Drives: 2K19 GT86
New Intake Install and Tune
Installed the Skunk2 Powerbox. Not a bad install, took about 3 hours.. I dropped one of the MAF screws so I had to take the whole damn skid plate off to get it... Fuel (e85 tune) trims look good. I'll be doing a MAF rescale/custom tune here in the next couple weeks with a local subaru tuner so I can take the interior baffle out for more air flow.
Didn't get to drive it yet as I finished later than anticipated.. Updates after custom tune to follow. |
| The Following 2 Users Say Thank You to czellers For This Useful Post: | BrahmaBull1990 (02-20-2021), Drifter X (02-20-2021) |
#3 |
Drives: brz 2017 hksv2
That intake requires an horrible MAF scaling, specially if you remove the restrictor
if you remove it, you ll gain something in higher rpm but will be too turbolent around the maf and will require a hybrid Speed density tune and a lot of time and logs to make the car run smoothly |
#4 | |
Drives: 2K19 GT86
What i can tell you is the real time data (STFT/LTFT) looks normal. it runs good at low rpm and WOT. Ill pull a data logging file here in the next couple days to see whats up. When you say that even with the restrictor it requires horrible MAF scaling and or air turbulence, how have you measured/logged or determined that? Im sure that the removal of the restrictor would necessitate MAF re-scaling but the turbulence and MAF scaling with the restrictor seems intriguing. Ill be happy to share a log file hopefully today or tomorrow if you'd be interested in seeing what it looks like with the OFT stage2+e85 tune tomei UEL header and matching diameter catless overpipe. |
#5 |
30 minute maintenance
Drives: My18 wrxsti
Not sure what you mean here. A catless header or a catless front pipe because all overpipes are catless I believe.
#6 | |
Drives: Crapcan
Even at the same RPM and close to the same engine load you will get MAF voltages that are inconsistent since the air hitting the MAF is turbulent.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | czellers (02-24-2021) |
#7 |
Drives: 2K19 GT86
#9 | |
WIth the restrictor yes, it's more stable but not as much as stock airbox and I put anywat a bit of hybrid speed density because Maf-only was inconsistent af If you arrived to a nice compromise, i m happy for you. Be aware that if you remove the restictor though you'll have a fun time with it if you don't set some speed density up |
| Car is stalling on start after Intake+header and a tune install. | WinterWolf | Engine, Exhaust, Transmission | 6 | 10-04-2019 08:44 AM |
| What is the recommended tune for header install? | Artxjr | Engine, Exhaust, Transmission | 12 | 04-08-2019 03:00 PM |
| Calibrating my Stg1 tune after 4-1 EL header install | freerunner | Software Tuning | 51 | 08-20-2018 12:38 PM |
| OFT tune now or after exhaust install? | johno87 | AUSTRALIA | 7 | 03-02-2017 05:19 PM |
| Shop in TN or MS to install and tune turbo | brocktwalker | Southeast | 2 | 03-16-2013 09:58 AM |
