#15 | |
Drives: Q5 + BRZ + M796
I was going to suggest a manual boost controller earlier, but technically it isn’t much different than your restrictor pill; like the pill, they restrict flow. Alternatively, some bleed boost instead. Each has its advantages. It is a cheap and easy way to add boost or you can have them tune your EBC, which is typically better because there will be a line going to the top of the wastegate keeping it shut until the last possible minute, so there is no crack of the wastegate or spike. Why was the harness ruined? They asked you to wire the EBC into the EVAP wires, and it went sour? Are you talking about this short line or the actual main engine wiring harness? ![]() ![]() If it is just the small harness, I have seen used lines for cheap. You might be able to buy a new OEM/aftermarket EVAP harness for cheap too. https://www.ebay.com/itm/2013-2018-S....m46890.l49292 Getting back to the rich issue: obviously the lines running to the EVAP are still attached to the solenoid, right? Hopefully fixing the EVAP wiring fixes some fueling issues, but let’s say it won’t. Are you running low compression on pump gas or stock compression on E85? What injectors? Aftermarket fuel pump or not? It could be a vacuum/exhaust leak. A smoke test would be good to test the vacuum system. Soapy water on exhaust components to test for air leaks there. Any chance they didn’t calibrate the injectors right, so you have larger injectors dumping in too much fuel because they are opening too long like the stock injectors would? Low speed is typically more direct injectors, so maybe there is an injector seal leak or something. Probably far less likely. I would think simply. Do you have a datalog that you can upload to Datazap and post here along with the specs I requested above?
| Tags |
| boosted brz, broken, evap, fueling system |
| OFT+OFH running rich | Dabrown | Software Tuning | 14 | 11-28-2016 03:20 PM |
| OFT STAGE 1 running rich? | Flat_4_Life | Software Tuning | 4 | 04-21-2015 06:28 PM |
| Cel gas running to rich | anthonyravenfrs | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 07-15-2014 01:55 AM |
| Running rich | KslayFRZ | Issues | Warranty | Recalls / TSB | 15 | 10-25-2013 11:42 PM |
| running rich/stumbling | Boostedpro | Issues | Warranty | Recalls / TSB | 1 | 01-28-2013 02:19 PM |
