Old 01-15-2020, 09:55 PM   #71
mkodama
86 Challenge
Drives: 2017 BRZ
To answer the question, holding the OFF button on a 2017+ car disables everything, including the “brake LSD” the previous cars needed the pedal dance to disengage. This only applies to manual cars and not automatics.
See bottom row of chart on page 254 in a North American 2017 manual. Picture attached.
EDIT: Subaru's Electronic Brakeforce Distribution EBD remains on; this electronically varies brake force between front axle and rear axle under hard, sudden braking.
mkodama is offline   Reply With Quote
The Following User Says Thank You to mkodama For This Useful Post:
dowroa (02-18-2021)
Old 02-18-2021, 10:15 AM   #72
Sphinx
Drives: 18 BRZ PP & 99 Spec Miata
So, Track Mode keeps a minimum level of stability and traction control on - correct?
And holding the Trac button down for a few seconds = the old pedal dance, correct?
Does ice mode show up in post 17 cars in any use case?
2018 BRZ 50th Anniv Performance Package, stock
1999 Spec Miata
Sphinx is offline   Reply With Quote
Old 02-18-2021, 01:19 PM   #73
Goingnowherefast
Drives: AP2 S2000, 91 Miata 1.8L Rotrex 5MT
Originally Posted by Sphinx View Post
So, Track Mode keeps a minimum level of stability and traction control on - correct? Yes.
And holding the Trac button down for a few seconds = the old pedal dance, correct? Yes.
This is how I understand it. Not sure about snow mode.
2022 Hyundai Elantra N 6MT SCCA TT S3//Will be back in an 86 eventually
Goingnowherefast is offline   Reply With Quote
Old 02-18-2021, 01:30 PM   #74
Mike_ZN6
Mike_ZN6's Avatar
Drives: 2016 Toyota 86
Has anyone experienced weird behavior from traction control when running big break kits? I noticed there are 2 different part numbers for the ABS module that controls traction control (Track Mode), 1 for non-Brembo equipped cars and 1 for Brembo equipped cars. I am trying to figure out what these modules could be doing differently and whether there could be issues running a BBK or PP Brembos with the wrong ABS module.
Mike_ZN6 is offline   Reply With Quote
Old 02-18-2021, 11:43 PM   #75
HSC
Drives: Whiteout FR-S
Not the PP Brembos but I have the Stoptech ST40 front bbk on 13MY with 17MY ABS module...no problems so far after 6 mo and maybe 5k miles.
HSC is offline   Reply With Quote
The Following User Says Thank You to HSC For This Useful Post:
Mike_ZN6 (02-19-2021)
Old 02-19-2021, 08:57 AM   #76
Breezio
Breezio's Avatar
Drives: 2017 BRZ series.yellow
Holding the off button does not disable EVERYTHING.
I can't tell you the name or function of what remains on, but if you get the car sideways far enough for long enough, you get a flashing light on the dash and the car intervenes. I've had it happen multiple times when intentionally drifting.
And a few times when autocrossing.
Breezio is offline   Reply With Quote
The Following User Says Thank You to Breezio For This Useful Post:
CSG Mike (02-19-2021)
Old 02-19-2021, 10:57 AM   #77
ZDan
ZDan's Avatar
Drives: '23 BRZ
Funny, on my '17 with the 3-second-hold I've never gotten flashing lights at the track with *plenty* of super-slideways action and a couple of offs. Honestly I couldn't tell much if any difference between 3-second-hold and pedal-dance, so I didn't bother with the dance. Or with the big ABS fuse pulled, which I had to do at Watkins Glen last year after ABS control module malfunction. Except that without ABS, with cold mismatched f/r brake pads and cold Hoosier A7s I could lock up a front way too easily (doh)...
Seems like I've heard/read that "EBD" remains active, but if it does it's never interfered with me on-track.
Old 02-19-2021, 12:37 PM   #78
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
The pedal dance turns off electronic brake force distribution.
I've also never had issues with the long press. Had the car drifting at full lock at the top of second on a snow course last year(for over an hour) and never had lights come on.
Also played with he pedal dance while I was there and did not notice a difference in that specific situation.
Old 02-19-2021, 01:01 PM   #79
Goingnowherefast
This is my experience too. Even with some snow drifting with huge sideways angle, there has never been any perceivable intervention.
Old 02-19-2021, 04:44 PM   #80
ermax
ermax's Avatar
Even on a 13 the long hold will not intervene regardless of how sideways you get.
Old 02-19-2021, 06:27 PM   #81
Breezio
Breezio's Avatar
I checked my videos from last season and unfortunately any of the angles that show the dash, the steering wheel blocks the area where the light is.
I do have onboard video from my buddies 2014, showing his traction light turning on multiple times within a single run, even with the 'long press'.
Also, in 'track mode'. Mine intervenes pretty quick. It's good, and I like it, but it seems to intervene sooner then the OP alluded to. I get maybe 5-10 degrees of angle and it'll jump in and straighten her out.
Old 02-19-2021, 06:35 PM   #82
ZDan
ZDan's Avatar
Drives: '23 BRZ
Forget "track mode"
The Following 2 Users Say Thank You to ZDan For This Useful Post:
Breezio (02-20-2021), CSG Mike (02-19-2021)
Old 02-19-2021, 07:22 PM   #83
Goingnowherefast
Forget "track mode"
This ^^
Friends don't let friends use track mode. It's slow.
Old 02-20-2021, 02:29 AM   #84
Breezio
Breezio's Avatar
Originally Posted by Goingnowherefast View Post
This ^^
I agree. I just brought it up because my perception of how soon it intervenes is different then the OP.
I typically use track mode for daily driving and the 'long press' for all racing.
Toyota "T" Badges For MY17 ThatAsianBradah Cosmetic Modification (Interior/Exterior/Lighting) 0 03-25-2017 04:04 AM
2013 production date cars more "reliable?" jacobzking Issues | Warranty | Recalls / TSB 64 09-30-2013 10:17 AM
Jalopnik: "10 most desirable cars of 2012" - guess who is at #1? frsinpa Scion FR-S / Toyota 86 GT86 General Forum 3 12-26-2012 11:38 AM
Switching stereo from TC to "FR-S" mode frsinpa Electronics | Audio | NAV | Infotainment 8 06-21-2012 10:48 PM
May 2010 Car&Driver issue FT-86 article - "25 Cars Worth Waiting For" JDMinc Scion FR-S / Toyota 86 GT86 General Forum 76 04-17-2010 03:58 AM
