Old 02-23-2021, 10:26 AM   #15
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
Originally Posted by gm5oh View Post
Issue resolved! It was the spark plug. Plug gap was also 0.29 instead of factory 0.32. The car runs smoothly now! Thanks for all your help guys.
Awesome! Did they come in a pack and one was that far off??
Dzmitry is offline   Reply With Quote
Old 02-23-2021, 12:30 PM   #16
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
That's interesting. Too wide a gap can cause misfires under load as the cylinder pressures increase to the point the coil can't generate enough ooooommph to jump the gap. I'm surprised that too narrow a gap (particularly .03" too narrow) could do that. Glad you got i resolved - that kind of problem can be maddening.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
The Following 2 Users Say Thank You to Capt Spaulding For This Useful Post:
Dzmitry (02-24-2021), gm5oh (02-23-2021)
Old 02-23-2021, 09:20 PM   #17
gm5oh
Yep, that's what happened. I ordered all four together initially.
gm5oh is offline   Reply With Quote
The Following User Says Thank You to gm5oh For This Useful Post:
Adjusting AFR with Engine Load Compensation (instead of Load Limits) Tor Software Tuning 33 08-17-2021 08:58 AM
Misfire problem Anar1988 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 11 12-14-2020 11:35 AM
Misfire with heat? bigjake Issues | Warranty | Recalls / TSB 2 04-28-2013 09:02 PM
Misfire Jono AFRICA 49 12-12-2012 06:01 AM
