Old 02-24-2021, 12:18 PM   #15
Originally Posted by villainous_frx View Post
Of course! When the bumper comes off in the spring for the oil cooler + some lighting upgrades, the bumper plate will be replaced as well.
Going to install thgose fogs?
Old 02-24-2021, 12:50 PM   #16
villainous_frx
Off to the track!
villainous_frx's Avatar
Drives: '14 Lava 86, '13 WRB BRZ
Yes, as well as some 12-16 BRZ headlights and a modified OEM 4th brake/fog light.
villainous_frx is offline   Reply With Quote
The Following User Says Thank You to villainous_frx For This Useful Post:
Tcoat (02-24-2021)
Old 02-24-2021, 12:52 PM   #17
Oh good! I will tell my wife. She got me those fogs for Christmas and was sort of pissy I never got them put in.
Dadhawk (02-25-2021), RToyo86 (02-24-2021)
Old 02-24-2021, 01:22 PM   #18
villainous_frx
Off to the track!
I will definitely send along pictures, as well as post some here.
Tcoat (02-24-2021)
Old 02-25-2021, 01:51 AM   #19
Celica00
Celica00's Avatar
Drives: 86
Originally Posted by Pat View Post
I like this photo. It's different than most others. It tells a story. There is action, somehow, without any movement. It almost tells a story about grassroots motorsports, and has good composition and lighting. Well done!
Fellas. Find you a girl who looks at you the way Pat looks at this FRS.
(I agree though, the pic looks astounding)
Celica00 is offline   Reply With Quote
The Following User Says Thank You to Celica00 For This Useful Post:
villainous_frx (02-25-2021)
Old 02-25-2021, 10:58 AM   #20
Thank you! It's definitely one of my favorite pictures I have thus far. With the new wheels I'm looking forward to recreating this exact picture (and get back out on track ).
LOL I actually saved that one into my pictures of the car. It seemed like a fitting final shot!
Dadhawk (02-25-2021), Dzmitry (03-01-2021), villainous_frx (02-25-2021)
Old 02-27-2021, 09:15 AM   #21
Hoahao
Drives: 2014 Monogram Hot Lava
That's a wonderful picture. The lighting really brings out the curves. Hot Lava/Orange are really good colors for these cars. Course, I AM biased...
It's all about gearing and steering.
Hoahao is offline   Reply With Quote
The Following 2 Users Say Thank You to Hoahao For This Useful Post:
Tcoat (03-01-2021), villainous_frx (02-27-2021)
Old 03-05-2021, 10:20 PM   #22
villainous_frx
Off to the track!
It was warm for a few days... and now it it is cold again. Ordered a few more small parts for the FRS and she'll be good to go come spring time. Threw in a picture from the summer when it was nice and toasty. Hoping to see a number like that on the dash soon.
beltax90 (05-16-2021)
Old 03-25-2021, 01:01 PM   #23
Happy Anniversary!
KR-S (03-25-2021), thedollarbill (03-25-2021), villainous_frx (03-25-2021)
Old 03-25-2021, 11:50 PM   #24
villainous_frx
Off to the track!
Happy Anniversary!
It just popped up in my memories, 1 year ago today! First start of the season is tomorrow around 1pm, and the final parts to get everything into running order for the 2021 season will be acquired this weekend.
Tcoat (03-26-2021)
Old 04-17-2021, 10:09 PM   #25
villainous_frx
Off to the track!
Spent the last week slowly working on the car.
Installed:
Blitz oil cooler, Removed TRD USA D-tip catback for a Blitz Nur-Spec VSR, Perrin shifter bushing, Whiteline transmission mount, BRZ 12-16 headlights repinned for FRS.
Removed the GReddy x KW to go back to stock off a 2020 BRZ... for now, as well as reverting to the stock RLCA for an easier alignment at home.
General maintenance:
Cleaned TRD intake filter, swapped cabin air filter, oil change (Motul 5w30), bled brakes and trying out Project mU G-Four 335 this season.
Still to do:
Transmission fluid, differential fluid, differential bushings, new suspension, engine mounts, spark plugs, TracBox + switch panel install.
Not many pictures, still waiting on tires and to switch to my nice white Ontario plates and return these horrendous blue ones (if only I had a Hikari).
KMA KiCKz (04-19-2021)
Old 05-16-2021, 01:23 AM   #26
villainous_frx
Off to the track!
Small update from the past week.
Went for the first test drive of the season and discovered my oil temp fitting was loose… by giving the engine a nice oil coating. Shut the car down with oil pressure still, and towed it home.
With Ontario’s lockdown being extended and the car needing to be cleaned, I did the motor mounts and spark plugs I had been putting off. Probably a good thing that I did the plugs, the old ones definitely look a little worse for wear, but nothing out of the ordinary.
Old 05-16-2021, 11:21 AM   #27
If you haven't changed the plugs before then those are still the original ones!
If so they look wonderful for the mileage.
villainous_frx (05-16-2021)
Old 05-22-2021, 06:35 PM   #28
villainous_frx
Off to the track!
Installed my Trac-Box from Gerald, as well as a DIY switch panel inspired by Jeremy's series.Blue Adventures one. The new shoes were ceramic coated and then mounted by a friend. Hopefully the weather holds off this long weekend and I'm able to install them with the new suspension.
The Following 3 Users Say Thank You to villainous_frx For This Useful Post:
kevaughan (02-14-2022), NoHaveMSG (07-14-2021), Stonehorsw (07-17-2021)
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 07:52 PM
[B is for Build] BRZ resurrection build im_topher Member's Car Journals 49 03-05-2018 09:41 AM
HKS stroker kit build going onto edelbrock SCd e85 FRS - build questions Corradooo Engine, Exhaust, Transmission 2 11-25-2017 07:16 PM
Superpenguin's "Not Another Build Thread!" Build Thread superpenguin Member's Car Journals 7 06-17-2015 04:00 PM
No build date on passenger side sticker, how to determine build date? BBYZILA Scion FR-S / Toyota 86 GT86 General Forum 5 01-20-2015 10:14 PM
