Old 03-07-2021, 09:54 AM   #519
StraightOuttaCanadaEh
Wes
Do they have a stock 2017 version? I have considered jumping into the 1/16 realm but never really saw one I wanted.
Just to clarify, you mean 1/18 right? Yes I have 2 stock BRZ and either 3 or 4 FR-S
Instagram: @gt86ws
Old 03-07-2021, 11:39 AM   #520
Kaotic Lazagna
Drives: GR Corolla
I'm still in awe that you have so many AutoArt models.
Since I felt bad about not using some of the Nismo parts in my original R32 Nismo build, I went ahead and ordered a standard R32 kit and will use all the unused Nismo parts on that. lol.
Old 03-07-2021, 11:45 AM   #521
Yes. 1/18 I typoed the 16!. I have the 2013 FRS Aoshima kit stashed away but have never found a 16+ (as they call it) kit that wouldn't require me taking out a second mortgage.
I would like to try a 1/16 kit since you can do a lot more detailing that can be seen.
StraightOuttaCanadaEh (03-07-2021)
Old 03-07-2021, 12:12 PM   #522
Kaotic Lazagna
Drives: GR Corolla
https://www.1999.co.jp/eng/10684256
You can sell the one you have now and pick this one up. Gives you the options of zenki and kouki versions, as well as LHD or RHD. And automatic or manual, as well as lowered or stock ride height.
Old 03-07-2021, 12:19 PM   #523
I would still need the one I have to do the Lava.
The problem I have with ordering from places like that is that by the time it gets to me that $28USD model costs about $140. With exchange, taxes, shipping, and duty there is no way I can order from independent places like that. For some reason Amazon or such doesn't seem to get all the extra costs pled on them.
Old 03-07-2021, 12:36 PM   #524
Kaotic Lazagna
Drives: GR Corolla
Oh dang, I keep forgetting about duty fees for you guys! I'm sure you can probably find this updated version on Amazon.
Old 03-07-2021, 01:28 PM   #525
Nope not yet at ant rate
Old 03-07-2021, 02:22 PM   #526
Wes
Yeah I bought mine either locally used or on sale. There are usually a few on Kijiji or fb marketplace. I think the 2 silver ones I bought from US cost me like $75 a piece.
Instagram: @gt86ws
Old 03-07-2021, 08:37 PM   #527
Kaotic Lazagna
Drives: GR Corolla
Alright guys. Need your input. This is in the primer stages (1 mist and one wet gray, and then 1 mist and 1 wet white coat). Don't mind the two splatter spots, the nozzle shot off after I depressed it for the first time (I guess I kept it in hot water for too long).
I originally cut out the roof for the moonroof option. However, after I tested the "glass" piece, the cut out for that was much smaller than the actual moonroof piece, as seen in the second pic. So I puttied the cut piece of the roof back on, but even after smoothing out the putty, I can see the outline still, even after the gray and white primer coats. What do you guys think I should do? Cut out the roof again and some how cut the glass piece and hope it doesn't crack farther out to the windshield part (that's why I abandoned the moonroof idea).
Not really liking Aoshima so far because of this (plus a few parts of the body had to be puttied since there were large gaps).
Old 03-07-2021, 08:42 PM   #528
Kaotic Lazagna
Drives: GR Corolla
Oh, and I couldn't just leave the glass piece uncut since it had one of those circles (I think they're called sink marks?) right in the middle.
Old 03-07-2021, 08:44 PM   #529
soundman98
ProCrastinationConsultant
soundman98's Avatar
need to keep sanding, adding filler, and more sanding. really a pain.
Old 03-07-2021, 08:53 PM   #530
Kaotic Lazagna
Drives: GR Corolla
But if I add more filler, it will no longer be flush with the body.
Old 03-07-2021, 08:57 PM   #531
Kaotic Lazagna
Drives: GR Corolla
So this is what it looks like. I guess I missed that tiny hole, or a chunk of putty came off when I was sanding???
Old 03-07-2021, 08:58 PM   #532
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Is the area you placed in too high (sand more) or too low (add filler)? Remember you should be samding before amd after applying fillers and primer to have a better bond and finish.
The Following User Says Thank You to Kiske For This Useful Post:
soundman98 (03-07-2021)
TRD ABS Plastic Kit? Shims Cosmetic Modification (Interior/Exterior/Lighting) 5 07-19-2015 07:31 PM
Front lip - abs plastic _frs Want-To-Buy Requests 0 09-21-2014 11:11 AM
Trade my black dash plastic for your silver dash plastic thread. F3dzo Southeast 0 07-17-2012 10:06 PM
plastic interior lancie Scion FR-S / Toyota 86 GT86 General Forum 34 10-16-2011 01:02 PM
