Old 01-14-2021, 03:24 AM   #43
tomm.brz
Drives: brz 2017 hksv2
Originally Posted by Compelica View Post
To clarify - does that mean the AFR values would display 11.25 as the lowest value from OBD tools, though stock tunes go richer than that? (10.8 or so I recall).
afr can go to anything, like if you clog someway the intake, or increase the intake tube diameter where maf sits, it will run a lot richer than that
it just means that your current tune has a lambda sensor scaling that only goes as low as 11.25 AFR
I recall Wayno and kodename possibly, they use a scaling that goes to 10.8 or something like that
Personally I scaled it to 10 AFR and I have an extra wideband sensor in my headers to check anytime the real afr
anyway that sensor is broken now so you don t know the afr, it could be 10 or 13.5, it shows 11.25 just only because it s broken and sends a maxed out signal... the afr target map is just a reference
don t drive anymore your car untill you replace the sensor
Old 01-18-2021, 09:53 AM   #44
Jfheisenberg
Jfheisenberg's Avatar
Drives: 2015 BRZ Series Blue WRB
Trying to find the OEM sensor but none of my closer Subaru dealer have in stock. Im gonna have to order it.
Would this be the right part? cant tell if this is the one with the grey connector
https://parts.libertysubaru.com/p/su...2641AA640.html
Jfheisenberg is offline   Reply With Quote
Old 01-18-2021, 09:57 AM   #45
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Check Toyota too.
Old 01-18-2021, 07:11 PM   #46
Silvermk2
Drives: Toyota Supra 2JZGTE VVTi
Why wouldn't you just go to Rockauto and buy the Denso sensor for $95? They make the OEM stuff.
Silvermk2 is offline   Reply With Quote
Old 01-20-2021, 11:00 PM   #47
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
This is why:
https://grassrootsmotorsports.com/ar...t-speed-parts/
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
Old 01-21-2021, 02:25 PM   #48
Silvermk2
You really think Rockauto is flipping counterfeit parts? How do you do know a random internet site is actually shipping you Subaru parts? In my experience Rockauto is usually drop shipping them from the manufacturer. Denso and Aisin make almost everything on most Japanese cars outside of Honda.
The Following 2 Users Say Thank You to Silvermk2 For This Useful Post:
soundman98 (01-21-2021), x808drifter (01-21-2021)
Old 01-21-2021, 10:42 PM   #49
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
You don't think Denso or any other "OEM" parts can't be counterfeited? I wouldn't want to find out the hard way, so I would rather go to the dealer for the parts and install them myself. That way, I can pull the old one out and compare it to the new one I'm putting in for peace of mind.
And I would NEVER go aftermarket on something as important as a sensor. That's just asking for trouble.
Old 01-27-2021, 01:08 PM   #50
Jfheisenberg
Originally Posted by tomm.brz View Post
maf has no problem to me
anyway always good to clean it
your problem is a faulty lambda sensor, maybe you got it damaged , it swings between max and min so you need to replace that
You were spot on! After replacing this sensor (primary O2 / lambda sensor) , all my problems went away. The car is idleing fine, and no longer having the sluggish problem.
The car even sounds better now. I drove like this for about 2+ months and these past few weeks the car started to sound like shxt.
Thank you all that help me figured out this problem, really appreciate it. Fingers cross that i dont get more problems.
The Following 2 Users Say Thank You to Jfheisenberg For This Useful Post:
FR-S2GT86 (01-27-2021), Lonewolf (01-27-2021)
Old 01-27-2021, 04:57 PM   #51
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Glad you got it solved.
The lesson here is that even though there's no CEL or diagnostic code, that doesn't rule out a bad part. Data logging is your friend and should always be used as a tool to help you figure out the problem when your engine seems to be operating incorrectly.
The Following User Says Thank You to FR-S2GT86 For This Useful Post:
Jfheisenberg (01-27-2021)
Old 01-27-2021, 07:35 PM   #52
Jfheisenberg
Yes, there was no CEL code while i was with the OFT stage 2+ tune. Last December, when i flashed back to OEM tune and took it to the dealer, i got code P219A "Bank 1 air fuel ratio imbalance" Idk what this meant, i thought this was due to my catless header and running with stock tune.
One thing to point out, is that I also contacted OFT support. Their support team mentioned that they 'disable' some codes while on Stage 2+ tune. Im not sure why they do this. I think that if those codes where not disabled, i could have found the problem much faster.
Old 01-27-2021, 08:03 PM   #53
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
That makes total sense in your case with your catless setup that the OFT flash would have disabled that code from triggering a CEL, and should be something that users of the product should probably be made aware of before using the product (if they aren't informed somewhere already). I've got the rear O2 sensor failure related codes disabled in my flex-fuel tune through EcuTek. Sometimes in order to make a gain somewhere, you may have to make sacrifice somewhere else and we have to live with that and adjust to it as best we can.
It's threads like this though that help us all learn how to overcome issues that crop up when using aftermarket tunes. I'm glad you were able to get back with us with the final verdict. And glad your twin is back on the road playing nice.
Rough idle edwardry2019@gmail.com Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 10-14-2020 01:28 PM
Rough Idle DeathToocher Engine, Exhaust, Transmission 18 03-20-2020 10:45 AM
Took my car in for rough idle... Da Brz Issues | Warranty | Recalls / TSB 34 10-29-2016 12:57 AM
'14 BRZ Ltd. - Rough Idle leicaboss BRZ First-Gen (2012+) — General Topics 20 05-22-2014 06:40 PM
Rough Idle & CEL *video JiB Issues | Warranty | Recalls / TSB 5 10-04-2012 10:28 PM
