Old 02-11-2021, 09:29 PM   #1303
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by Limitless_BRZ View Post
for purpose, i measured my 1320 UEL header outside flange bolt to bolt(driver to passenger) it measured 23 1/8
the JDL UEL manifold measured 22 3/4 -_-
now i see why it dont fit
Deleted
Old 02-12-2021, 05:41 PM   #1304
Limitless_BRZ
Limitless_BRZ's Avatar
Drives: Crystal White BRZ
Talked with Jesse @ JDL & their fixing the manifold to fit
Limitless_BRZ is offline   Reply With Quote
Old 03-03-2021, 04:55 PM   #1305
ShadowReaper
Indulgent Tormenter
ShadowReaper's Avatar
Drives: 15' LTD Subaru BRZ DGM
Another JDL turbo owners having replace the air filter and the end of turbo inlet over and over again?
Instagram: Gabe.it.the.ole.college.try
ShadowReaper is offline   Reply With Quote
Old 03-04-2021, 11:08 PM   #1306
Limitless_BRZ
Well, i am happy with my kit. Everything running smoothly after my accident of not clamping a coolant line and spraying it all over my engine/hood. Its back on the road, dual catch can from radium. Thinking eventually built motor/bigger turbo etc
Follow on IG-- Limitless_brz
The Following User Says Thank You to Limitless_BRZ For This Useful Post:
FRS_FIEND (03-08-2021)
Old 03-08-2021, 05:04 AM   #1307
FRS_FIEND
Whats next?
FRS_FIEND's Avatar
Drives: '13 Asphalt FRS MT
If that happened to me when I installed my kit I would have just given up lol. how much power did it make?
Life is too short to drive a boring car...
Instagram: @angelb_af
FRS_FIEND is offline   Reply With Quote
Old 03-08-2021, 05:15 AM   #1308
FRS_FIEND
Whats next?
FRS_FIEND's Avatar
Finally got my car tuned last week! 396hp on e85 (e70) and 314hp on 91 10psi its a different car. I will only be using e85, no more 91 for me. I need to figure out on how to loosen my wastegate spring. My tuner was telling me that it was too tight, it is the 7psi spring and I am using a 3 port boost solenoid. any takers on what the tuner means by loosening the wastegate spring? I tried googling and yt and just cant find anything.
Old 03-08-2021, 08:49 AM   #1309
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
You can't loosen a wastegate spring, it is set at a fixed pressure. You add/remove springs to create the desired resistance. I'm certain they meant another component, probably the blow-off valve. The TurboSmart vee port pro BOV that came with your kit has a loosen/tighten mechanic. You just need to rotate the housing, there is an arrow on top of the BOV that can show you the direction you need.
Congratulations on getting your car all set and running, take care of it!
Old 03-08-2021, 07:10 PM   #1310
Limitless_BRZ
i did give up for 3 days while waiting for new hoses, reducers and clamps from summit racing lol
But i haven't got it dyno'd yet.. noticed today with the ECU phone app while driving hit 241 lb torque on a 3rd gear pull. not bad, but i noticed while doing that that i had a boost creep to 9lbs !
FRS_FIEND (03-23-2021)
Old 03-23-2021, 02:31 AM   #1311
FRS_FIEND
Whats next?
FRS_FIEND's Avatar
That's exactly what I said I know they're are a set pressure, but he said loosen my wastegate spring trust I remember vividly. they even reminded me through email lol OH! ok I completely forgot about the bov having the adjustability I installed it right out of the box without adjustment. you think the bov is too tight so its making me build/hold more pressure than I'm wanting? sorry for the late reply, I'm not on often.
thanks for the jogging my memory and advice bro. trust me I do take care of it. I've had it since 2013 and its been garaged all its life, its my baby. just replaced my old coilovers with some HKS Hypermax ones (6k,4k), tuner said previous supsension was too stiff (8k,8k) making the tires break loose on
the dyno. My pilot super sports were sitting for a long time because of a deployment and they were old. Replaced my coilovers anyway because I've had them since mid 2014 and got new Falken fk510s. I will be upgrading to Toyo r888s once I find wheels that can replace my Advans, which is hard af lol Anyway long story short I have a lot of money into my car and I never stop buying new car parts for it and keep most of my old parts lol.
The Following User Says Thank You to FRS_FIEND For This Useful Post:
CSG Mike (04-01-2021)
Old 06-12-2021, 05:13 PM   #1312
Efferalgan
Drives: 2025 BRZ, ex-2012 GT86
Why the cold air intake is no longer available? I desperately need one!
Efferalgan is offline   Reply With Quote
Old 07-23-2021, 11:10 AM   #1313
trinidadj
Drives: '16 FRS-MT Ablaze Red
I ordered a JDL kit with 2860rs turbo. My goals are 300whp using 93 now and then 300whp with e85 in the future. I'm looking at the southbend stage 2 daily (rated for ~315 tq) and southbend stage 3 daily(rated for ~400tq). Should I go stage 2 or stage 3? Anyone have issues slipping on stage 2?
Thanks
trinidadj is offline   Reply With Quote
Old 07-23-2021, 11:49 AM   #1314
jflogerzi
jflogerzi's Avatar
I would just get the stage 3. Remember these are rated at the crank or in the case flywheel and not whp and wtq
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
trinidadj (07-23-2021)
Old 07-23-2021, 03:21 PM   #1315
trinidadj
Thank you very much I ordered stage 3, I didn't know it was rated at crank.
Old 09-14-2021, 11:52 PM   #1316
DarkPira7e
DarkPira7e's Avatar
What are people doing for a filter on a 4" inlet? I bought an AGP filter but it's too long. I'm going to run a turbo screen for the time being, but I'm curious what others have done. A filter straight off the inlet puts me straight into the front support framework
I'll likely end up putting an ugly looking pipe + filter into the pocket where the windshield washer reservoir lived.
HKS Supercharger owners thread wbradley Forced Induction 1054 10-26-2024 02:18 PM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 03:31 AM
To Greddy Turbo Owners (or SBD/Zage Turbo).... Melted Radiator Fans? General Opinion? xuimod Forced Induction 106 09-01-2016 08:33 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 01:58 PM
P&L Turbo Owners Topic Thread GTB/ZR-1 Forced Induction 4 09-01-2013 07:27 PM
