Old 03-11-2021, 11:44 AM   #1
theFISCHERcat
theFISCHERcat's Avatar
Drives: 2013 Subaru BRZ
BRZ Next Essential Mod?
Fellow BRZ enthusiasts,
Hello my friends. Looking for some recommendations from the community. Got my BRZ about 6 months ago and have started to modify shortly after getting it. So far I’ve done:
Wheels and tires (F1R F29s 18x8.5 +38 all four corners, wrapped with Federal SS595s)
Mishimoto Cold Air Intake
Mishimoto Baffled Oil Catch Can
Tomei UEL Header
Tomei Expreme Ti Type 80R Catback Exhaust
OFT V2 Stage 2+ Tune
With the intention of getting some track time in coming up in the next few months and those stimulus checks coming in, what would you guys recommend as a next mod that you would consider essential?
Thanks!
theFISCHERcat is offline   Reply With Quote
Old 03-11-2021, 11:53 AM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Dot 4 brake fluid.
Either go to a good 5-30 oil or add an oil cooler using good 0-20.
You are going to want to swap out those federals down the road, they are not great. Would have been better to stay with 17's.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
Dzmitry (03-11-2021), spcmafia (03-11-2021)
Old 03-11-2021, 12:01 PM   #3
dpfarr
Drives: BRZ ts
A tune to take advantage of headers and intake?
dpfarr is offline   Reply With Quote
Old 03-11-2021, 12:08 PM   #4
theFISCHERcat
Forgot to mention I picked up a OFT V2 and did the Stage 2+ tune. Would like to go ECUTek down the line once I start considering forced induction.
Old 03-11-2021, 12:09 PM   #5
theFISCHERcat
Dot 4 brake fluid.
I’ve had my eyes on the thermostatic oil cooler from mishimoto.
I got a package deal with the federals but I do plan on swapping out in the near future.
Old 03-11-2021, 12:16 PM   #6
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
Deff recommend hitting CSG for ECUTek. As someone told me before, don't go crazy with mods, and get some track time on, as the more mods you add right now prior to that the more they'll mask mistakes on your track experience. After getting some track time, you can start looking at flywheels, suspension mods, etc. Get a feel for your current mods and adjust accordingly.
Edit: I didn't notice that you had a CAI included. OFT is not compatible with CAIs, so I would look into that. Probably have to do some scaling and what not. In that case, better switch to ECUTek. More measurable gains.
spcmafia is online now   Reply With Quote
Old 03-11-2021, 12:18 PM   #7
cmiovino
cmiovino's Avatar
Drives: 2017 BRZ PP, 2004 WRX
If you're taking it on the track, your main concern should be braking. Track time, even light track days, are hard on the braking system.
At a minimum, if you're doing a basic track day, replace the brake fluid (Valvoline Dot 3 & 4 is a cheap, good fluid to start with) and swap to a better pad. You'll probably need something that gets up to temp on the street, but can also withstand lighter track duty.
An alignment and camber bolts would be beneficial for the track too to help with grip and mainly tire wear.
cmiovino is offline   Reply With Quote
The Following User Says Thank You to cmiovino For This Useful Post:
Old 03-11-2021, 12:21 PM   #8
theFISCHERcat
I noticed that as well, OpenFlash provides a custom tune to include CAIs with some data logging. Was an alternate route I was considering before jumping into ECUTek. Although that custom tune runs about $250, looking back should’ve just gone ECUTek lol
Old 03-11-2021, 12:22 PM   #9
theFISCHERcat
I appreciate the advice! Brakes was kind of an oversight but now it makes much more sense.
Old 03-11-2021, 12:23 PM   #10
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
They will still do the job till you wear them out. Try not to get sucked to far down the mod rabbit hole until you get some time in the seat. Early on, money spent on seat time is worth more then money spent on parts.
Have fun and be safe
The Following 4 Users Say Thank You to NoHaveMSG For This Useful Post:
bcj (03-11-2021), BrahmaBull1990 (03-12-2021), Dzmitry (03-11-2021), RBman (03-11-2021)
Old 03-11-2021, 02:11 PM   #11
CrowsFeast
CrowsFeast's Avatar
Drives: 2013 BRZ Sport-Tech
Performance alignment
front: camber plates and/or camber bolt(s)
rear: adjustable lower control arm
CrowsFeast is offline   Reply With Quote
Old 03-11-2021, 03:17 PM   #12
Lantanafrs2
Drives: 2013 frs red
You've already done plenty. Beautiful car
Lantanafrs2 is offline   Reply With Quote
Old 03-11-2021, 04:16 PM   #13
ZDan
ZDan's Avatar
Drives: '23 BRZ
Front camber. You need some! Camber bolts + offset mounts (Pedders?) is one way, or camber plates. Fresh DOT4 brake fluid (name-brand parts-store stuff is fine) and some decently trackworthy pads for track.
The Following 2 Users Say Thank You to ZDan For This Useful Post:
CrowsFeast (03-12-2021), nikitopo (03-12-2021)
Old 03-12-2021, 04:39 AM   #14
theFISCHERcat
Thank you =D
Help with essential basics why? Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 37 12-11-2016 03:07 PM
Why Processing is ESSENTIAL To Sound Quality TOOSTUBBORN2FAIL Electronics | Audio | NAV | Infotainment 38 06-03-2016 03:17 PM
Three Essential Subaru BRZ / Scion FRS Mods You Have to Make! MAPerformance Announcements, Contests, Giveaways 0 11-12-2015 11:40 AM
Essential roadtrips. Freeman Scion FR-S / Toyota 86 GT86 General Forum 16 04-18-2013 02:59 PM
