Old 02-22-2021, 09:51 PM   #75559
spike021
spike021's Avatar
"Panic attack" during an interview?
How did that surface (what caused it)?
Partly I'm out of practice. I haven't practiced the type of coding problem he was asking me to do since I interviewed for the current job.
I had figured when they said coding questions for this internal transfer opportunity, it'd be more like discussing code I've written here for my current team or work on a relevant problem for this new team. Not just a straight-up typical challenge problem that's asked of people interviewing to every new job.
So while I'd seen this problem before, I hadn't practiced it recently and the pattern recognition for thinking through how to solve it was rusty. Some people can still solve stuff like that on the spot, but I got anxious.
Also, in general when it comes to these types of interviews I've just always felt fairly insecure and unskilled because they're usually styled at one type of vague, very unrelated problem solving on the spot, which I'm not good at. Rather than the kind of problem solving that is actually relevant to the job itself.
The last time I interviewed when I got my current job back in Dec. 2019, it was a full day on-site with 4 one hour segments, each with a different person. Did fine with 3/4 of them, panicked on one.
I'm mostly out of practice, which makes the fear/anxiety problem worse. And it's difficult to spend time outside of work practicing because we're in crunch mode on some projects.
Most people you ask would say the typical software engineer interviewing process is incredibly awful, but there's not really a better way either.
The sad thing about this scenario is just that since I already went through that process, I was hoping/expecting that with this being internal, my earlier interviews would have counted and these would be more relevant to the role itself, which they clearly are not.
Instagram: @spike.grc
spike021 is offline
The Following User Says Thank You to spike021 For This Useful Post:
humfrz (02-23-2021)
Old 02-22-2021, 09:59 PM   #75560
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Sounds like you need to do a poll
Haha if you guys wanna know. Current name lists are:
Fiona
Artoria
Elise
Aura
Sonia
Aria
Mia
Vanessa
Sena
Sydney
Lily
Rin
& yes, a lot of name that ends w “a” lol
ichitaka05 is offline
The Following 3 Users Say Thank You to ichitaka05 For This Useful Post:
NoHaveMSG (02-22-2021), ScoobsMcGee (02-23-2021), spike021 (02-22-2021)
Old 02-22-2021, 10:01 PM   #75561
spike021
spike021's Avatar
Fiona
Artoria
Elise
Aura
Sonia
Aria
Mia
Vanessa
Sena
Sydney
Lily
Rin
Great list of names. I'd maybe add Sophia on there. I personally don't love Fiona/Vanessa but if you're happy with them that's all that matters!
spike021 is offline
ichitaka05 (02-22-2021)
Old 02-23-2021, 12:30 AM   #75562
soundman98
ProCrastinationConsultant
soundman98's Avatar
Fiona
Artoria
Elise
Aura
Sonia
Aria
Mia
Vanessa
Sena
Sydney
Lily
Rin
wait until you see her. my brother and his wife did. they're confident in the name they chose. they individually had narrowed down their name lists to about 5 names per gender, but it's still a lot to choose from!
soundman98 is offline
ichitaka05 (02-23-2021)
Old 02-23-2021, 01:19 AM   #75563
Well, spike021, that's a shame you felt your interview went poorly.
I know nothing about software engineering, however, I have interviewed for several positions during my working days in the scientific field. Most of the executives that I have interviewed with and were hired by, held a PhD degree and most of my prospective counterparts had PhDs. I had a BBS degree (Barely a Bachelor of Science - ), so, I had to try to avoid direct scientific questions.
For example, in your case with the "typical challenge problem", I might have admitted that I was a bit rusty with that particular type of problem and would need to do a bit of research and/or brushing up to solve the problem. "HOWEVER, in the past I have successfully solved similar problems".
"FOR EXAMPLE, when I was project manager of _______, a problem arose that involved ___________. I proceeded to _____ and ______. After consulting with _____ and _____ I laid out a plan that was accepted and was successful in meeting the objective, on time, within budget. AND THEN when I was _____, my team was given the task of __________, again, I _________ by _________."
Just keep on going till the interviewer has had enough .........
This strategy may or may not work for you, in your field.
Good luck with your next interview -
humfrz is offline
soundman98 (02-23-2021), spike021 (02-23-2021)
Old 02-23-2021, 02:39 AM   #75564
spike021
spike021's Avatar
Wish it were that easy .
In these kind of interviews they don't want you to say it requires some research, even if it's just a matter of rust.
It's basically like doing a decently tough Calculus/Linear Algebra/whatever problem, closed-book/notes/etc. You need to be able to perform on the spot. Generally they'll say something like "it's ok, we can walk through it together." But the results of that vary. Sometimes the interviewer means that and will gladly help you and that help doesn't negatively affect how they report the interview went. Sometimes depending on the interviewer, they'll be more like "I had to help this guy on this part or that part, which I think are too easy so they shouldn't have had issues with it" and it will reflect negatively.
You can't really BS it, either.
spike021 is offline
humfrz (02-23-2021)
Old 02-23-2021, 07:25 AM   #75565
That's what we did with all three of ours. Well, the first two we didn't find the sex out in advance, MomHawk wanted to find out at birth, so that made not picking out a name in advance easier. The third we did find out in advance.
In all cases, we had a few names picked out, and even with that, only used 1 of the selected names after the birth.
Dadhawk is offline
ichitaka05 (02-23-2021), soundman98 (02-24-2021)
Old 02-23-2021, 07:50 AM   #75566
Fiona
Artoria
Elise
Aura
Sonia
Aria
Mia
Vanessa
Sena
Sydney
Lily
Rin
Ok so why not save a name that is at risk of becoming extinct?
How about a nice Fannie or Bertha?
https://wehavekids.com/baby-names/En...ve-Disappeared
Tcoat is offline
Old 02-23-2021, 08:28 AM   #75567
"An SUV should not be capable of handling like this." These will be popular cop cars.
Back to the discussion about the Durango Hellcat, looks like GM may be getting into the SUV HP wars with a supercharger for its big SUVs (Escalade, Tahoe, Suburban).
Oddly enough, its likely to be a dealer add-on! It won't top the Durango but 620HP or so is nothing to sneeze at. I think with the suspension changes they've made to the big SUVs it would be an interesting (but still very dangerous) driver.
Dadhawk is offline
Tcoat (02-23-2021), Ultramaroon (02-23-2021)
Old 02-23-2021, 08:54 AM   #75568
ichitaka05
Site Moderator
ichitaka05's Avatar
Extinct? Out of 18, I know 10 that has that name.
Old 02-23-2021, 08:55 AM   #75569
So do I but they are all about 80 years old!
Tcoat is offline
Dadhawk (02-23-2021), Ultramaroon (02-23-2021)
Old 02-23-2021, 08:57 AM   #75570
ichitaka05
Site Moderator
ichitaka05's Avatar
Well, you’re around that age, that’s why. Edna is 60? But the rest are <30 for me.
Old 02-23-2021, 09:19 AM   #75571
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
Fiona
Artoria
Elise
Aura
Sonia
Aria
Mia
Vanessa
Sena
Sydney
Lily
Rin
Rin, because if you get a pet and name him Obito she will always take care of him.
spcmafia is offline
The Following User Says Thank You to spcmafia For This Useful Post:
Old 02-23-2021, 09:54 AM   #75572
ichitaka05
Site Moderator
ichitaka05's Avatar
Haha Naruto... but I think my wife chose Rin from this
