Old 01-26-2021, 12:43 AM   #15
treedodger
treedodger's Avatar
Drives: 2022 GR86 (was 2013 BRZ)
With 245-40/17 SX2, at 33-34psi hot, the tires wear really evenly, and the pyrometer reading have been about where I want them.
I'm pretty sure for 95% of the drivers out there, they have bigger gains to be had with driver mod vs. optimal tire pressures. For all but the fastest drivers, I would suggest set the tire pressure to 34hot, and focus on your driving. But if you want to optimize your tire pressure, go for it, and let us know what you find.
Maybe the SX2 is just not very sensitive to pressure, given it's stiff carcass?
Originally Posted by Pat View Post
Abe and I were talking about these hot tire pressures that set lap records in SoCal. We still struggle to understand how this is possible given our data. I could understand one or two PSI difference but six is really difficult to comprehend. Especially when I can feel 35 is too hot relative to 34. I have a lot to learn.
2022 GR86 / 2013 BRZ
86drivechallenge.com/
treedodger is offline   Reply With Quote
Old 01-26-2021, 09:28 AM   #16
Pat
Pat's Avatar
Drives: 2023 BRZ
I've spent significant time monitoring temperatures and pressures. I have not used a probe-style pyrometer, but have done things many others typically do not, including logging the temperature of each tire in three different places in real time. That data is shown in Track Addict and compared with all of the other data available.
See here: https://forums.nasarockymountain.com...the-track.263/
The Following User Says Thank You to Pat For This Useful Post:
jflogerzi (01-26-2021)
Old 01-26-2021, 09:35 AM   #17
jflogerzi
jflogerzi's Avatar
Wow that's really cool. Hard to see images as you need a login to see attachments. I will give your range a try. I have been trying to sit around 30-32psi hot.
2013 Series 10 FRS #553
Old 02-09-2021, 05:40 AM   #18
tankslapper
Drives: None
Do you think it's possible that altitude might be the reason for the difference in PSI?
https://www.tirerack.com/tires/tiret...jsp?techid=167
tankslapper is offline   Reply With Quote
Old 02-09-2021, 09:18 AM   #19
Pat
Pat's Avatar
Drives: 2023 BRZ
Possible but unlikely.
Old 02-13-2021, 03:23 PM   #20
Jstyle
Jstyle's Avatar
Drives: 2020 86
Just outta curiosity... How many miles do these tires last? The FRS I bought has some really bald Kuhmo P31s and while most of my miles will be track... Just wondering how long they last for.
Jstyle is offline   Reply With Quote
Old 02-14-2021, 11:39 PM   #21
jflogerzi
jflogerzi's Avatar
They last a good amount and because they under 500$ for a set they are great all around daily tires.
Question for BRZ tS owners: Raven86Project Cosmetic Modification (Interior/Exterior/Lighting) 4 04-18-2019 11:57 AM
Question for 860 owners CoolHandMoss BRZ First-Gen (2012+) — General Topics 3 07-20-2018 11:20 AM
A question to all you SC owners McG86 Forced Induction 18 03-22-2016 04:16 PM
Question for the the 2014 Brz Nav Owners (BT Question) jbsali Electronics | Audio | NAV | Infotainment 3 07-16-2014 11:41 AM
Question for HOUSTON Fr-s owners and/or to be owners enjoi23 Southeast 2 08-30-2012 09:48 PM
