Tracking / Autocross / HPDE / Drifting What these cars were built for! |
#43 | |
Weight Weenie
Drives: 15 FR-S
Thanks, it looks great in the video (Power band) Would you do it again? |
#44 |
Drives: Track preped NA FRS
The Following User Says Thank You to Icecreamtruk For This Useful Post: | new2subaru (12-13-2020) |
#45 |
Weight Weenie
Drives: 15 FR-S
The Following User Says Thank You to new2subaru For This Useful Post: | Icecreamtruk (12-14-2020) |
#46 | ||
Drives: Miata
Why don't these guys do the same? Quote:
#47 |
Drives: Nevermorange FRS
No - I wasn't going to pay "cusco" prices for a piece of aluminum.
I did this: https://www.ft86club.com/forums/show...&postcount=111 And this: https://www.ft86club.com/forums/show...&postcount=134 For the same reason I didn't for the last 2 years, sometimes you don't realize you need something until it becomes blatantly obvious. The same reason why I wrapped my front/overpipe to keep the heat out of my transmission so I don't have to change the fluid as often.. but I did 2 seasons of racing, often replacing my trans fluid before I thought "Hey - I could make this situation better easily, cheaply and legally."
SCCA T4 - FRS
The Following User Says Thank You to rice_classic For This Useful Post: | new2subaru (12-15-2020) |
#48 | |
Drives: Miata
Just meant, did you install a heat shield. Seems a no brainer...thanks. But they're building new axles and no mention of a heat shield, I don't get it. |
#49 |
Drives: 2013 FR-S, 2017 BRZ
So I'm about to rip apart the axles on my car and do a maintenance inspection & repack-- Ordered a couple tubes of redline CV-2, but I'm curious as to a specific volume to repack back into the joint? Any guidance on that?
I'll be adding heat shields like what you did as well. I had similar on my RX7 and it really helped get heat out of the car. prior to those treatments, the exhaust was so hot, it was melting the wiring inside the car and burning up electronics. I wrapped the exhaust, put a couple layers of DEI heat shield stuff on the bottom of the car, and added another layer inside. maybe 3lb total added to the car, but I could put my hand on the floor of the car at the end of a race in the same location the pain had previously turned black and blistered away. |
#50 | |
SCCA T4 - FRS
The Following User Says Thank You to rice_classic For This Useful Post: | bcj (12-15-2020) |
#51 | |
I was also planning to just yank the boot, toss them into the parts washer and walk away for a while.. way less effort than manually cleaning! Been trying to find a proper FSM to download, but all the links I come across are either invalid or my work computer deems the site unsafe. ![]() |
#52 |
Well that was a bust.. my tuner called and said the axles were so noisy on th dyno, he thought they were gonna blow.
So I picked up some junkyard axles and swapped them until I could open and find out what was up. I got em open last weekend and these axles are toast. All the wear surfaces are pitted and galled. They weren't going to blow up on the dyno, but they were definitely done. Don't know how much track time was on them, but they were cryo treated by previous owner and packed with some *really* thick grease. Maybe that lengthened their lifespan, but theyre done either way. No part lasts forever! I'm currently swapping the rear to a 4.3 from a 2017 and have some of the PBM diff riser bushings on the way. Will rebuild the junkyard axles w/ redline CV2 while its all apart and see how long they last me. |
#53 | |
Drives: 18 BRZ PP & 99 Spec Miata
What are "motorsports boots"? Is there any data that the heatshields are helping? |
#54 |
Drives: GT86 TRD Cup
The official TGM upgrade is high temp grease and a 3mm roll pin a breather for the boots
GKN make a motorsport boot. https://www.merlinmotorsport.co.uk/p...rd-gkn-ms6j002 And we got an bulletin from Seat for the TCR cars to wrap wire lock around the valleys' off the CV boots to increase the life so they do not expand as much with heat |
Buying an early build in the fall, but some issues with these cars are worrying me... | RyMi | BRZ First-Gen (2012+) -- General Topics | 34 | 02-27-2019 08:56 PM |
LCA Upper Ball Joint Issues (maybe?) | NAEightySix | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 19 | 11-03-2017 12:31 PM |
AVO owners who HPDE/Track... Any issues? | seven | Forced Induction | 11 | 01-19-2015 10:15 AM |
New cars produced still suffering from first year issues? | Lord09 | Issues | Warranty | Recalls / TSB | 30 | 09-22-2013 06:32 PM |
Brake issues on the track | Mike @ MRP | Tracking / Autocross / HPDE / Drifting | 28 | 08-30-2013 04:03 PM |
