Old 02-18-2021, 02:33 PM   #491
Petah78
Drives: 2022 BRZ sport-tech
Originally Posted by Goingnowherefast View Post
Man, the NC's are just a great deal now that the NA/NB's have appreciated in value so much. Honestly, I'm not a huge advocate of the 2.5L swap, simply because you go from a completely forged internal motor (09+) to a commuter engine with mostly cast parts. The 09+ NC's handle boost really well with street cars doing up to 400 whp stock block, and reliable track cars doing 250-300 whp. The early transmissions can be the weak link at those power levels though.
I have noticed that the cost of NA/NB have gotten significantly more expensive. Does FM make a turbo kit for the NC? What other boost options are there? I have not read about the 2.5L too much but is it a drop in affair that uses OEM engine mounts? Basically, it just places the factory 2.0L?
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ
Current: 22 BRZ, 00 S2K - #0220
Petah78 is offline   Reply With Quote
Old 02-19-2021, 09:40 AM   #492
Tokay444
Originally Posted by gtpvette View Post
I am so glad you posted this. In the current C&D they posted a dot chart where dots were price of cars versus times, the same dot chart as in this article. What I wanted to know was what were the 4 models of the light blue dots ($35k-$64K) in the sub 2:55 class. Now I know.
Mustang Shelby GT350R 2016
Corvette 2014
Mustang PP2 2018
Camaro SS 1LE 2017
That base C7 beat a lot of higher priced hardware!!!
That Camaro SS 1LE 2017 isn’t a V6.
Old 02-19-2021, 10:16 AM   #493
Goingnowherefast
Drives: AP2 S2000, 91 Miata 1.8L Rotrex 5MT
FM does not make a turbo kit for the NC. Unfortunately the work required to make the 2.5L work in the NC is WAY more than say swapping a 1.8L VVT engine into a NA Miata. Here's all that needs to be done:
1. Remove oil pan, valve cover, intake manifold, all accessories from 2.5L
2. Remove sensor between cyl 2/3
3. Transfer VVT solenoid gasket from 2.5L valve cover to 2.0L valve cover
4. Install balance shaft delete plug and delete balance shaft
5. Cut notch on timing cover
6. Port match the intake manifold runners via dremel or grinder and use RTV to seal cylinder head
7. Transfer 2.0L accessories, wire harness, motor mounts to 2.5L
8. Swap VVT solenoid connector
9. Transfer crank pulley, replace diamond washers
10. Install clutch/flywheel
That's ONLY the required things to get the swap working let alone refining it. IDK to me it seems like a lot of work for 7 HP and some torque. Not to mention, now you have an engine without a balance shaft (I'm actually a powertrain NVH guy so this is a big deal to me haha). Fab9 tuning has probably the most complete FI kit on the market in my opinion.
Has anyone suggested a late model RX8 for the OP yet? Honestly the 09+ cars have much better reliability and at least I find that a similarly prepped RX8 is just as if not a slight bit faster than a FT86 with similar mods. There's a local guy that's in near SCCA TT T4 spec that's like a few tenths faster than me, granted he does have a small street port.
I think his point was that there was four vehicles that outperformed their price bracket by magnitudes - one of those being the SS 1LE which share the same chassis as the V6 model.
2022 Hyundai Elantra N 6MT SCCA TT S3//Will be back in an 86 eventually
Goingnowherefast is offline   Reply With Quote
Old 02-19-2021, 10:50 AM   #494
e1_griego
e1_griego's Avatar
Drives: Many
VVT swap into an NA is mostly just wiring work, and requires expensive aftermarket ecu.
I think a 2.5 swap NC is easier and ultimately is probably a better car to run. (source:I have a VVT swapped 97 miata). NC fits bigger tire, more modern chassis, and 2.5 motor is cheap and easy.
If you're talking about an NC, though, that's spitting distance to an ft86...
The kit that I really wish existed was 2.5 swap for rx8 but that is nowhere near bolt-in.
e1_griego is offline   Reply With Quote
Old 02-22-2021, 12:35 PM   #495
WolfpackS2k
WolfpackS2k's Avatar
Drives: '12 C63 P31, '23 GRC
Fellas, please chill with the Miata conversations. Somewhat interesting, but I'm not buying a Miata. Not interested.
Put an offer in on a gorgeous and meticulously maintained C63 Friday. Owner said he wanted to think about it over the weekend. Sunday night he called me and said he changed his mind and just can't sell. Loves the car too much.
This is the 3rd car for sale in the last few months that I've shown serious interest in, to only have the owner change their minds because they love the cars too much.
The Following User Says Thank You to WolfpackS2k For This Useful Post:
CSG Mike (02-22-2021)
Old 02-22-2021, 01:14 PM   #496
jflogerzi
jflogerzi's Avatar
Well it sounds like you know what you want. Just gotta be patient. Keep searching and you will find it.
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
Old 02-22-2021, 01:18 PM   #497
Code Monkey
Drives: Subaru BRZ
E92 M3? 8,300 redline + can get it in manual.
Code Monkey is offline   Reply With Quote
Old 02-22-2021, 04:28 PM   #498
WolfpackS2k
^It's just not ticking the right boxes for me.
Oh I didn't say 3rd C63 AMG
Old 02-22-2021, 06:47 PM   #499
jflogerzi
jflogerzi's Avatar
EDITED
Old 02-23-2021, 01:50 AM   #500
Jordanwolf
Rice King
Jordanwolf's Avatar
Corvette 2014
Mustang PP2 2018
Camaro SS 1LE 2017
Pricing brackets make little to no sense.
Glorious Honda.
Jordanwolf is offline   Reply With Quote
Old 02-23-2021, 08:14 AM   #501
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
Ah, one of these guys.
The V6 Camaro w/ 1LE absolutely destroys our cars by an LOL 14+ seconds in car and drivers lightening lap competition (https://www.caranddriver.com/feature...storical-data/). Actually, it beats our cars by every single performance metric available. Lol indeed.
That's not really a good point. Pretty much anything with power can wreck our cars on that track layout. I bet 5000 pound v8 SUV's could beat the twins time.
why? is offline   Reply With Quote
The Following User Says Thank You to why? For This Useful Post:
Tokay444 (02-23-2021)
Old 02-23-2021, 09:34 AM   #502
Goingnowherefast
No worries. The reason it comes up so often is it's just by far the closest thing to the twins on the market today.
Well, they did lol. Looks like the Porsche Cayenne Turbo, and the Lamborghini Urus beat the twins by way more than 10 seconds. But yeah, VIR is a different track than most of the others around the USA so take it with a grain of salt for sure.
The Following User Says Thank You to Goingnowherefast For This Useful Post:
why? (02-23-2021)
Old 02-23-2021, 12:05 PM   #503
WolfpackS2k
But VIR is my home track, so it's certainly relevant to me!
Also nobody should care what a 5000 lb car can do around a track. (car or SUV). The brakes and tires will be cooked within a few laps and/or need to be replaced. It's just folly.
The Following 3 Users Say Thank You to WolfpackS2k For This Useful Post:
Goingnowherefast (02-23-2021), Tokay444 (02-23-2021), why? (02-23-2021)
Old 02-23-2021, 12:52 PM   #504
why?
why?'s Avatar
Drives: series.blue
It's just a power track.
It's really close to me, but don't they change configurations a lot? I need to go some day.
brz, cayman, s2000
2013 981 Cayman ironchef Other Vehicles & General Automotive Discussions 49 12-09-2012 07:03 PM
FR-S vs Cayman colganc FR-S / BRZ vs.... 102 09-13-2012 04:17 PM
GT86 vs. 370 vs. Cayman S wrxgoose FR-S / BRZ vs.... 0 08-27-2012 11:26 PM
FRS/brz VS Porsche Cayman jurjurson FR-S / BRZ vs.... 22 08-15-2012 04:14 PM
FR-S, Cayman S, & Lexus GS Mcdj18 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 17 06-23-2012 04:49 PM
