Drives: 2020 BRZ PP
Perrin 3" Resonated - Going Turbo
Hey Guys. I have a few questions. I recently bought a 2020 BRZ PP.
Ordered a JDL Turbo kit (GTX2867R) with EL Manifold. I also plan on going with a full 3" exhaust system (tuner's recommendation). I have also ordered the resonated (single) over/front pipe combo from JDL and finishing it off with a 3" Perrin resonated catback system. Since the JDL parts are 4 weeks out and the Perrin system was already in. I decided to put the system on and I do not like it. Remember I am currently fully stock. At idle: the system is very close to stock, not obnoxious at all. Going up in the revs: the system is deep but definitely has drone. Going down in the revs: the system has uber high levels of drone. My question: Will the system sound totally different after the turbo kit and over/front pipe are installed. Is there a chance all the drone is just due to having a 3" system on a stock header & front pipe??? If anyone has a turbo kit and is running the perrin system I would love to hear your feedback. Thank you in advance. |
| The Following User Says Thank You to airindia33 For This Useful Post: | YSoAggressive (07-06-2021) |
#2 |
Drives: 2015 BRZ
Interesting you might be the only person i know off that is experiencing drone from the Perrin exhaust either that or something is wrong with your install. Make sure everything is tight and check the vband connections.
Yes once you put the turbo it will sound different usually putting on a turbo quiets things down slightly ,but since you're installing an EL header and the OP/FP im sure it will have a good tolerable sound shouldn't be obnoxious. Im not running this setup so take my input with a grain of salt... Last edited by Vital; 02-02-2021 at 03:05 PM. |
| The Following 2 Users Say Thank You to Vital For This Useful Post: | airindia33 (02-03-2021), YSoAggressive (07-06-2021) |
#3 |
Rust bucket enthusiast
The car will sound different; a turbo is like a muffler. Just be patient and wait to see how it sounds
| The Following 2 Users Say Thank You to DarkPira7e For This Useful Post: | airindia33 (02-03-2021), YSoAggressive (07-06-2021) |
#4 |
Drives: 2014 BRZ Limited, Satin White Pearl
this.
'14 SWP BRZ 6MT | FBM built 9:1cr engine w/ GTX3076R Turbo | Mazworx CD009 trans swap | EcuTek | Jackson Racing Dual Oil Cooler/Radiator | SPAL fans | JDL 3" Dual Resonated OP/FP | Perrin 3" | Radium Dual Cans | 18" Rota Titans | M85 3.73 diff | DSS 1k axles | And more....too much more....ugh.
| The Following 2 Users Say Thank You to Tonrogs For This Useful Post: | airindia33 (02-03-2021), YSoAggressive (07-06-2021) |
#5 | |
Drives: 2020 BRZ PP
| The Following 2 Users Say Thank You to airindia33 For This Useful Post: | Vital (02-03-2021), YSoAggressive (07-06-2021) |
#6 |
Drives: 2015 BRZ
| The Following User Says Thank You to Vital For This Useful Post: | YSoAggressive (07-06-2021) |
#7 | |
Drives: 2020 BRZ PP
This isn't my daily driver... |
#8 |
Drives: 2020 BRZ PP
Ok so update. Finally got my full JDL kit in last week and installed this week. The install was fairly straight forward and am very happy with the gains. Unfortunately the exhaust still has a horrible drone from 2750-3400...
Any other recommendations of exhaust systems?? Would like to stay 3” or 2.75”. Don’t mind louder as long as there isn’t drone. |
#9 |
LMGTFY
Drives: 13 FRS, 91 Miata
Does the OP/FP have a CAT?
| The Following User Says Thank You to x808drifter For This Useful Post: | YSoAggressive (07-06-2021) |
#10 |
Drives: 2017 Subaru BRZ
I have the same setup as you except I went with the dual res FP/OP. Personally its just right for me.
I've heard a slightly quieter catback is the CSG one but that does step down to 2.75" https://www.counterspacegarage.com/c...tition-exhaust Heres a quick dyno pull with my exhaust
2017 Subaru BRZ PP
FBM Turbo Kit: GTX3076R - HRI FlexFuel Tune - 3" Turboback Exhaust - ID1000cc Injectors - Walbro 485 Fuel Pump - FBM Oil Pan - FBM Oil Cooler - Killer B Oil Pickup - FBM Catch Can - FBM Radiator w/Fan Shroud - Clutch Masters FX400 - Verus Clutch Fork/Pivot - IRP Shifter - Cusco Engine/Trans Mounts - RCE Yellow Springs - PS4S 245/40/17 |
| The Following 2 Users Say Thank You to MotoX16 For This Useful Post: | airindia33 (04-30-2021), YSoAggressive (07-06-2021) |
#11 |
Moutain Runner
I currently have the perrin 3inch on my turbo BRZ. No resonators in my "front pipe"
3400 rpm does have some drone, but it's much better than my Tomei I previously had |
| The Following User Says Thank You to Chuckls For This Useful Post: | YSoAggressive (07-06-2021) |
#12 |
Get the CSG Touring 86 by MXP. The minor step down in size wont restrict till 400WHP.
2013 Series 10 FRS #553
| The Following 3 Users Say Thank You to jflogerzi For This Useful Post: |
#13 | |
| The Following User Says Thank You to DarkPira7e For This Useful Post: | YSoAggressive (07-06-2021) |
#14 | |
Drives: Silver 2018 Toyota 86 GT
I also installed the same catback (Perrin 3" Resonated) this weekend and am getting a lot of cabin noise and drone, especially when cruising at those rpms. I can't say for sure this will fix my problem as my front pipe has a blown out cat. Already ordered the hangers and should get a new front pipe soon |
| The Following User Says Thank You to SumDizzy For This Useful Post: | YSoAggressive (07-06-2021) |
| FS: Perrin 3" Catted Front Pipe + Perrin 3" Resonated Cat Back | projek_01 | Canada Classifieds | 3 | 01-26-2018 10:32 PM |
| WTT: Perrin 3" Catted Front Pipe + 3" Perrin Resonated Exhaust for 2.5" Setup | projek_01 | Canada Classifieds | 3 | 03-03-2016 01:45 PM |
| TRADE perrin 2.5" non resonated catback for resonated | otterpop | Southeast | 0 | 01-22-2015 10:14 PM |
| Looking to trade resonated 3" Perrin CB for resonated 2.5 Perrin CB Sacramento Area | Brinks | Northern California | 4 | 07-22-2014 10:58 PM |
| Looking to trade resonated 3" Perrin CB for resonated 2.5 Perrin CB Sacramento Area | Brinks | Engine, Exhaust, Bolt-Ons | 6 | 07-22-2014 10:58 PM |
