Old 02-09-2021, 11:34 AM   #99
Tokay444
Anti stance.
Tokay444's Avatar
Did you check your alignment settings after installing?
Old 02-13-2021, 11:24 PM   #100
e30cabrio
e30cabrio's Avatar
Drives: 2017 86
No, it supposedly does not alter alignment and I'm not driving 100 miles a month and the rims & tires are coming off when my new ones come at which point, I'll have the car aligned.
e30cabrio is offline   Reply With Quote
Old 02-14-2021, 08:39 PM   #101
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Originally Posted by e30cabrio View Post
After about 80 miles more the car hooks up better and stays much more firmly planted during all manner of changes in direction and from changing road conditions. Worth every penny!
Oh wow.. Now I cant wait till the next stimulus drops. lmao jk
Intent > Content
Old 02-25-2021, 06:17 PM   #102
Bodalenko
Steve Bodalenko
Drives: Toyota 86 GTS
Originally Posted by wootwoot View Post
Any one know how much this lowers the rear of the car?
It doesn't. Well mine didn't..
Bodalenko is offline   Reply With Quote
Old 02-25-2021, 06:25 PM   #103
Bodalenko
Steve Bodalenko
Originally Posted by 86•BRZ View Post
That's a gross simplification of something that is different. A bit like saying you don't need coilovers if you've got a camber bolt.
I agree. I've had these on for prob 3 yrs and there was an instant change/improvement in the way the car handles under acceleration. Much more planted and sure footed. For the record I'm Harrop'd and at 300+hp. Also fitted with MCA Red, subframe inserts, Verus LCA and P4 245/40/18's on 9.5" TE37's.
Just watch fitting them. Those subframe bolts can be buggers to realign and will cross thread very easily. ALWAYS install with fingers. If installed properly the bolts should almost tighten up by hand till the last couple of threads. Then you can uses a socket and bar. Ask me how I know
Old 03-02-2021, 12:19 AM   #104
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Originally Posted by solidONE View Post
Define "planted".
Old 03-03-2021, 09:48 PM   #105
solidONE
solidONE's Avatar
Ahh. Planted like onions? Or is that garlic?
Intent > Content
Old 03-03-2021, 09:55 PM   #106
solidONE
solidONE's Avatar
How about on the brakes? Does it not want to rotate as much on corner entry.
Intent > Content
Old 03-03-2021, 11:39 PM   #107
Captain Snooze
Drives: Red Herring
Are you serious? This is the suspension thread; they are obviously aftermarket bushes. Well, young, immature bushes.
Here is a picture of a rubber bush. I couldn't find a pic of a poly bush.
Old 04-14-2021, 07:37 AM   #108
e30cabrio
e30cabrio's Avatar
Drives: 2017 86
I'm selling my car and my mca mod is for sale in the member classified suspension section
Old 11-16-2021, 06:46 PM   #109
Tatsu333
Drives: 2020 BRZ Sport Tech RS
Latest mod installed today - MCA Traction Mod:
Installing on jack stands in my garage was not super fun...LOL.
Also, if you ever do this mod, do yourself a favour and do ONE SIDE AT A TIME. I.E. do EVERYTHING on the one side, then start the other. Trust me.
Haven't had a chance to really push it in the twisties yet (my favourite roads are currently cut off by flooding due to heavy rains over the last few days), but I took it through some of the spots around town where I've had some code brown moments with the back snapping out mid-corner and my first impressions are that it does what it says on the tin - puts the power down much better through corners and particularly bumpy corners.
Before, it felt twitchy and would snap into oversteer when the outside rear loaded up suddenly and the diff would shunt the power to that wheel, but now it's WAY more planted.
Helical diffs on FWD are friggin magic - when the outside wheel loads up, it just shunts torque to that wheel, tucks in and drives the front end around the corner. I installed a Quaife diff in my Tiburon, and it was insane how well it could put power down in corners.
With the BRZ's stock behaviour, I was having my doubts whether the same type of diff made sense in a RWD car. With this mod, I feel like it more progressively loads the outside wheel, making the diff behave better. The car feels like it has more of the balance it should have had from the factory as a proper sports car.
HIGHLY RECOMMENDED MOD, for sure!
Tatsu333 is offline   Reply With Quote
Old 11-17-2021, 03:49 PM   #110
gpvecchi
gpvecchi's Avatar
What is your lowering? It should provide a similar effect.
Old 11-17-2021, 04:34 PM   #111
Tatsu333
Zero - I'm on stock (Performance Pack) springs and Sachs dampers.
For what it's worth, with how much that pickup point is lowered by the Traction Mod, to get the same reduction in anti-squat from lowering the ride height would require about a 50mm drop, which would have very little, if any, suspension travel left.
UPDATE: Got a chance to push it a bit more on some of the local roads in the dry, and all I can say is WOW. This is how the car should have been from the factory. Puts the power down so much better, and the rear end behaviour is much more predictable.
Last edited by Tatsu333; 11-18-2021 at 12:11 AM. Reason: EDIT 1: Added note RE: change in pickup point EDIT 2: further driving impressions
Old 11-18-2021, 04:51 AM   #112
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
What's the rear alignment like?
ineedyourdiddly
Needed opinions: Does debadging "Subaru" and "BRZ" cheapen the car? davidchoi Cosmetic Modification (Interior/Exterior/Lighting) 49 11-22-2014 10:17 PM
"Clicking" or "knocking" caused by rear seat pull down lever. husker741 Issues | Warranty | Recalls / TSB 6 11-27-2013 02:30 PM
"My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") levifig BRZ First-Gen (2012+) — General Topics 48 08-09-2013 06:34 PM
Factory suspension "sticktion" andrew20195 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 04-02-2013 02:49 PM
"Official" Suspension/Brake Thread NYC BRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 27 06-27-2012 09:14 PM
