Old 01-22-2021, 04:57 PM   #29
86TOYO2k17
Drives: 2017 toyota 86
nitto nt05R is probably the best tire for hooking up that you can drive on the street and aren't completely F'd if it rains.
Also note with the NT05R or even the 555R they need a lot of heat to grip, when cold they are often worse than generic street tires.
Once you've done everything possible to maximize grip, at a certain point you might not be able to overcome the physics and will need to turn her down. but a lot of things you can try and still do until that point.
aero wont help much 1-3, but 4th+ a rear diffuser, side skirts, flat bottom, front lip can help reduce lift in turn adding more "weight" to the wheels.
Old 01-22-2021, 05:14 PM   #30
CSG Mike
CSG Mike's Avatar
None of this applies when you're making the OP's level of torque. For all intents and purposes, if the tire won't hook for a Z06, it won't hook for the OP.
Neither of those tires will ever hook up at a reasonable speed for the OP.
CSG Mike is online now   Reply With Quote
Old 01-22-2021, 05:43 PM   #31
ft86xtc
Drives: 2013 FRS
Spring rates aren't granular enough to adjust based on corner weights.
Run the car high and use the stock bump steer geometry to your advantage for launching or rolling launches. If you're already used to slick walk, then this kind of alignment wont bother you.
I understand there is more to finding the correct spring rate and it's not based off just your corner weight. Currently I'm running off the shelf stance coilovers, I believe they came with 8k springs front and rear. I have the ride height set as high as I can go and had the car corner balanced. I feel with being able to adjust compression and rebound separate with a softer spring will allow you to dial in weight transfer better than what Im working with now. I appreciate any advice as suspension is not my strong suit.
ft86xtc is offline   Reply With Quote
Old 01-22-2021, 05:48 PM   #32
CSG Mike
CSG Mike's Avatar
The type of squat control you want won't really be possible with the coilovers you have. You'd quite literally be better off stock, as long as you don't bottom out the rears on launch. How much stroke do you have now?
Old 01-22-2021, 07:36 PM   #33
johl
johl's Avatar
Drives: toyota 86
Mca traction mod will not help you with this issue. I have the Mca mod in mine and it is purely designed for mid corner grip by changing the suspension geometry. So look elsewhere for a solution to your traction issue.
Can you post up a dyno graph? I would hedge a bet that your power is almost vertical. Are you able to switch the rear turbo housing to a smaller one and then retune to make a lot more area under the curve, rather than a massive cliff where the car makes 400hp over 1000rpm?
johl is offline   Reply With Quote
Old 01-22-2021, 07:54 PM   #34
ft86xtc
Drives: 2013 FRS
Yeah I'm assuming the OP is in the same boat with his suspension setup. I would run stock struts but I need the clearence for the wheels and tires. To be honest I know I'm working with cheaper coilovers and planned on upgrading eventually. Are you asking how much stroke am I using or how much stroke it has overall? I havnt checked how much it uses under a launch but it can't be much. Correct me if I'm wrong but a softer spring will give me more stroke to a point?
Old 01-22-2021, 08:06 PM   #35
CSG Mike
CSG Mike's Avatar
Both. How much compression stroke do you have available and how much of it do you use?
As long as you don't bottom out, yes, a softer spring will get you more bump (squat) travel
Old 01-22-2021, 10:22 PM   #36
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
This guy uses the best tires:
Old 01-22-2021, 10:38 PM   #37
Irace86.2.0
Best tires here too:
Old 01-23-2021, 12:13 AM   #38
86TOYO2k17
C6 forums tons of guys making 550-650whp hooking 2nd on the street with NT05R , they need heat before they hook is the problem too cold of day and or not warming up the tire first and they skating if you get on it.
Old 01-23-2021, 05:09 AM   #39
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
OP Tire is NT555R not NT05R. (Too cold for the tire still possible)
NT555R
NT05R
Old 01-23-2021, 05:49 AM   #40
CSG Mike
CSG Mike's Avatar
first off, look at the GEARING of a C6Z, and second, look at the SIZE of the tire on the C6Z.
Terrible comparison.
To put it in perspective, 2nd gear on a C6Z is roughly equivalent to 4th gear on my Supra.
Old 01-23-2021, 09:21 AM   #41
pope
has a funny hat
Drives: 2014 BRZ Limited
So what you’re saying is OP’s 3.73 rear is too much gear and if he really wants traction he’d swap in a rear diff with more gearing options (like an 8.8) and take advantage of the any of these factory ratios: 2.26, 2.47, 2.73, 3.08, 3.27, or the multitude of aftermarket gears sets.
pope is offline   Reply With Quote
Old 01-23-2021, 11:03 AM   #42
86TOYO2k17
NT555R
NT05R
You should probably read more comment posts so you don’t take posts out of context.
If you read you’d see I recommended NT05R. and mike said it was a bad tire.
Not sure how you got me saying OP already had NT05R
Sub talk. Howaitoguru Electronics | Audio | NAV | Infotainment 34 08-01-2019 06:00 AM
Rewire an AT traction button into MT? Use traction toggle as an accessory? The_Understated Cosmetic Modification (Interior/Exterior/Lighting) 27 05-06-2017 11:35 PM
Why does my BRZ have LESS traction with traction control on??? BRZnut BRZ First-Gen (2012+) — General Topics 19 12-16-2013 03:28 PM
Talk me into, or out of, a Mac Chimpo Off-Topic Lounge [WARNING: NO POLITICS] 49 06-18-2013 01:37 PM
BMW talk RaceR Other Vehicles & General Automotive Discussions 101 01-15-2013 11:32 AM
