Old 01-31-2021, 04:23 AM   #2479
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
i think i've been playing forza too much...
went to drive the car today, and panicked a little when i went for reverse next to and down off 6th gear...
I was addicted to FarCry mp for a while. I thought "sniper glint" one time when I saw some reflection off a can I was walking past.
Dadhawk (01-31-2021)
Old 01-31-2021, 10:01 AM   #2480
soundman98
ProCrastinationConsultant
soundman98's Avatar
years ago, i used to play a lot of call of duty. i got so used to checking corners, i would enter houses in real life and check behind the door i entered through without even thinking about it.
Captain Snooze (01-31-2021)
Old 01-31-2021, 10:53 AM   #2481
Stephen W.
Stephen W.'s Avatar
Drives: 1993 Caterham HPC Evo
You know you've been playin' too long when...
I play America's Army: Proving Grounds on PC. One evening while driving I crested a hill and as I started down the other side my headlights began to light up the reflective strips on top of the guard rail posts one after the other. Frist thing that came to mind was "draw distance."
The Following 2 Users Say Thank You to Stephen W. For This Useful Post:
Dadhawk (01-31-2021), soundman98 (01-31-2021)
Old 02-06-2021, 10:04 AM   #2482
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
With my Phanteks Evolv Shift 2, my thermals are quite horrible. But that's to be expected with a SFF build and tempered glass on both sides. So until Phanteks actually has some of the mesh panels available, I've been running with the GPU side off (computer sits on my left).
Last night I was fiddling around and thought that a slim 120mm fan could do a lot of good as another 'intake' fan. For reference, the intake fan is at the bottom with the exhaust fans at the back. Very chimney-esque. Although it's a 15mm slim fan, it should be enough to add just enough airflow. However, I will need to modify part of the chassis as I will be mounting it where an SSD up top would go. Should have the fan tomorrow so I shall post my progress!
MS, CSCS, TSAC-F, CPT
Old 02-06-2021, 07:24 PM   #2483
soundman98
soundman98's Avatar
the project for today. replacement video screen pc build.
Dadhawk (02-06-2021)
Old 02-11-2021, 04:30 PM   #2484
weederr33
weederr33's Avatar
She fit's!
The Following 2 Users Say Thank You to weederr33 For This Useful Post:
NWFRS (02-14-2021), soundman98 (02-12-2021)
Old 02-12-2021, 05:57 AM   #2485
Captain Snooze
Drives: Red Herring
Impressive, scary, maybe both.
Dadhawk (02-12-2021)
Old 02-16-2021, 07:38 AM   #2486
soundman98
soundman98's Avatar
I take my left leg out
Old 02-18-2021, 08:48 AM   #2487
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
Here it is! Is not finished and needs some improvement in the cooling area, need to move the radiator to the right side. First computer build, thank you all who recommended parts and gave info. Had to settle with an older GPU due to availability on the 3000 series NVIDIA. Here's the build specs.
ASUS Rogstrix B550
WD Black 1TB HDD
Corsair Vengeance LPX 16GB RAM
Ryzen 5 5600 X
Corsair H60 Cooling
ADATA XPG Pro 1TB NVme SSD SX8200
PNY Single Fan GTX1660 Super OC
Corsair RM 750X Modular
NZXT H510 Case
spcmafia is offline   Reply With Quote
The Following 5 Users Say Thank You to spcmafia For This Useful Post:
Dadhawk (02-21-2021), Mr.ac (02-19-2021), soundman98 (02-19-2021), Spuds (02-18-2021), weederr33 (02-19-2021)
Old 02-19-2021, 01:20 AM   #2488
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
@spcmafia
Nice. Post up the final set up. That 1660 is not bad, it's like PS4 pro level-ish.
Just got to be patient till there is more supply.
The Following User Says Thank You to Mr.ac For This Useful Post:
spcmafia (02-19-2021)
Old 02-19-2021, 09:48 AM   #2489
spcmafia
spcmafia's Avatar
@spcmafia
Thanks! The 1Q sales are supposed to settle down in April. Also, NVIDIA has downgraded the new cards so their efficacy for Ethereum mining goes down by 50%. That should stop the madness a little bit.
Old 02-20-2021, 11:51 AM   #2490
weederr33
weederr33's Avatar
Originally Posted by Jackie View Post
Yes I am here.
Welcome
Old 02-22-2021, 09:18 AM   #2491
spcmafia
spcmafia's Avatar
Build is done! Boy was it a pain to get this thing running. My problems started after the first failed boot-up. After re-verifying that my connections were good, turns out I had a bad CPU (Last resort). Great thing I bought two by mistake. After replacing the CPU, I thought my RAMs (DRAM light on mobo) were bad, so I bought another 16GB. After replacing said RAM with new stick(s), same DRAM light on MOBO was on. Re-checked connections, Google, Youtube, read the manual, Ah! Came across a section on the manual about BIOS Flashback button. Turns out that even if my Mobo supports all the components I bought, it is likely that the latest version the mobo was built with was no longer compatible with the components. I also luckily had an old 2GB USB Drive lying around, downloaded the latest drive for the mobo (verify the exact model number), take usb drive, plug usb drive, press flashy BIOS-Flashback, light goes blink blink, light goes out. TA-DA! Computer turns on, no DRAM lights, recognizes the keyboard, mouse. Now I ended up with extra 16GB of RAM which brought me to a total of 32GB, plus a broken CPU which I need to go return.
Lessons learned
-Double check connections. Triple check. Then check again.
-Might not be applicable to all motherboards, but a DRAM light on could mean two things, bad RAM or bad CPU. Most likely the latter, unless you somehow managed to discharge into the RAM during installation process. The controls for the RAM are inside the CPU, so its a 50-50 chance.
-You bought all the latest and greatest components for you brand new PC, your mobo supports said components. Might be a good idea to download the latest BIOS version of you Mobo to an USB Drive and update it before booting-up, trust me, took me HOURS to come to this realization.
-If you can afford it, buy two CPUs, or have a spare one, or even better, don't get them shipped to your house, I think mine maybe got messed up during shipping.
EDIT: Somehow my pics keep uploading sideways, apologize for that.
The Following User Says Thank You to spcmafia For This Useful Post:
soundman98 (02-23-2021)
Old 02-22-2021, 10:21 AM   #2492
Congrats on getting the build up and running. It seems there are only two options when building, unbelievably smooth or days of troubleshooting.
Yea, that's why I buy all the critical components locally, even if I have to pay a little more. Fortunately, I have access to both MicroCenter and Frys, plus a number of local shops still open (although they aren't as go-to as they used to be). That way, I know I'm quick drive back if something seems amiss.
I realize not everyone has that option though.
pc master race, u no have 3080
gamers lounge Touge_ninja Off-Topic Lounge [WARNING: NO POLITICS] 25 01-21-2014 05:32 PM
GT Acadamy Gamers Banned from Britsh GT Pro-Am WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 16 02-11-2013 07:37 PM
