#29 | |
I'm at about 185,000 miles, including the spring recall work, and no issues so far. Then again, I've had "good luck" with almost all my cars, and never have been "afraid" of cars with miles, including two GM vehicles that had nearly 300,000 miles on each. I can think of 10 cars I've owned that had more than 150,000 miles on when I traded them in that were all still running when I did so. Heck I own a Mustang, Suburban, and a Scion right now that are all over 120,000 miles and one Honda that's over 210K. One of them had a second engine, but it was installed under warranty and went another 250,000 miles with the second engine. All the others, had their original motors, transmissions and had only minor (under $1000) repairs done to them.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
| The Following 6 Users Say Thank You to Dadhawk For This Useful Post: | BrahmaBull1990 (02-27-2021), Grady (02-25-2021), MuseChaser (02-27-2021), soundman98 (02-25-2021), strat61caster (02-25-2021), Tcoat (02-25-2021) |
#30 | |
| The Following 4 Users Say Thank You to Grady For This Useful Post: |
#31 |
Famous Potatoes
Drives: '15 ultramarine
My highest mileage car in my life with original motor and tranny was a 1982 Honda civic 4 door. 350k miles. It was still running when I sold it to the state as a gross polluter, and still getting 30 mpg.
Still had original clutch. |
| The Following User Says Thank You to Sapphireho For This Useful Post: | Dadhawk (02-25-2021) |
#32 | |
Starting a track career in it's "retirement" at 140,000 miles. https://www.ft86club.com/forums/showthread.php?t=143847
| The Following 3 Users Say Thank You to Tcoat For This Useful Post: |
#33 | |
Drives: '13 FRS - STX
I'll cross 100k miles in the coming weeks on my car, like I said before, high confidence in crossing 150k miles without major incident just like many of your vehicles (unless it's an issue related to hpde/tt use). Sold my truck at 210k miles and it was starting to need more then the little maintenance items, things like timing chains and catalytic converters and hvac repairs. Which reminds me, I need to go shore up my front bumper this weekend, it's flapping in the breeze... |
| The Following User Says Thank You to strat61caster For This Useful Post: | Dadhawk (02-25-2021) |
#34 | |
Drives: 2015 BRZ WRB
| The Following User Says Thank You to CB750F For This Useful Post: | aghuman (03-01-2021) |
#35 |
Feeling like thinking....
Almost without exception, the reason I've had to "retire" a vehicle over the years has been salt and the subsequent total corrosion of the frame/unibody/body panels, brake and fuel lines, gas tanks, mounting points, etc. Eventually it gets so bad and so unenjoyable to fight that stuff that I give up and move on to the next sacrificial vehicular offering to the sodium sowers. We aim for at least 200k miles, and have beens successful everytime...our record so far was a Volvo 240 with 275k on it, with a Bmw 325i, a Ford Aerostar, and a Benz ML430 all close behind with about 235k each, give or take. Every vehicle still ran great engine and tranny wise. The only engine trouble I've ever had was dealer/recall-induced via our FR-S. Did have to replace the transmission in our current ML500, but that was evil used car criminal dealership induced.
Drive like everyone's life around you depends on it...
| The Following 3 Users Say Thank You to MuseChaser For This Useful Post: |
#36 | |
Drives: 2001 Mr2 Spyder
Member of Heya Project for Fr-S/BrZ.
Tire choice, Dash, Options list, Engine, Chassis, Suggestions; My fault Owned N/A '93 Mr2, N/A '91 Mr2, '98 Corolla, Mazdaspeed Mx-5, '07 Legacy Wagon, E90 328i well maintained and lit up on fire while driving on the freeway in traffic. |
#37 | |
ProCrastinationConsultant
most people that i've known that had a range rover or vw would laugh at that.
| The Following 2 Users Say Thank You to soundman98 For This Useful Post: | alone1i (03-01-2021), BrahmaBull1990 (03-01-2021) |
#38 | |
Howdy
Drives: 2020 BRZ PP
My 2008 Land Rover LR2 died a couple months ago. Doc called it at 140,000. The transmission slipped when cold, coil packs were exploding, and the last (new) issue was the temp gauge started bouncing and it died outside of Autozone. It also had a cool feature where the entire dash would reset sometimes going over a bump.
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
| The Following 4 Users Say Thank You to BrahmaBull1990 For This Useful Post: |
#39 |
Drives: 13 FRS
this car rides like trash after 150k.. suspension bushings dont last... OEM replacements cost an arm and a leg... or you can go the cheapo solid bushings route and pretend to be a ricer.... the ride will be even worse than a salty worn set of OEM bushings.. but you can tell your wife / passenger you "want it that way" :P :P
#40 |
I'm at 180,000+ and haven't really noticed much change in the ride. Then again, it could be the frog in a boiling pot thing....
| The Following 2 Users Say Thank You to Dadhawk For This Useful Post: | alone1i (03-11-2021), soundman98 (03-11-2021) |
#41 | |
Never put much trust into any anecdotal evidence when it comes to wear and tear on a car and how many miles it will "last" anyway. Different driving styles, road/weather conditions and maintenance levels all will affect how long a car will last more than a set number of miles. Not like there is some timer hooked up to the odometer that says "OK that's 100,001 miles start breaking down".
#42 |
True, 95% of those miles (a number I made up but most likely a low estimate) are on relatively smooth, pothole free roads so it probably qualifies are "light wear and tear"
| The Following User Says Thank You to Dadhawk For This Useful Post: | soundman98 (03-11-2021) |
| Following time or mileage interval for low mileage car? | Ohio Enthusiast | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 19 | 06-08-2021 03:53 PM |
| New rims cut my 0-60 a lot more than expected | Riftur | Scion FR-S / Toyota 86 GT86 General Forum | 133 | 04-21-2017 02:28 PM |
| Seeing more than expected? | CLTBRZ | BRZ First-Gen (2012+) — General Topics | 26 | 07-09-2012 03:47 PM |
| Expected Price of car in 3-5 years? | FRSDREAMER | Scion FR-S / Toyota 86 GT86 General Forum | 72 | 03-20-2012 06:44 PM |
| Not what I expected. | Casual | Scion FR-S / Toyota 86 GT86 General Forum | 34 | 11-23-2010 07:25 PM |
