Old 02-15-2021, 07:14 PM   #1
Clay_from_Verus
Clay_from_Verus's Avatar
Drives: 2013 Subaru BRZ
Arrow Aero'd Out Subaru BRZ Track Build
Ever since I joined the forum, I have been scrolling through the Member's Car Journals looking for new ideas and what modifications I want to do next. With this being said, I'd like to dive into my personal build a little bit and hopefully can offer some ideas for other members.
I purchased my BRZ back in October of 2015. One of my best friends drove me a couple of hours west to Hamilton, Ohio, where Bilstein of America is located. I purchased the car from a Bilstein engineer, so I was lucky enough that the car already had Bilstein B16 coilvers installed. Apart from the coilovers, the car was bone stock. Below is a photo of my first day of ownership.
If you know me well enough, you know the car didn't stay stock for long. In the following thread, I will go through everything that has been modified on the car to date.
Above is a photo of how the car currently sits. Below is my complete build list along with some photos of said components.
Aerodynamics
  • Verus Engineering V1X
  • Verus Engineering Composite Adjustable Front Splitter with Professional Awesome Splitter Diffusers
  • Verus Engineering 2013-2016 BRZ Air Dam
  • Verus Engineering Splitter Endplates
  • Verus Engineering Dive Plane Kit
  • Verus Engineering Hood Louver Kit
  • Verus Engineering Carbon Side Marker Delete Kit
  • Verus Engineering Composite Side Splitter Kit
  • Verus Engineering Composite Rear Spat Kit
  • Verus Engineering Trans Tunnel Cover
  • Verus Engineering Aggressive Rear Diffuser
  • Verus Engineering Rear Suspension Cover Kit
  • TRD Style Ducktail
Engine
  • GrimmSpeed Cold Air Intake
  • Tomei Expreme UEL Header
  • Invidia N1 Cat-Back Exhaust
  • Delicous Tuning Flex Fuel Kit
  • Racer X Oil Cooler Kit
  • Tune by Marin Nelson
  • Verus Engineering ECU Bracket/Fuel Rail Covers
  • Verus Engineering Bellhousing Cover
  • Verus Engineering Front Cam Sensor Cover Kit
  • Verus Engineering Air Oil Separator
  • Verus Engineering Rear Cam Cover Block Kit
  • Verus Engineering AOS Drain Back Kit
  • Verus Engineering AOS Coolant Add-On Kit
  • Verus Engineering Throttle Pedal Spacer
Suspension
  • Bistein B16 Coilovers
  • Verus Engineering Camber Plates
  • Verus Engineering Rear LCAs
  • Eibach 2-Way Adjustable Anti-Roll Kit
Wheels, Tires, and Brakes
  • Enkei NT03 (18"x9.5" +40)
  • Bridgestone Potenza RE-71R (255/35)
  • Verus Engineering Brake Cooling Kit
  • Hawk HP+ Brake Pads
I'm sure there is something I am forgetting, but that's my build in a nutshell.
Clay_from_Verus is offline   Reply With Quote
The Following 15 Users Say Thank You to Clay_from_Verus For This Useful Post:
bhmax (02-21-2021), Cephas (05-23-2021), Clipdat (07-12-2021), Code Monkey (02-15-2021), Copy (02-22-2021), DIY (02-15-2021), DustinS (02-16-2021), Jdmjunkie (02-15-2021), Joveen (02-16-2021), Lonewolf (02-24-2021), mrg666 (02-16-2021), Racecomp Engineering (02-18-2021), soundman98 (02-15-2021), tintumz22 (02-21-2021), WORKS (02-19-2021)
Old 02-21-2021, 05:15 AM   #2
Purist
Purist's Avatar
Drives: Subaru BRZ
Cool as. Is this for time attack or what?
Sent from my SM-G973F using Tapatalk
Less More
Purist is offline   Reply With Quote
Old 02-21-2021, 11:41 AM   #3
Milhouse86
Noob
Milhouse86's Avatar
Drives: 13' FRS, 13' F150, 17' A4, 69' 442
Damn, I'm jealous! Nice build!
Any pics on track? Where do you go? I am just a couple hours from Verus up in Michigan.
Sent from my Pixel 4 XL using Tapatalk
-2013 FRS/Black (Motor Blown/Under Construction)
http://www.ft86club.com/forums/showthread.php?t=135599
-1979 Trans AM/Black (Sold) -1969 Olds 442/Orange with white racing stripes - 2017 Audi A4/Black
Milhouse86 is offline   Reply With Quote
Old 02-23-2021, 04:17 PM   #4
Clay_from_Verus
Yes, eventually it will be used in time attack events. Currently, it is just my fun track toy.
Old 02-23-2021, 04:19 PM   #5
Clay_from_Verus
Thank you! I have a few photos, but we are members at Putnam Park Road Course, so we go out there quite often.
The Following 2 Users Say Thank You to Clay_from_Verus For This Useful Post:
Clipdat (07-12-2021), Lonewolf (02-24-2021)
Old 02-23-2021, 07:18 PM   #6
NathanielSproul
Drives: 2017 BRZ
Wow, it looks real good. Big fan of how that wing looks.
NathanielSproul is offline   Reply With Quote
Old 02-26-2021, 12:22 PM   #7
Clay_from_Verus
Thank you!
Old 05-23-2021, 06:10 PM   #8
in_sherman
Drives: 2017 BRZ Performance Package
how is cornering balance at high speed? large rear wing !
in_sherman is offline   Reply With Quote
Old 05-23-2021, 08:01 PM   #9
jflogerzi
jflogerzi's Avatar
Looks good. Still using stock brakes setup?
2013 Series 10 FRS #553
Old 07-05-2021, 10:17 AM   #10
VerusEric
VerusEric's Avatar
Drives: BRZ, STI, GT350R, Supra, 987.2
It depends on your driving style. I personally liked the rear wing at lower angles of attack and the front setup was generating enough to balance out the V1X rear wing.
Yes, he is still using factory brakes with upgraded pads, fluid, and our brake cooling kit.
VerusEric is offline   Reply With Quote
The Following User Says Thank You to VerusEric For This Useful Post:
in_sherman (07-14-2021)
subaru brz, verus engineering
Verus Engineering Brake Cooling Kit VerusEric Suspension | Chassis | Brakes -- Sponsored by 949 Racing 100 07-15-2023 11:18 PM
Modular Hood Louver Kit - Verus Engineering VerusEric Cosmetic Modification (Interior/Exterior/Lighting) 276 07-08-2023 05:03 PM
DIY: Verus Engineering Brake Cooling Kit thekevinvo DIY (Do-It-Yourself) Guides 0 09-29-2020 06:10 PM
Verus Engineering and FT86SpeedFactory Time Attack Build VerusEric Tracking / Autocross / HPDE / Drifting 30 03-04-2020 04:38 PM
Front Splitter Endplates - Verus Engineering VerusEric Cosmetic Modification (Interior/Exterior/Lighting) 46 08-10-2016 11:54 PM
