Old 01-27-2021, 01:58 PM   #253
Anthonyc777
Drives: White Toyota 86
While I can't confirm the exact fitment for the PP calipers, the new Konig Hexaform 17x9 +40 clears my RR Racing Sport Calipers which are on the thicker side and I am using PP rotors. It clears them by a little over half an inch. I attached the template for my calipers if there is one for the PP that you can compare.
Anthonyc777 is offline   Reply With Quote
Old 02-09-2021, 09:09 AM   #254
cmiovino
cmiovino's Avatar
Drives: 2017 BRZ PP, 2004 WRX
2004 STI 17x7.5 +53
I can confirm 2004 STI 5x100 17x7.5 +53 do fit with the stock suspension, but just barely. There will be slightly more clearance than stock for the Brembos, but with 225/45/17 RE-71R, the tire to front strut clearance was down to 1-2mm because of offset and -1.3* camber. Tires that run wide might be an issue and need a 3mm slip on spacer, or you'd need to run less camber.
cmiovino is offline   Reply With Quote
Old 02-10-2021, 07:30 PM   #255
Sphinx
Drives: 18 BRZ PP & 99 Spec Miata
I don't see the TR Motorsports C4 rim for the SSC class. Anyone know if it clears the PP brakes?
2018 BRZ 50th Anniv Performance Package, stock
1999 Spec Miata
Sphinx is offline   Reply With Quote
Old 02-15-2021, 01:42 PM   #256
abyssFT86
Drives: 2020 BRZ Limited
Does anyone know if the Apex EC-7R 17x9 +35 fits on performance package "out of the box"? It looks like it might require a little bit of negative camber, wasn't sure.
abyssFT86 is offline   Reply With Quote
Old 02-15-2021, 06:08 PM   #257
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
They will fit over Brembos. They will fit over PP shocks, but you probably won't be able to get much camber by using camber bolts. You might want to get offset top hats or adjustable camber plates to dial in some camber and improve grip and prevent rubbing against the fender. As a free bonus, this will give you better fitment.
There's a thread dedicated to APEX EC-7R wheels already on this forum if you have more detailed questions.
Old 02-16-2021, 11:02 AM   #258
abyssFT86
Thank you! Do have a few follow ups but will ask them there for better visibility.
Old 02-18-2021, 11:30 PM   #259
Joe-G
Canada Eh!
Joe-G's Avatar
Drives: '13 FRS
Superspeed RF03RR
18x9.5 +38
Do NOT fit. Will need 3mm spacer to prevent contact with caliper.
Joe-G is offline   Reply With Quote
Old 02-19-2021, 11:28 PM   #260
Joe-G
Canada Eh!
Joe-G's Avatar
Drives: '13 FRS
Rays Engineering Volk Racing
ZE40 18x8.0 +45
Fits front performance package calipers, no spacer needed.
Old 02-19-2021, 11:30 PM   #261
Joe-G
Canada Eh!
Joe-G's Avatar
Drives: '13 FRS
ZE40 18x7.5 +48
Does not fit as-is!
Does not fit with 3mm spacer!
Fits with 6mm spacer (two 3mm stacked) - will probably work with 5mm spacer.
Old 03-04-2021, 01:38 PM   #262
N_Raged
Drives: 2019 BRZ Sport-Tech RS
Originally Posted by Enti.Moose View Post
Hey Timurrrr, just wanted to give you a massive thanks for this thread.
I have another set of wheels to add to the list:
Enkei TS9 17x8 +45 (White BRZ - stock suspension) - will clear Brembos
Enkei TS9 17x9 +45(Series Gray? - stock suspension) - will clear Brembos but I believe tires will will rub at full lock on a grade. (5mm spacer recommended.)
Credits to CC and TK from a BRZ/FRS/86 FB group.
I believe these are Enkei TFR, not TS9 which has 9 spokes. Can someone confirm?
N_Raged is offline   Reply With Quote
Old 03-11-2021, 07:13 PM   #263
Blitz_86
Blitz_86's Avatar
Drives: Angie
I currently have the caddy brakes, does anyone know if motegi traklites 17x8 clear the brakes ?
Blitz_86 is offline   Reply With Quote
Old 03-24-2021, 02:21 AM   #264
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Rays G25 18x8 et45 5x100 fit, according to Rays Japan website:
Old 03-24-2021, 02:33 AM   #265
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Originally Posted by samagon View Post
for whoever needs to know, V7 sti wheels clear.
Please provide more info on these wheels. Are they from Subaru STI (if so, which years?), or some other kind of sti? What are the dimensions?
Old 04-24-2021, 07:16 PM   #266
N_Raged
Enkei TS-10 17x8" ET45
I couldn't find any photos of the 17x8" TS-10 on this car with Brembos so I messaged Enkei themselves and they said they do clear Brembos. I took their word for it and placed an order. There's around 2.5mm of clearance at the closest point which should be fine. My car's suspension is completely stock.
brz, performance package, wheels
Finding wheels to clear brembos jojosbrz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 11-13-2018 08:46 AM
Performance package Brembos Ernest72 Want-To-Buy Requests 2 07-14-2018 08:06 AM
Performance Package Brembos Freezing to Wheels? texastwurkt3am Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 02-23-2018 08:31 AM
What pads fit the Performance Package Brembos? mistople Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 01-03-2018 05:15 PM
