| Engine Swaps Discussion of engine swaps. |
#15 |
Drives: 2015 FRS
Another option would be to use a DSM / EVO 1-3 / JDM Mitsubishi RVR 4G63. There are a few "bolt on" RWD transmission options for that swap (Dodge D50 / Mighty Max).
The Evo VIII and Evo IX transmissions are flipped and I don't recall them ever being used in a RWD form from the factory. https://projectzerog.com/transmissions.shtml |
#16 |
Drives: 2013 Ultramarine FR-S
Because DCT (Dual Clutch Transmission)... and it's really the only decently price DCT option on the market currently.
| The Following User Says Thank You to DustinS For This Useful Post: | wparsons (02-05-2021) |
#17 | |
Drives: 2016 Subaru BRZ
Third gear did grind(slighty), never bothered to fix it before I sold it. Clutch job took two long days on jack stands. |
| The Following User Says Thank You to Trueweltall For This Useful Post: | Xero-Limit (02-06-2021) |
#18 |
Drives: 2017 Toyota 86 MT White Drift Spec
Hey fellas.
I got a stupid question. Is there ANY possibility of connecting (somehow) together 4G63 or 4g69 engine and fr-s manual tranny. I’m getting crazy but really need it. |
#19 |
ProCrastinationConsultant
would definitely need a custom trans adapter spacer, likely also need to convert the engines output shaft to the trans' input shaft pattern.
considering no one else is putting the 4g64 in with the oem trans, it's going to require a machine shop and a large wallet.
#20 |
Drives: Q5 + BRZ + M796
Soundman means using a custom flywheel with a custom trans adapter. Your best bet is ditching the stock transmission for something stronger and that has aftermarket support, as there are already RWD adapter kits for common T56 transmissions.
| The Following User Says Thank You to Irace86.2.0 For This Useful Post: | soundman98 (10-11-2022) |
| FRS 4.8 LS swap | kurty85 | Engine Swaps | 207 | 03-03-2023 12:48 PM |
| 2JZ Swap - Looking for Labor Info from Swap Shops/XP'd Members | Cookiemonster | Engine Swaps | 18 | 05-25-2019 12:40 PM |
| Dead RB25 Swap, Alive 2jz swap | -Phil | Engine Swaps | 72 | 09-15-2018 02:35 PM |
| Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions | Dezoris | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-06-2017 10:54 PM |
| Rod Swap | protpibe | Engine, Exhaust, Transmission | 6 | 10-21-2015 11:38 PM |
