   Reply With Quote
Old 07-27-2012, 09:37 PM   #24
CircuitJerk
Pull my finger...
CircuitJerk's Avatar
Drives: Silver Scion Slushbox
There could be several things at play here.
Fueling up with a reduced octane level can cause the ECU to start correcting and changing timing to compensate. I don't know how the 86 is set up so this part is more speculation than anything.
I've had it take almost half a tank or better before things settle in. My Rav4 V6 shares the same engine as one of the Lexus models with direct injection that requires premium. It is rumored the ECU programming is identical and has the logic to compensate for regular or premium.
When I changed to 93, after about 3/4 tank I noticed more pull and responsiveness especially in hot humid weather. The mileage improved slightly as well. When fall came and the temps dropped to the high 70's (F) I changed back to regular and had a similar experience for what it seemed like an entire tank of fuel.
What I suppose was happening was the higher octane in the higher temps and humidity allowed more aggressive timing and better performance whereas the 87 it would just lag in hot weather since it was pulling timing..
Don't panic, drive it out but avoid WOT as much as possible.
Go back to the 93+ and give it a half tank and see what happens.
CircuitJerk is offline   Reply With Quote
Old 09-07-2012, 09:49 AM   #25
Grimlock
Grimlock's Avatar
Drives: BRZ and NA
Filled 91 v power (no ethanol), hour later noticed significant power loss..it's taking awhile for the rpms to climb...car has 4000km no oil change..did I get bad gas...or is something more serious ie maf sensor fuel pump/fuel filter..it takes awhile for those things to go bad right...
Update? It's been over a month.
Grimlock is offline   Reply With Quote
Old 09-07-2012, 03:40 PM   #26
Razz
Razz's Avatar
Drives: Fast
When this happens buy a can of HEET to remove water.
http://www.autozone.com/autozone/acc...ier=136367_0_0_
Razz is offline   Reply With Quote
Old 09-08-2012, 12:06 AM   #27
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
Use ISOHEET it is non-corrosive.
Coheed is offline   Reply With Quote
Old 10-15-2012, 09:46 PM   #28
TemeCal
Drives: 86
Sorry to resurrect this thread. However, I just had the exact same thing happen to my car. My car had Mobil 91 in it, and it was very quick and responsive. Just fueled up with 91 Shell V-Power, and it is SLOW now. It honestly feels like a completely different car, like I'm back in the Corolla rental Toyota put me in.
Anyway, I was curious to see if you resolved your issue. If so, what'd you do? Switch brands? Octane booster?
Before anyone says I should be using 93, I'm in CA and only have access to 91. I do have some Torco fuel additive I use in my desert toys, so I may mix some into this tank.
Thoughts??
TemeCal is offline   Reply With Quote
Factory Oil Fill Level Black Tire Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 54 12-09-2016 02:14 AM
What is your prediction on FT86 power and Subaru 086a power? 86Fan Scion FR-S / Toyota 86 GT86 General Forum 88 08-27-2013 12:49 AM
Loss of power after gassin up HELP!!!! Ad8707 CANADA 26 07-29-2012 07:24 PM
DI and engine power loss over time Sport-Tech Engine, Exhaust, Transmission 7 06-27-2011 06:49 PM
How much are you guys paying to fill your tanks? Giccin Off-Topic Lounge [WARNING: NO POLITICS] 64 04-13-2011 02:36 AM
