Old 05-27-2014, 09:56 AM   #43
blackhawkdown
blackhawkdown's Avatar
Drives: 2012 WRX, 2003 RSX Type S
I'll post a picture later when I feel like getting off my fat ass.
Originally Posted by fatoni View Post
saying they wanted to add weight to improve handling is like saying people wear condoms to improve sex.
blackhawkdown is offline   Reply With Quote
The Following User Says Thank You to blackhawkdown For This Useful Post:
blackfireball5 (05-27-2014)
Old 02-10-2016, 02:15 AM   #44
Joaco
Joaco's Avatar
Drives: White Stock FR-S
Im more interested on how did you mount the oil cooler there.
Part list and oil tubing routing!
Joaco is offline   Reply With Quote
Old 12-06-2020, 11:31 AM   #45
Lonewolf
Lonewolf's Avatar
Drives: Moped
Bump for new members...
Old 01-22-2021, 03:26 AM   #46
jeepmor
Drives: 84 CJ7, 08 Duramax, 2014 FRS
Didn't see Gorilla glue epoxy mentioned. I'd try gluing flat head bolts like this down with it for a project like this. After a good scuffing prep course.
jeepmor is offline   Reply With Quote
Old 01-22-2021, 07:31 PM   #47
86TOYO2k17
Drives: 2017 toyota 86
Not sure i see the point of this
Old 01-22-2021, 07:43 PM   #48
86TOYO2k17
I did this on the 86, the opening isn’t ideal for a track setup but more than adequate to handle a lot of abuse for a street setup on a boosted 86.
I later added fans with switches I could turn on and off. The fans worked incredibly well almost too well for the street.
I combined it with the “oem” oil to water heat exchanger and 197f thermostat. Combined with the limited non direct air flow from smaller opening it warmed up to 170f in any weather conditions essentially as fast as stock. Then kept the oil nice and cool once thermostat started opening. Adding the fans just enhanced both of these factors. worked incredibly well overall.
Here’s a few pics. Bigger one is oil smaller one ATF.
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
Lonewolf (01-27-2021)
Old 01-22-2021, 09:07 PM   #49
jeepmor
Fair enough. Figured it could be cleaner and stronger than just glopping glue on it was all.
Old 01-22-2021, 10:54 PM   #50
86TOYO2k17
I just used a bead of JB Epoxy Adhesive Plastic Bonder fully around the outside edge of the mesh wire. The epoxy is black and hardens to pretty much blend perfectly with the bezel. Makes it look like it’s how it came from factory.
Old 01-25-2021, 04:53 AM   #51
Aust86
Drives: GT86
can you share a close up photo? Thanks
Aust86 is offline   Reply With Quote
Old 02-12-2021, 11:33 PM   #52
airrick
Drives: TRD R.S. 1.0 FRS
Where did you get those wheel well vents from?
airrick is offline   Reply With Quote
Old 02-13-2021, 12:23 AM   #53
86TOYO2k17
White Water ABS Black Plastic Louvered Vent https://www.amazon.com/dp/B06VTB7T3F...ing=UTF8&psc=1
airrick (02-13-2021)
Old 02-15-2021, 02:13 AM   #54
airrick
not to bug you with more stuff but where did you get the bendable thin metal strips? i got some pretty thick strips of metal that can't really be bent easily.
Old 02-15-2021, 10:17 AM   #55
86TOYO2k17
No worries,
Home depot by the wood/fencing stuff.
You can also stack 2 or 3 together if you wanted it more rigged, but because I have them mounted on different axis to each other and the oil cooler isn't that heavy it was stout enough for me, I also zip tied 2 anchor points on the bottom, so pushing on it pretty hard didn't budge it in any direction at all.
I used rivnuts to secure them to the vehicle. Drilled a hole in the crash bar for one side, the other side already had a perfect hole.
airrick (02-16-2021)
**Toyota 86 Fog Light Bezels $34.9, 86 Arm Rest, GT86 Badge, Fog Light Set for $112.9 nigel-jdmparts Exterior Parts - The Rest 524 02-28-2016 11:24 AM
WTB: fog light bezels natesparxxx Exterior Parts (Aero, Lighting, Etc.) 1 03-20-2014 12:44 PM
Pair of FR-S fog light bezels speedrye Exterior Parts (Aero, Lighting, Etc.) 2 02-21-2014 02:28 AM
Installing JDM Fog Light Bezels knewsom32 Cosmetic Modification (Interior/Exterior/Lighting) 13 01-22-2014 02:29 PM
Color matched fog light bezels NyC Zn6 Cosmetic Modification (Interior/Exterior/Lighting) 1 06-05-2013 01:10 AM
