Old 03-07-2021, 05:07 PM   #75951
The hoses are blocking the core.
ono
Ultramaroon is offline
Old 03-07-2021, 05:08 PM   #75952
Packing a box of OEM parts I'm keeping.. Is it worth keeping mostly used up OEM pads and the old OEM brake lines?? :dunno:
save brake lines. ditch pads
soundman98 (03-07-2021), spike021 (03-07-2021), Spuds (03-07-2021)
Old 03-07-2021, 05:28 PM   #75953
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Scrap both. If he in the future ends up selling the car; is it worth it to swap the OEM lines back on? Will selling used aftermarket lines be worth the hassle of swapping the OEM parts back on and replacing lost fluid for a car with such poor resale value?
Keep them if you want piece of mind in the back of your head should your current brake lines fail... but, even then it is only a better safe than sorry mindset.
Kiske is offline
The Following 6 Users Say Thank You to Kiske For This Useful Post:
Dadhawk (03-07-2021), humfrz (03-08-2021), soundman98 (03-07-2021), spike021 (03-07-2021), Spuds (03-07-2021), Ultramaroon (03-07-2021)
Old 03-07-2021, 05:46 PM   #75954
soundman98
ProCrastinationConsultant
soundman98's Avatar
scrap both. you're never going to re-use old pads, and the likelihood of pulling, replacing, and re-bleeding the entire brake system is a pretty large stretch for stainless steel lines that cost less than $200 for a whole set.
soundman98 is offline
The Following 4 Users Say Thank You to soundman98 For This Useful Post:
Dadhawk (03-07-2021), humfrz (03-08-2021), spike021 (03-07-2021), Ultramaroon (03-07-2021)
Old 03-07-2021, 05:56 PM   #75955
Totally agree. Safety > sorrow.
But yeah. Toss 'em.
Old 03-07-2021, 06:15 PM   #75956
spike021
spike021's Avatar
Yeah those are good points. Plus OEM lines probably aren’t super pricey if I absolutely had to swap back someday.
Instagram: @spike.grc
spike021 is offline
Old 03-07-2021, 06:35 PM   #75957
soundman98
soundman98's Avatar
rock auto shows the soft lines are about $10/corner.
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
Old 03-07-2021, 06:36 PM   #75958
I'm super leery of braided lines chafing but I have no long-term experience. That's the only reason I would save the stock ones. Plus I already have a couple boxes of shit I'll never use again. Would be easy to toss a set of brake lines in with the rest of it.
Old 03-07-2021, 06:39 PM   #75959
Yeah but those are untested ones. How much for a known good set?
bcj (03-08-2021), soundman98 (03-07-2021)
Old 03-07-2021, 06:47 PM   #75960
spike021
spike021's Avatar
I only have them because a friend won them at the Norcal86 Summer Kickoff raffle but didn't have a twin yet and wasn't planning to get the PP (these lines were for the OEM Brembo system), so they gave them to me, then I just had them swapped in when I had a shop do my last brake fluid change.
But yeah hopefully they're reliable enough to last.
spike021 is offline
Old 03-07-2021, 06:53 PM   #75961
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Roughly $20.03 each corner for OEM.
Kiske is offline
The Following User Says Thank You to Kiske For This Useful Post:
Old 03-07-2021, 06:58 PM   #75962
A "couple"?
Dude, I have seen your garage
Tcoat is offline
humfrz (03-08-2021), soundman98 (03-07-2021), spike021 (03-07-2021), Ultramaroon (03-07-2021)
Old 03-07-2021, 07:01 PM   #75963
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Random Thoughts - Part Deux [NO POLITICS]
Getting closer to done. Outside is almost done, need 3-4 more yards of gravel, put expanded steel on the foundation vents and put hand rails on the porches. Inside is just little BS. Outlets, plug covers, install backsplash, hook up sinks and toilet.
NoHaveMSG is offline
The Following 6 Users Say Thank You to NoHaveMSG For This Useful Post:
Dadhawk (03-07-2021), humfrz (03-08-2021), NWFRS (03-07-2021), spike021 (03-07-2021), Spuds (03-07-2021), Ultramaroon (03-07-2021)
Old 03-07-2021, 07:03 PM   #75964
soundman98
soundman98's Avatar
if he's selling, it doesn't matter how bad they bulge, as long as they don't leak!
