View Poll Results: What should Tcoat have for lunch today?
hamburger 62 33.70%
hot dog 44 23.91%
other (please specify in comments) 29 15.76%
why is this even a thread? 72 39.13%
Multiple Choice Poll. Voters: 184. You may not vote on this poll
Old 02-02-2021, 07:12 PM   #2339
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Originally Posted by x808drifter View Post
That looks disgusting! How could I market that. I'd be rich.
Old 02-02-2021, 07:29 PM   #2340
TEST: Can you remember what you had for supper last night?
brownchickenbrowncow
The Following 4 Users Say Thank You to Ultramaroon For This Useful Post:
humfrz (02-02-2021), p1l0t (02-02-2021), soundman98 (02-07-2021), spike021 (02-02-2021)
Old 02-07-2021, 04:06 PM   #2341
spike021
spike021's Avatar
Any cooks in here have experience with newer electric stovetops? The apartment I'll be moving to next month has a newer GE electric stovetop (probably ~5 or so years old) and I'm used to having a gas range..
Looking into it and getting apprehensive. Some sites and friends said they've used cast iron on theirs before and it works fine, but then some reviews of similar ranges say it's bad to use cast iron, and a similar range's manual (can't confirm it's the same model) recommends against cast iron.
But the only major issue I can find is that it's easier to scratch the cooking surface.
Instagram: @spike.grc
spike021 is offline   Reply With Quote
Old 02-07-2021, 04:46 PM   #2342
You might wish to check with ol @Sapphireho , no doubt he has experience up there, cooking with cast iron on stoves -
All I know is that our GE electric stove with a glass cook top had worked good for several years - then the main burner burnt out. Just as I got a new element ($100), the glass stove top cracked in several places, plus it looks like someone took an electric grinder to it.
A new glass cook top is $250, so, it's new stove time -
Old 02-07-2021, 04:53 PM   #2343
soundman98
ProCrastinationConsultant
soundman98's Avatar
i think that's going to be the crux of the entire concept. heat is heat. electric isn't going to do anything differently to the pan that gas won't. in fact, electric is a more even heat, where gas has notable hot spots, so if there were any worries about cracking the cast iron due to uneven heating, gas is down a notch...
as i tell the new guys "don't tell the tool what it's working on, and it'll be fine."
Dadhawk (02-07-2021)
Old 02-07-2021, 05:27 PM   #2344
Is it induction, or radiant? Big diff.
I use cast iron on our induction range all the time. The ceramic surface will be scratched. Meh. It's an appliance, not a mirror. It is the most efficient and safest way to heat a pan, ever. There's a learning curve that involves understanding the detrimental effects of impedance mismatch but once the big burner is reserved for the biggest pots, available power and its control is impressive. It's possible to never burn a teflon pan again.
Old 02-07-2021, 05:51 PM   #2345
spike021
spike021's Avatar
Yeah, wouldn't surprise me if mine would need to be replaced at some point just because I don't think I can be arsed to be 100% careful.
That's what I'm thinking. Might just be a bit different in terms of use, but not results.
I tried looking around, I _think_ it's an older model of this one: https://www.geappliances.com/applian...ange-JB655YKFS
But unfortunately when I took photos of it in the demo unit I didn't grab a good pic of the model number.
Seems like it's an electric range, not induction? But I could be wrong.
The Following User Says Thank You to spike021 For This Useful Post:
humfrz (02-07-2021)
Old 02-07-2021, 06:32 PM   #2346
Dang, spike021, there you go again, worrying about stuff you don't need to be worrying about. You're renting an apartment, including the appliances, right?
As ol @Ultramaroon says - just cook on the damn thing - it's an appliance - right?
If the range goes out/cracks, just ask the super to replace it. Just tell him that, no, you never turned the big element all the way up on HI and you never used cast iron pots or pans on it.
Old 02-07-2021, 07:26 PM   #2347
Yeah, I've never owned one of those. Seems like the worst of both. Sacrifice conductive heat transfer to make it easier to clean... Invisibly gets hot AF... Scratches...
humfrz (02-07-2021), soundman98 (02-07-2021)
Old 02-07-2021, 08:25 PM   #2348
spike021
spike021's Avatar
Guess I will just need to report back in a couple months. Also, not sure if the oven uses gas or not. I'd assume it's also electric but I guess I'll find out.
As much as I dislike my (likely) 30-40 year old stove/oven, having gas burners has been great. The oven just 'works', no more / no less.
Old 02-07-2021, 11:12 PM   #2349
I agree - but mrs humfrz wouldn't.
I found nothing wrong with the electric burner/coils type stove top. To clean it just take out the pans and wash them. To replace an element, just unplug it and plug another one in. With the coils, one is less likely to lay something on top of them, like they were part of a counter top. Plus they will always scratch and look like hell, no matter how careful you are and how often you clean them -
soundman98 (02-08-2021), Ultramaroon (02-08-2021)
Old 02-07-2021, 11:49 PM   #2350
Sapphireho
Famous Potatoes
Sapphireho's Avatar
I am a gas guy.
You will learn to use and get used to any type in time. I'd rather have a nice place with a shitty stovetop, then...
The Following 3 Users Say Thank You to Sapphireho For This Useful Post:
humfrz (02-08-2021), soundman98 (02-08-2021), spike021 (02-08-2021)
Old 02-07-2021, 11:56 PM   #2351
Sapphireho
Famous Potatoes
Sapphireho's Avatar
I would love to have an outdoor kitchen with that stove. I have cooked on one.
The majority of my cast iron cooking experience is like this.
humfrz (02-08-2021), spike021 (02-08-2021)
Old 02-08-2021, 12:02 AM   #2352
spike021
spike021's Avatar
I wonder if you could polish these to at least remove minor scratches, like you would with car paint. I think it's a ceramic glass.
humfrz (02-08-2021)
dia beat us, give me your lunch money!, gone sexual, instagram your food, it's time for plot!
WHy does Tcoat try so hard ? Icanfaptothis86 Off-Topic Lounge [WARNING: NO POLITICS] 156 07-18-2019 01:32 PM
Tcoat banned? Hotrodheart Off-Topic Lounge [WARNING: NO POLITICS] 95 07-06-2019 01:46 AM
Tcoat gone? Atticus808 Off-Topic Lounge [WARNING: NO POLITICS] 2 08-26-2015 03:35 PM
Lunch Meet - 8/4/13 MannyO New England 1 08-03-2013 10:28 PM
Lunch be for Meet Mar 30 BadLuck New England 48 03-31-2013 06:24 PM
