Old 02-23-2021, 04:46 PM   #57
alone1i
Not pro yet
Drives: 2020 Toyota GT86
Originally Posted by RToyo86 View Post
It could be you've just grown accustomed to it.
What coating did you apply?
Most of your gloss comes from polishing the paint. Coatings and sealants do add gloss, but it's more the cherry on top.
I have done this one-
https://durasealprotection.co.nz/
alone1i is offline   Reply With Quote
Old 02-27-2021, 12:09 AM   #58
CB750F
CB750F's Avatar
Drives: 2015 BRZ WRB
If the spots appeared after it was coated give opti-coat MDR a try.(if it even bothers you) You can also clay and use iron remover on your coating, kind of unique to opti-coat. You can combo Optimum ferrex with a clay mit if you ever feel the need. Generally not required but I've seen it done by a FT86 local club member who is a certified opti-coat installer.
Consider hyper-seal once you use up your opti seal. It's a newer formula designed for coatings, specially opti-coat.
I've been using it with Optimums consumer coating gloss coat. The coating isn't all that durable but with hyper-seal on-top it still seems to be holding up pretty well on its second winter.
Like opti-seal my bottle of hyper-seal lasts forever.
I clayed the car.
I believe the shop left the water spots under the clearcoat.
CB750F is offline   Reply With Quote
Do you scrape a lot? Is it worth it? Will BRZ BRZ First-Gen (2012+) — General Topics 32 01-01-2019 02:09 AM
Clear bra scrape removal eSOLOR Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 11 01-27-2014 02:46 PM
Scrape much? Andrew360 BRZ First-Gen (2012+) — General Topics 54 12-05-2012 07:50 PM
Best way to repair this scrape on my FR-S jflogerzi Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 08-11-2012 08:14 PM
Nooo, first scrape :( ubersoph Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 0 06-12-2012 12:07 PM
