| View Poll Results: Turbocharger or Supercharger? | |||
| Turbo |
19 | 30.65% |
| Super |
43 | 69.35% |
| Voters: 62. You may not vote on this poll | |||
#43 | |
Drives: Q5 + BRZ + M796
https://www.greencarcongress.com/201...180411-a6.html I think the best, simplest and most elegant supercharger solution that was already mentioned is the electronically-controlled, variable-geometry pulley, which can essentially create a small-pulley high-boost-map for more power down low, and it can taper off boost by creating a large-pulley low-boost-map for less power up high. This means the supercharger never has to over-spin or bleed boost.
#44 | |
Master Collaborator
I'm speaking of what we as consumers can do to improve our EXISTING FI systems. With what I am describing, there are no electronics, no electrical connections and no batteries involved. It's purely mechanical. This would be something a home mechanic would be able to piece together with existing parts that are already out on the market. You're talking about something that would have to be mass-produced by a vehicle manufacturer that adds electric motors, additional batteries and a redesigned charging system. Why turn mechanical energy into electrical energy just to turn it back to mechanical energy, when the first two steps can be eliminated? The first video you posted above is addressing turbo lag, I'm addressing supercharger parasitic load of an already existing and installed supercharger unit which eliminates the lag in the first place. The second video seems to be focusing mostly on fuel efficiency and regenerative electrical production, I'm addressing performance by freeing up the power and torque at high RPM's which would normally be needed of your engine by the supercharger and that you are already producing anyways, to make it available to the drive train instead. (Besides, would you really ever want anything designed by Chrysler/Fiat to be bolted up to your engine?) |
| The Following User Says Thank You to FR-S2GT86 For This Useful Post: | Irace86.2.0 (03-05-2021) |
#45 | |
Drives: 2017 toyota 86
#46 |
Master Collaborator
I'm just throwing the idea out there. If I had deep enough pockets and a big enough shop with a dyno, as well as all the time that would be needed, I would do this. But as things are right now, I'm just slowly getting my car built little by little.
#47 | |
Also the point was to mention inherent benefits and drawbacks to each system. I wasn’t quantifying the impact of any of these things. The cheapest supercharger solution would be to buy a variable pulley supercharger like in the video above and build custom brackets since no one is offering an off-the-shelf kit for the 86. I posted a video from Torotrak, but Procharger also has a CVT-like supercharger: https://www.enginelabs.com/news/insi...ng-technology/ ![]() Just FYI, many other manufacturers are using BAS setups like Audi. Obviously, such systems could be custom added to any vehicle, but these are more for OEMs, which again, is what I assumed you were referring to in a hypothetical situation; I didn’t think you were thinking someone would actually build something one-off for their setup in a cost-beneficial way.
#48 | |
Master Collaborator
Although the variable pulley supercharger is an interesting design, seeing the technology already being used in vehicle transmissions with somewhat iffy reliability results, (I'm thinking Jatco CVT's in Nissan vehicles) I would have serious doubts about the overall reliability of that particular technology within the Procharger over an extended period of time. But time will surely tell once they are out on the market. Maybe they'll be more reliable than the Edelbrock kits, maybe they'll be worse. I can almost guarantee you that they won't be as reliable as our Harrop kits. One thing for certain is that they WILL cost even more than their standard supercharger as the rep stated in the video you provided.Another thing I see about the variable pulley supercharger, is that whenever boost is needed, and wherever in the RPM band, parasitic draw on the engine will still always exist. Low demand for boost, like in a standard fixed pulley supercharger, will mean a low draw, and high demand for boost will mean a high draw. What I'm proposing would reduce the draw on the engine completely (ideally) at high demand. This would have the added benefit of less strain on the engine internals. You are correct in pointing out the higher cost, which I pointed out already, but the two combined technologies I'm proposing are already tried and true and have been for decades. There is already an understanding of both out in the field of how they work and what things to expect to have to deal with when using them, with the exception of mounting a drive pulley to the gearbox instead of a compressor, but I would think that would simplify the build somewhat. And with the higher cost will come higher reliability, not only of the engine, but the bolt-ons as well. I seriously think my idea would be much more reliable in the long term than any type of electronically-controlled variable pulley drive system, as long at it is designed properly. I doubt those rollers or electronic actuators inside the Procharger will hold up to years of even just normal wear and tear. The good thing is, the standard Procharger supercharger is a tried, tested and reliable design, and its gearbox would be a good candidate to modify in the set up that I'm describing. The desired final supercharger drive shaft speed could be as simple as experimenting with different combinations of gearbox, pulley size, belt size and possibly overrunning clutch pulley size. It will certainly take time in developing, but what good product doesn't? |
| The Following User Says Thank You to FR-S2GT86 For This Useful Post: | Irace86.2.0 (03-06-2021) |
#49 | |
I think the biggest obstacle for your design would be mounting the exhaust turbine to an exhaust manifold with good tolerances and then having that interface with a pulley in a good packaging situation. I don’t know if you were thinking that there would be a custom output shaft mounted at a distance to a gearbox or if it would be mounted to the turbine like a centrifugal supercharger, but if it is the latter then there may be heat concerns for the components. It is an interesting idea.
#50 | |
Road-hole
Drives: 2013 Whiteout FR-S
You can drop timing for non E-85
Jaden |
| The Following User Says Thank You to Jaden For This Useful Post: | tomm.brz (03-12-2021) |
#51 | |
Also, when not on E85 with advanced timing and high boost, pulling timing with high boost might result in the same power or knock resistance as advanced timing on low boost, but the lower boost level will have better EGTs, less heat and less cylinder pressure for the same horsepower. It will have better fuel economy too, so while it may be done on a supercharger, the turbo would be better with flex fuel.
#52 |
Rust bucket enthusiast
I think after this, OP will be buying a canoe to simplify his life
| The Following User Says Thank You to DarkPira7e For This Useful Post: | bcj (03-13-2021) |
#53 |
LMGTFY
Drives: 13 FRS, 91 Miata
| The Following 2 Users Say Thank You to x808drifter For This Useful Post: | DarkPira7e (03-12-2021), Irace86.2.0 (03-12-2021) |
#54 |
We need to know OPs demographic and how harsh the waters are I think. Also, if they wear gloves or bareback the paddle. And if they have a dog(s). I give up, life is too complicated
| The Following User Says Thank You to DarkPira7e For This Useful Post: | x808drifter (03-12-2021) |
#55 | |
Road-hole
true...
Except I'm finishing up a flex fuel supercharger with a total cost of around $500, try that with a turbo...lol Jaden BTW, the $500 includes the $156 it cost me to add flex fuel already. |
#56 |
How would a turbo be different?
| WTT: Pandem v3 widebody for FI kit (turbo or super) | IceMeister | Want-To-Buy Requests | 3 | 10-03-2018 12:06 PM |
| Super vs turbo | aslanteye | Forced Induction | 29 | 06-16-2015 12:30 AM |
| Turbo+super | firl21 | Forced Induction | 8 | 04-16-2013 11:51 AM |
| would you turbo or super charge your BRZ/FRS? | chenshuo | Scion FR-S / Toyota 86 GT86 General Forum | 45 | 03-04-2013 10:13 AM |
| Turbo or Super Charger | Ryan86 | AFRICA | 7 | 11-21-2012 08:14 AM |
