Old 01-21-2021, 11:04 PM   #1
jflogerzi
jflogerzi's Avatar
GT radial SX2 track owners question about PSI
What PSI do you run hot on track? Trying to figure out what is the best/optimal PSI...
I run 245s on a 17x8 wheel
2013 Series 10 FRS #553
Old 01-22-2021, 01:27 AM   #2
CSG Mike
CSG Mike's Avatar
Depends on your setup and preference. There is no universal one best, just how your tune is customized to your setup.
Use a pyrometer. You're welcome to borrow mine as long as you don't damage it.
Old 01-22-2021, 09:03 AM   #3
jflogerzi
jflogerzi's Avatar
Yup I get that.
Setup mostly in sig. Suspension is stock 17 non pp dampers, rce yellows, and peddlers top hats. I have a whiteline 20mm sway bar up front on stiff and a 2017+ oem rear sway out back. Alignment is -2.3 up front and -2.2 in the back
I normally shoot for 30-32psi hot. I feel like the higher it goes the less grip the car has...
Old 01-22-2021, 12:17 PM   #4
Pat
Pat's Avatar
Drives: 2023 BRZ
I like 34 hot with 225 45 17 SX2s on an 8" wheel. 3.6* front camber, 2.5* in the rear.
Old 01-22-2021, 08:19 PM   #5
CSG Mike
CSG Mike's Avatar
most of the socal records are held by 37-40psi hot
Old 01-22-2021, 08:21 PM   #6
jflogerzi
jflogerzi's Avatar
Really wow... So excuses my ignorance what's the benefit of having a higher PSI vs lower PSI
Old 01-22-2021, 09:35 PM   #7
Pat
Pat's Avatar
Drives: 2023 BRZ
Hmm.. very interesting. I wonder what the rest of their setup is like.
Old 01-22-2021, 09:50 PM   #8
Pat
Pat's Avatar
Drives: 2023 BRZ
So maybe they go out and turn a fast lap with cold tires at 34 and by the time they are done they are up to 40 hot? Or do you really think the fastest laps are turned with tires between 37 and 40?
Old 01-22-2021, 10:53 PM   #9
CSG Mike
CSG Mike's Avatar
Stock class car in many instances, so.... quite literally a stock car, with a 17 rear sway, and camber modification, brake pads, and oil cooler.
In the case of William's car, -4ish front camber, -2.7ish rear camber, 0 toe front/rear.
His fastest laps are typically laps 6-10.
Old 01-22-2021, 10:54 PM   #10
CSG Mike
CSG Mike's Avatar
There isn't. That's where it happened to end up when tuned by pyro.
Old 01-23-2021, 08:34 AM   #11
SCFD
Why a rear sway bar instead of front?
SCFD is offline   Reply With Quote
Old 01-23-2021, 10:42 AM   #12
jflogerzi
jflogerzi's Avatar
I need to read up on these pyro tire devices.
Old 01-23-2021, 06:30 PM   #13
CSG Mike
CSG Mike's Avatar
Rotation.
We don't really slalom on tracks the way you do in AutoX, so there's not a reason for giant front sway.
Old 01-23-2021, 08:59 PM   #14
Pat
Pat's Avatar
Drives: 2023 BRZ
Abe and I were talking about these hot tire pressures that set lap records in SoCal. We still struggle to understand how this is possible given our data. I could understand one or two PSI difference but six is really difficult to comprehend. Especially when I can feel 35 is too hot relative to 34. I have a lot to learn.
Question for BRZ tS owners: Raven86Project Cosmetic Modification (Interior/Exterior/Lighting) 4 04-18-2019 11:57 AM
Question for 860 owners CoolHandMoss BRZ First-Gen (2012+) — General Topics 3 07-20-2018 11:20 AM
A question to all you SC owners McG86 Forced Induction 18 03-22-2016 04:16 PM
Question for the the 2014 Brz Nav Owners (BT Question) jbsali Electronics | Audio | NAV | Infotainment 3 07-16-2014 11:41 AM
Question for HOUSTON Fr-s owners and/or to be owners enjoi23 Southeast 2 08-30-2012 09:48 PM
