| View Poll Results: Turbocharger or Supercharger? | |||
| Turbo |
19 | 30.65% |
| Super |
43 | 69.35% |
| Voters: 62. You may not vote on this poll | |||
#57 |
Road-hole
Drives: 2013 Whiteout FR-S
Takes more ancilliary...
#58 |
Drives: Q5 + BRZ + M796
#59 |
Road-hole
Let's make this easier.
#60 | |
Moreover, it is telling that you dodged the question I asked about what makes your situation unique for a supercharger that couldn't be done with a turbocharger. Regardless, this isn't the reality most people live with regards to the cost, nor is it really addressing the issue of which one is better or worse, but typically, it is cheaper to get into a basic turbo setup than a supercharger.
#61 | |
Road-hole
touche...
As to answering your question, the biggest cost difference would be the oiling for the turbo and the exhaust manifold and routing, which aren't necessary for a S/C. I could fab the exhaust using the catless header I already have or even the stock header but it's still additional cost. Even for someone with my resources, it would still be closer to $1000 for a turbo setup. Actually, I had already started to build a remote mount turbo when I still lived in Commufornia but I didn't want an electric oil pump so I was fabbing my own adapter for the wrx's oil return pump(the kit used on the existing turbo kit for our cars was over 500). I had gone a different route and was building a 4.6 ford to swap in and had taken the turbo out of the stock frs muffler and put it in my VR6 jetta but after realizing how cheap and easy it would be to add a S/C I detoured from the swap for the time being. Now I should be only about a week from being finished. I just finished porting the S/C housing and am waiting for some aluminum to come in for mounting. Now it helps that I had a spare engine and spare intake to modify for the supercharger so I saved money. I'll get into the details in the build thread. I think I'm going to take out the injectors and put them in my flow bench tomorrow since they've been sitting because my plan is to just use the intake as it was sitting with the fuel rails and injectors already in. That makes swapping back and forth like a 2 hour endeavor if I would want to do so. I may take some pictures tomorrow to show some progress although my intention was to create the build thread after it was all said and done. Jaden |
| The Following User Says Thank You to Jaden For This Useful Post: | Irace86.2.0 (03-13-2021) |
#62 |
At least you owned it.
| The Following User Says Thank You to Irace86.2.0 For This Useful Post: | Jaden (03-13-2021) |
#63 |
Drives: 2017 toyota 86
| The Following 2 Users Say Thank You to 86TOYO2k17 For This Useful Post: | Irace86.2.0 (03-13-2021), Jaden (03-13-2021) |
#64 | |
What blower you using? how much was it? and where/how did you get it? |
#65 | |
Road-hole
LOL...
It's almost like it was made perfectly for the fa20, the output hole lines up with the big square portion of the stock intake manfold when the pulley is in perfect alignment with the serpentine belt. The crank pulleys on the 3800 and the fa20 are almost the same size but the fa20 has a redline 1300 rpm higher than the 3800. So it will be rotating the m90 at about 13500 rpm which is perfect for about 300 wheel on E... I'm also building a water to air intercooler for it so I might in the future opt to switch out to the 3.4 pulley and take it up to 330-350 wheel. The 3800 N/A was also 200 hp and the gen 5 on 6lbs made 260hp on a super conservative factory tune. Now my car isn't stock so it's making closer to 240 bhp so it ends up being perfect for about 300 wheel on the stock pulley on E. I ported the gen III m90 so it should be close to on par with the gen V. I cut off the long intake on the back of the m90 and I'm fabbing up an intake that will mount the stock 86 throttle body that will swing around to the front with piping and tie into my perrin CAI. This will all be mounted onto the stock intake manifold. The bearings are all good on the m90 and it's the cleanest used S/C I've ever seen. The guys at the yard were surprised I was able to find one. I did get a replacement snout coupler and I'll replace the S/C oil though. The S/C cost me $90, the coupler $13, various aluminum and such around $30. Panel bond $30. There will still be some additional costs, but remember, I've already proven I can do flex fuel for $156 and I've ran that for over 3 years so, as far as being able to do what I say, been there done that. Jaden p.s. as far as posting the cost, It should come in at WAY under $500, $500 is allowing for any unforseen costs. I have a CNC mill, 5 3d printers, a gun smithing lathe, a cnc lathe and a welder so I'm not including the costs of what I already have that allows me to fab pretty much anything I want. Last edited by Jaden; 03-13-2021 at 11:48 AM. |
#66 | |
Sounds like a cool project none the less, hope it works out and you get some dyno numbers or some solid pulls in to validate what you’ve done. |
#67 |
A turbo can be done the same and probably easier for more people with just a welder. Used turbos and manifolds and oil lines can all be harvested for cheap from a junk yard. Internal wastegate. No BOV for low boost. Old manifolds for welding up a turbo manifold to the stock header.
This isn’t the reality for the vast majority, but even if it was, turbo is better.
| The Following User Says Thank You to Irace86.2.0 For This Useful Post: | 86TOYO2k17 (03-13-2021) |
#68 | |
Road-hole
no...
Yes the stock plastic intake manifold, but the S/C will be supported by metal brackets separately and the plastic intake will be supported with aluminum as well. The plastic intake is more than capable of handling the boost, I just have to make sure that the super charger is properly supported to be able to handle the load of the belt turning it. and yes I'm sorry but that marathon analogy is no where close to the same. Yes, building a flex fuel kit may be relatively easy (although less people would be able to code it) but getting it all done with tune for $156 is a different story all together. Jaden Besides, I'm only running E, I could easily get away with the 280-300 non intercooled on E with no crazy timing, but it won't matter because I will be intercooled. Last edited by Jaden; 03-13-2021 at 01:23 PM. |
#69 | |
Yeah the manifold can handle the boost no problem. Just concerned if it was supporting any load of the blower. But sounds like you got it all sorted and planned out well. Should post a link to your build page if people want to follow more. |
#70 | |
Think he was more bragging than giving an actual solution for anyone to consider following. Like you basically said, piecing a turbo kit together off ebay, or with some minor beginner fab work can be done fairly easily and cheaply at least compared to a make shift sc kit. Proper pulley alignment alone could be challenging not throwing belts all the time. |
| The Following User Says Thank You to 86TOYO2k17 For This Useful Post: | Irace86.2.0 (03-13-2021) |
| WTT: Pandem v3 widebody for FI kit (turbo or super) | IceMeister | Want-To-Buy Requests | 3 | 10-03-2018 12:06 PM |
| Super vs turbo | aslanteye | Forced Induction | 29 | 06-16-2015 12:30 AM |
| Turbo+super | firl21 | Forced Induction | 8 | 04-16-2013 11:51 AM |
| would you turbo or super charge your BRZ/FRS? | chenshuo | Scion FR-S / Toyota 86 GT86 General Forum | 45 | 03-04-2013 10:13 AM |
| Turbo or Super Charger | Ryan86 | AFRICA | 7 | 11-21-2012 08:14 AM |
